Results 1 to 20 of 20
    Reputation: BIGHaroHucker's Avatar
    X7 Bottom Bracket
    I have noticed that my bottom bracket keeps getting louder and louder. I haven't taken an "external" apart before. Do I replace the whole thing, or just bearings, or what? Does anyone know what I need as far as parts?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    You should be able to replace just the bearings using the Enduro tool or some creative wrenchin.
    http://www.enduroforkseals.com/siteb...ress_tool1.pdf
    Dirtlabs is awesome, great people.
    http://www.greasybench.com/
    Formotion Products
    http://www.formot
    Thanks dog. You the man. I knew you would pull through for me.
    Jan 2005
    If you have a bearing warehouse near you can get the numbers off the bearing seal and they should have them on hand.
    Formotion Products
    http://www.formot
    Jill...or dog...
    Is there any way to find out what the exact bearing is before I tear into it so that I dont have to have by bike apart for several days waiting on parts?
    Jan 2005
    Quote Originally Posted by BIGHaroHucker
    Jill...or dog...
    You will most likely have to pop off the left crank arm to see the bearing numbers located on the seal, the manufactures dont include that info on their tech sheets.
    http://www.greasybench.com/SealedBearings.aspx
    http://www.thisoldtractor.com/gtbender/bearing.htm
    Formotion Products
    http://www.formot
    Jan 2005
    What crank set and BB do you have??? I should have asked that sooner.
    Formotion Products
    http://www.formot
    Stock truvative cranks in the stock external BB. Not really sure more than that...lol.
    Since I dont have the proper tools, I might just take it into the bike shop. Depending on cost...
    Jan 2005
    Looks like you have the Truvativ Howitzer BB, wouldnt pay over $40
    http://www.spadout.com/b/Truvativ/bottom-bracket/
    Formotion Products
    http://www.formot
    Here is what my local bike shop has. They have the Truvative Howitzer "Team", and the CrMo. What is the difference? Is the team better than the regular? Or should I just order it online and save my money?
    Oh, and how do I know what size it is? Chainline?...
    Jan 2005
    You want the Team CrMo it is designed for real riding the XR is light weight riding.
    http://www.sram.com/_media/techdocs/...itzer-e-r0.pdf
    Formotion Products
    http://www.formot
    I just wanted to let everyone know what I found out, just in case someone searches for this info later.
    The 2006 Haro X7 has the Truvative Howitzer BB in size 68mm x 50mm. I was able to contact Haro and get the info and continue riding until my parts get here. Thanks dog, you the man. I ended up going with the CrMo Team BB. And while I was at it I bought 2 of them. $29.99 each at pricepoint.
    Haha, while I was on pricepoint I decided to get the BB tool, some more grease, more chain lube, a chain cleaner, and a chain guide. That place gets me every time. Their prices are just too good to pass up.
    Jan 2005
    Can never have to many tools or lubes.
    Sorry about the vague post last nigh was getting late and had to be a early riser this morning. Too much like work to pay the bills then count the pennies for the bike bits.
    Formotion Products
    http://www.formot
    No need for apologies. You helped me plenty with this.
    Before you blame it on the bearings, sometime the creaking comes from the threads...some grease on the threads usually quiets it, or making sure it's tightened.
    I replaced the bearing regardless. The bike has been ridden a lot since I got it in 2007. I weigh 300lb so it definitely gets lots of use.
    Jan 2005
    And like the name says BIG Haro Hucker he frigin rides that bad boy hard.
    Formotion Products
    http://www.formot
