Results 1 to 2 of 2
    Reputation: dunerinaz's Avatar
    High clamp derailleur on shift frame?
    The shift normally runs a low clamp. Anyone know if a high clamp will work ok? I went to a 2x9 setup and want to move the derailleur down some but I'm all the way down against the bottom bracket. I don't see any reason why it wouldn't work but wanted to ask here first.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    As long as you have a cable housing stop and the swing arm has clearance anything is possible.
    Formotion Products
    http://www.formot
