Results 1 to 13 of 13
    Reputation: kerrys914's Avatar
    Bashed my Big ring..SOB
    Okay I bashed my big ring and lost a few teeth from the big ring at the same time.
    Seeing is I don't use it much can I just remove the big ring and add a bash guard? I have seen them on bikes but really don't know much about them...As you can tell.
    I assume I just adjust the stops on my front D. to not alow a shift in to the missing big ring??
    Cheers and thanks.
    Building an Asta right now
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Yes to all of that
    No moss...
    I win.
    Reputation: Popper252's Avatar
    Here ya go man. Click
    14 dollars shipped.
    You'll want a 104 BCD and a 32 tooth. You can go 34 and 36, they're just designed to cover a bigger middle ring. They have colored and "super light" ones that look pretty cool.
    Good luck!
    09 Giant Anthem X3
    07 IBEX Trophy Comp X7
    Reputation: boomn's Avatar
    Quote Originally Posted by kerrys914
    Cheers and thanks.
    Yep, most bashguards are meant to be a direct replacement for the big ring. After you have it installed then you can adjust the high limit screw. Its super easy
    Ordering a BBG today
    Will a size 32 protect a 32t ring or will I need a size 36?
    The 32t bash will be enough. I currently have a 32t BBG on my bike
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    I like a 36T for the range so to answer the question go with the 36T guard that way if yo decide to go with a 36T you only need a sprocket.
    Formotion Products
    http://www.formot
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    Kerry's,
    You my want to consider upgrading the middle chainring to a 36t along with the bash ring..
    In doing so you wont lose all of the speed and still have a higher ring to obstacle clearance..
    Flying Goat
    Reputation: mrpercussive's Avatar
    ditto on the 36t... you'll out spin yourself too easily on the 32 and the 36 is a good medium for lower speed techy stuff to highspeed balls out bombing stuff...
    Thanks guys..I'll be sure to post a photo when it arrives
    I win.
    Which one did you end up choosing? Color?
    09 Giant Anthem X3
    I ordered the 32 blue.. I couldn't wait for the 36 to be made plus at $14.. I will buy another if/when I change my 32t.
    Thanks and the Bling photos will be posted soon.
    Kerry soon to be in St. Louis
