Results 1 to 2 of 2
    v-brakes on a Flightline?
    I own a comp frame,came with disc, and a friend wants to buy it and use v-brakes on it. Is that possible?
    Reputation: watkinscapital's Avatar
    It depends on the year and if the frame has brake post mounts? If the frame has brake post mounts on the top of the rear seat stays then it will work, you will just need to buy brake studs.
