Results 1 to 37 of 37
    Building up Ignition Frame - need help on shock mount
    So I probably got one of the last Ignition frames to be sold as a frame only. Finally got around today of disassembling my San Andreas and moving all the components over to the Ignition, but I don't get the shock mount.
    I assume I have to get some new hardware to mount the shock - a Cane Creek Cloud Nine. I was hoping someone might have a picture of the upper mount and how that works -- it's so wide, that I just don't quite get it, and wonder if I"m missing something.
    Would be cool if anyone has a picture of their shock mounted up close I could see.
    Thanks.
    BTW - building it as a 1 x 9 -- so the front derailer hitting the frame shouldn't be an issue. Will have to harden up on the steeper climbs to make em on a 32 tooth ring.
    MT - thanks for the pic. I figured it would be something like that, but having the visual helps tons.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by MiniTrail
    Attachment 497981
    smart move on the 1X9
    Whats that red lookout thingy for???
    Formotion Products
    http://www.formot
    Jan 2005
    COLOR
    I turned it on twice. Both times in error.
    any hep with the spacers for this guy?
    Do like I did disconnect it and throw it away.
    Ohhhh now you want to give away bushings ayyy, got measurements??
    Formotion Products
    http://www.formot
    Jan 2005
    I thought I'd seen you bike nerds post links to places to buy such things.
    Got any links?
    maybe something else red to look at while were waiting?
    Need help digging the driveway yet??
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-23.jpg
    Formotion Products
    http://www.formot
    Jan 2005
    These guys rock!!! http://www.greasybench.com/
    Formotion Products
    http://www.formot
    Jan 2005
    no dangit
    but they can help with Jake's pony
    1 7/8" between the rockers
    25.4mm???
    Speaking of Jake.
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-paraquat.jpg
    Formotion Products
    http://www.formot
    Jan 2005
    Sorry my bushings are all narrower than 1 7/8
    Formotion Products
    http://www.formot
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    Quote Originally Posted by dogonfr
    I'm stayin' out on this one
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-capturewiz860.jpg
    Jan 2005
    Just found one but the spacer on the bushing is stuck on because it looks to have been smacked but it should still work.
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-p1010014.jpg
    Formotion Products
    http://www.formot
    Thanks guys...i'll see what my local shop has first. They have a whole wall of miscellaneous parts and I bet they have something that will work.
    I have no idea what's happening in this thread, but if the brunette with the shovel is free to help with my bike, send her my way.
    Jan 2005
    metrics shmetrics
    Best work I've seen around here for a while. It's kind of a free for all forum at this point.
    you've got an eye for talent
    Q you.
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-pool-q.jpg
    Formotion Products
    http://www.formot
    Jan 2005
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/jAAKPfOQA_Q&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jAAKPfOQA_Q&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    Formotion Products
    http://www.formot
    Jan 2005
    have a happy guy!
    those big knifes were scary
    And a a great Pumpin Pie to you also,
    Formotion Products
    http://www.formot
    back on topic:
    you are building 1 X 9, what are your plans for a chain-retention device? I'm using a black-spire Stinger, but I had to modify it with a Dremel tool to make it fit the frame......so far I have mixed results (I still lose the chain at least once every ride)
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    ill be building up a middleburn crankset with a road dérailleur soon.. when i acquire all the parts after December ill sow you guys.
    RAH!
    nicely done mini!!
    RAH!
    if it works then its a job well done!
    I modified an old mrp sandwich guide dog gave me to fit a smaller diameter guard and brought the wheels in to they wouldnt contact the frame. dont have pictures of it though
    RAH!
    Jan 2005
    Don't tell the mrs about the spoon
    Thought that was your coke spoon!!!
    Formotion Products
    http://www.formot
    Jan 2005
    that's what ho's hinnies r fo
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-20.jpg
    Formotion Products
    http://www.formot
    Jan 2005
    the shadows give it away
    pretty cool though
    Attached Thumbnails Attached Thumbnails Building up Ignition Frame - need help on shock mount-slam-dunk.jpg
    Formotion Products
    http://www.formot
    Yeah I shortened my chain,,,,,and yeah, the chain comes off when it enters the largest sprocket......I love your solution...pure genious....I love it.....its f**'g ugly, but it works.....
    I'm gonna try one other "prettier" home-made solution but if that doesn't work I'll be going through my wife's silver-ware......
    Well my chain-retention system on my 1X9 Iggy actually works......went for a ride on one of my nastiest trails and no matter how hard I tried, not one dropped chain over the course of the entire 20 mile ride...
    I was hoping it would fail miserably and give me the excuse to go the silverware route.........I was even eyeing one already and actually hid it in the garage from my wife......
    Jan 2005
    Quote Originally Posted by osmarandsara
    Pic or I call the Wife!!!
    Formotion Products
    http://www.formot
