Results 1 to 2 of 2
    Ride in heat
    May 2012
    Haro Shift R5 2011 stem dilemma
    Hi guys.
    Need some help. I'm trying these days to upgrade my wife's Shift R5 to something more aggressive. Bought her some shorter RaceFace Respond stem and RaceFase Atlas High Riser bar.
    Now here's the dilemma - Haro Shift R5 2011 stock comes with Ritchey Comp Axis 4 stem, which is 42 mm high with 20 mm spacer under it. But all the new MTB stems, and also the one that I've already bought, are 40 mm high. I can't find any spacer kit that will allow to put together 22 mm spacer.
    What should/can I do with those spare 2 mm of open space?
    Ride in heat
    May 2012
    Never mind, found 2 mm spacer at LBS, surprisingly...
  1. Haro shift discontinued?
    By Sdgreen in forum Haro
    Last Post: 07-12-2013, 06:14 AM
  2. Haro Shift Frame
    By superj101 in forum Haro
    Last Post: 06-01-2013, 10:18 PM
  3. Which FD for a Haro Shift R5?
    By goonboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2012, 08:49 PM
  4. Haro Shift R5?
    By basslu in forum 27.5
    Last Post: 05-30-2011, 07:11 AM
  5. Haro x7 frame and haro shift swingarm
    By Combatcm in forum Haro
    Last Post: 04-13-2011, 09:02 PM
