    Jun 2010
    Steerer Tube Length Haro Flightline Comp
    I have a 22" frame Haro Flightline Comp and am interested in upgrading from the Dart 2 Fork. What length fork steerer tube do I need to order?
    BJ
    May 2010
    It should come with a set length if you are buying new, you need to trim it down to the same length as your current one or get a bike shop to fit for you, it wont cost much.
    If you are buying secondhand then check the forks being offered have one that is as long or longer than the one you have.
    Jun 2010
    I am looking at purchasing an OE take Tora from Jensen and am not sure which length to buy. Any help out there???????
    Reputation: downhilljill's Avatar
    Apr 2005
    Like Curlie said, if this is a new fork, it will come way longer than you need it. You cut the steer tube down and re-install a star nut to fit your bike.
    If the Tora fork is a new take-off fork (meaning it's already been installed on a bike) or if it's a used fork, your best bet will be to measure the steer tube length on the Dart that's on the bike now. If the new fork is at least that long, you are good to go.
