Need the clamp size and BB measurements of a 2004 Haro Werx XLS
Hi,
I just bought a used 2004 Haro Werx XLS frame but cant find any technical docs on the frame dimensions. Specifically I need to know what size front derailleur I need (clamp size) and the Bottom Bracket size. Thanks!
ride hard take risks
You'll need a 31.8mm clamp size; down pull, top swing front derailleur.
The BB shell is 68mm. Your spindle width is dertermined by the cranks you decide to run; the crank manufacturer can advise what's compatible.
- You may not post replies
- You may not edit your posts
Forum Rules
