Results 1 to 10 of 10
    Reputation: bikebike69's Avatar
    Haro Steel Reserve 8 headset???
    Hello all. I hope someone here can tell me the actual headset size required for this bike. I just picked up a bare frame but cant find any specs on the web. Yes I know it takes a 1 1/8 drop in type like the Ritchey Logic,but what size? I see on the web they come in a few different sizes,40.0,41.8, and the such. Anybody know for sure . Or maybe changed one out for yourself. I was kinda wanting to order the headset so it would get here by the time the frame comes in. Thanks for any info you can provide.
    Feb 2012
    Quote Originally Posted by bikebike69 View Post
    I just purchased the same frame and need the same info.. if you found out by now, please let me know
    sure,this is the one I got,works perfect 42mm;
    FSA Orbit CE Integrated 1-1/8'' White Campy (45/45) 8mm Aluminum top Cover | eBay
    good luck on the build,mine turned out pretty good.
    Also a little info on this frame. the rear stays will not hold but the most narrow of a 2.1 (kiniption) for example. so you prob need to run a 1.95,just so you know.
    I run SB8s on most of my DJ bikes and the 2.1 will not fit the rear on these bikes.
    Feb 2012
    Wonderful thanks so much! This will definitely help me get on the trails much sooner
    Mar 2012
    I want that bike
    good luck on the build,heres mine as of today.
    I have a trek 4300 '09 will the 100 mm shocks fit on that frame
    Also what other parts of the trek can I use tires,rims,disc breaks,
    Tires, handle bars etc?
    lipship
    Guest
    Anonymous abuse is for cowardly mugs..
  1. Haro steel reserve 1.1
    By A-NON-A in forum Urban/DJ/Park
    Last Post: 08-16-2011, 12:51 AM
  2. Paid Spam: Haro Steel Reserve 8
    By SlowbutSure in forum Arizona
    Last Post: 02-06-2011, 04:13 PM
  3. Replies: 18
    Last Post: 10-07-2010, 06:15 AM
  4. Haro Steel Reserve 1.3
    By droptopchevy in forum Urban/DJ/Park
    Last Post: 03-18-2010, 07:24 AM
  5. Haro Steel Reserve 1.1?
    By gbosbiker in forum Urban/DJ/Park
    Last Post: 01-30-2010, 10:52 AM
