    Atlas Pro Fork Travel
    Hello there
    Just wondering- has anyone run a fork with up to 160mm travel on their Atlas? If so, how did it go?
    In my final musings over an Atlas frame; my Marzocchi fork is adjustable 120-160mm and I've noticed the SC Heckler has the same geometry but will take up to 160mm travel apart from the slight slackening of head angle (probably to about 67.5-68 you think?) do you think the Atlas frame is strong enough to handle that little bit extra? (Assuming one is not concerned about warranty and is not a suicidal rider).
    Just seems it would be nice to be able to slacken the head angle sometimes and use that spare travel from time to time.
    locked - time out
    Quote Originally Posted by songairen
    Hello there
    set more sag and should be fine.... i know that it seems like setting more sag it seems pointless to run a 160mm fork, but you need the travel for the drops I assume? well once airborne the fork is topped out at 16t0mm. Depending on the fork also. Manitou has a longer axle to crown length then marzocchi does.
    thanks for the advice it was really helpful xD
    Flying Goat
    Reputation: mrpercussive's Avatar
    a 160mm would rake out the front end too much, and raise the BB height a lil... It will compromise your ability to corner and to throw the bike around... I honestly would not go above 140mm if you indeed want to keep that bike fun...
