Please help me identify this Haro MTB!!!
I posted a couple of pic of what it looks like, dunno much about it. The frame kind of looks similar to Haro escapes but it lacks the little tube that connects the top tube and the top of the seat tube that makes a little triangle. It has similar specs too: Manitou splice 130mm, hayes brakes, truvativ husselfelt bars and arms, kenda tires.
That's all I really know about it since it's second hand. Please let me know if you recognize it and let me know any detail that I could provide to help identify it.
I found numbers on the bottom bracket( not sure if this is what it's called, its the part where the crank attaches)
one says A289-2 across in the middle of the bracket bigger letters parallel to the handlebars, and another says 0434000063 towards the side side of the bracket perpendicular to the other number given above.
I don't know if this helps, but I thought i'd post it.
thanks.
I'd say an 03-05 Escape 8.1,2 or 3. Looks like it's been resprayed. Rugged Frame and fun frame.
Didn't the Escapes from 2003-2005 have a little supporting gusset stretching between where the top tubes meets the seat tube?
I've never seen the small size frame though. Perhaps those didn't carry the gusset (if that's the correct term)
Sorry but a blatant way of upping post so I might get some pics for ya
Specs
Frame is green but its luster not gloss
Discs: Avid 160
Tyres: Kenda
Brakes AVID 5 ball bearings
Shocks Sr Suntour XCT V2
Seat: Velo
Seat Post: Kalin
Crank arm TruVativ (SRAM)
Rear Derailleur: Deore
Cassette: CS HG 30-81
RIMS: ZAC19 26*1.5-1.95
Hope this helps
Kaffine
- You may not post replies
- You may not edit your posts
Forum Rules
