Results 1 to 3 of 3
Thread: Rs Fail!!!
    huh?
    Rs Fail!!!
    I finished the build on my LT a couple weeks ago. And now I think I have to replace the rear shock. I've developed a metallic "squeegie" sound on the MC3.3 that redefines the word "annoying".
    Yes, it IS from the shock. While trying to locate the sound, I pulled the shock from the frame and compressed it by hand. There it was.
    I used some stanchion lube, even got some under the seal. Not any better. Any LT owners here experienced this? Did you get rid of the noise? Tips before spending the $$ on a new rear shock?
    the MC3.3 noise I had was like having a loose head set. its more like a clunking sound.
    Get a RS monarch4.2 High volume or a Fox RP23 HV with boost valve. It will give your frame a whole new level of performance
    Reputation: downhilljill's Avatar
    Apr 2005
    You might want to have your local shop take a look at it and have them contact RockShox warranty for you.
