Results 1 to 5 of 5
    Haro Shift R5 -update
    I bought a Shift R5 early this year and I´m really happy with my bike. The thing is I recently putted it on a scale and it weighs in at 32.5 pounds which seems a tad heavy for a bike with 120mm of travel on both ends…
    I´m no weight weenie by any chance and you can see from the upgrades I´ve made. I always look for function before making crazy weight cuts. The thing is I want my bike to drop a couple of pounds maybe by upgrading the wheel set. I was thinking of using transition hubs laced to some mavic rims, maybe some xm-819. Would that manage to cut some weight? Is there another upgrade that I could make to lighten my ride?
    I´m a heavy rider, 200 pounds with gear and ride mostly trails with some occasional downhill tracks.
    My current setup is:
    Frame Shift 6061 Hydroformed Aluminum; 120mm Wheel Travel
    Sizes 18”
    Frame Shock RockShox Ario 2.1
    Fork Rock Shox Reba Team with 20mm Thru-axle
    Headset Ritchey Comp Logic Drop In
    Crank Set Truvativ Fire-X 3.0 22/32/44
    Bottom Bracket Truvativ GXP
    Derailleur Front Sram X.7
    Derailleur Rear Sram X.9
    Freewheel Sram PG970 9 Speed 11-34
    Chain Shimano HG53
    Pedals Cranckbrothers Candy X
    Handlebar BlackMarket Badaboom
    Stem Ritchey Comp mtn; 6 degree; 31.8 clamp
    Grips Lizard Skins Steve Peat Lock-ons
    Derailleur Shifter Sram X.7 9-Speed
    Saddle WTB Rocket V Comp
    Seat Post Ritchey Comp 30.9
    Seat Post Clamp Pivit alloy QR
    Hubset Transition Revolution Front/Shimano M475 32h Rear
    Rim Ritchey OCR Pro
    Spokes Stainless steel 14g w/ Alloy Nipples
    Tires Kenda Kinetics 2.35 Front/Maxxis Ranchero 2.1 Rear
    Shimano SLX w/ 160mm Rotors
    Brake Lever Shimano SLX
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Thats a sweet looking bike!!!
    Formotion Products
    http://www.formot
    Reputation: downhilljill's Avatar
    Apr 2005
    Looks awesome!!!
    Thanks dogonfr and Jill. At some point I told you (Jill) I was going to make some upgrades to my Shift in order to make it more "air friendly", and I also want to end up with a lighter set-up.
    I´m currently thinking of changing for a shorter stem (70-80), and that´s going to make it easier for jumping and also lighter…
    The next upgrade I might make is getting a hand built wheel set using Transition hubs and some DT Swiss rims and spokes.
    I figure both upgrades would make my ride ready for minor dirtjumping? Thanks in advance for your answers…
    Jan 2005
    If you do more jumping the 70mm stem is cool but for all around do everything the 80mm gets the nod.
    Formotion Products
    http://www.formot
