Page 12 of 13 FirstFirst ... 2 8 9 10 11 12 13 LastLast
Results 276 to 300 of 323
  1. #276
    if i can remember to take a pic, i'll post it. honestly, though, other than saying "P2" on it, there's little perceptible difference. well, i guess it doesn't look quite as beefy.
    and i doubt a picture of the old one would be of much help. but i'll take a picture of it with the tire in so you can see the offset i'm talking about.
  2. #277
    O.T
    O.T is offline
    "Cyclocross"
  3. #278
    Quote Originally Posted by loose chain View Post
    yeah, i haven't bothered to find out exactly what the problem is- whether it was the legs themselves or just the dropouts. didn't have rotor rub, but the top of the tire was offset by a good 3-4mm all the time, and when i'd get in the front brake pretty hard, it would yank the wheel out of the non-DS dropout a little bit.
    i had the slightest inclination to replace it with suspension, but luckily somebody offered up a takeoff P2 for cheap. has more rake (either 4 or 9 mm, depending on what the reality of the stock fork is), and 7mm less A-C height. altogether that got enough weight over the front end that i'm happy again.
    finally got around to looking at this- one fork leg was a full 1/8th inch shorter than the other. the dropouts were perfectly in phase otherwise, but the legs were definitely different lengths. which explains everything above. ended up donating the fork to yellowbike- with full disclosure of the problem.
  4. #279
    Oct 2012
    Couldn't help but bring back this thread. Just picked up this 2007 a few hours ago with 0 miles.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-imag0575.jpg
  5. #280
    Reputation: rob.char's Avatar
    Nice, what tires are on there? Mine came with Nevegals.
    Mary ss shenanigans
  6. #281
    Oct 2012
    Quote Originally Posted by rob.char View Post
    Thanks. This came with WTB ExiWolf 2.3
  7. #282
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    Here's mine, changed bar and stem to ibis, deore hydro's. I love this bike, mostly golden gate park and china camp but will try annadel and Boggs soon
    Haro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154581.748707.jpgHaro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154605.417220.jpgHaro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154634.307406.jpg
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
  8. #283
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Soo no riding this weekend eyy
    Formotion Products
    http://www.formot
  9. #284
    oge
    oge is offline
    Oct 2012
    Anybody happen to know the max rear tire width for the 08/09 Mary SS using the stock wheels?
  10. #285
    bhc
    bhc is offline
    It is approximately 2.5" I have a WTB Weirwolf in mine with Velocity p-35 rims which are wider than the stock wheel set.
  11. #286
    Sweet, I was going to ask the same question about rear tire width. I have plans to get a 2.4 ardent and run it in the back as well as the front which is set up currently and have a poor mans fat bike this winter. I am running the Ardent on a flow at 20PSI and it rides really well. A few PSI lower than 20 and I start getting rim strikes. I am at 175 pounds.
    I just read through the entire thread and I didn't see any info or pictures of people putting a carbon Niner fork on this bike. Anyone tried this or have anything to say? Is it blasphemy to put a carbon fork on a steel bike?
    I bought mine used and so far have it set up with a flow/hope front wheel after I tacoed the stock wheel. A WTB rocket v saddle (salsa branded with a chilli logo on the nose), a salsa pro-moto alloy bar, kona stem, Zeus Carbon seat post, Green Salsa skewers (really nice bling to the bike), Black ESI chunkies, BB7's with SD7 levers and 185's front and back, F-Ardent/R-Slant 6 2.2, and SPD 520's.
    Future plans for it are...
    Black Niner Carbon Fork (shoulda jumped on the jenson $200 sale)
    Rear flow/hope wheel w/ Ardent 2.4
    Nicer 18T cog
  12. #287
    Where are the pictures?....
  13. #288
    I haven't taken pictures of it in quite a while and have none to reflect what it currently looks like
  14. #289
    EXORCIZE
    Reputation: Ryder1's Avatar
    Quote Originally Posted by tooclosetosee View Post
    Niner carbon fork should work great. I like mine (on my Kona Unit) more than I liked the '07 Mary fork. Geometry isn't an issue and its lighter and rides better IMO. An all-steel frameset is a classic/romantic ideal, but the Niner fork is tough to beat. I chose Niner's "nude" color so it wouldn't look too out of place on any frame.
    2016 Pivot Mach 429 Trail
    2011 Kona Unit
  15. #290
    ridin' Mary
    Reputation: OhNooo's Avatar
    I bought a used White Brothers carbon fork for my '08 Mary. It worked great for about 6 months until I noticed what looked to be a stress crack in the clear coat of this carbon fork about halfway up the leg that has the disc brake mount. I realized that I might be playing with fire. So I replaced it with a Salsa fork. The Salsa fork was a full pound lighter than the stock Mary fork (which was a truly awful beast) and behaves just like the White Brothers carbon fork I took off. I'll stick with steel forks.
  16. #291
    Dec 2012
    I have a 2009 SS model and have heard / read of a conversion to a geared Mary simply by swapping the drop out... Masses of changes, will pop pics on when I see the thread is not dead.....
    The single spread has a flush drop out, I presume this is simply swapped for a drop out which has a mount for the rear mech. Then just run cables through full length outers and attach using zip ties..
    All the dropout manufactures I've been to don't make a drop out anywhere near comparable!
    Can anyone post a link to a supplier of the dropouts please?
  17. #292
    bhc
    bhc is offline
    I got mine from the Haro dealer.
  18. #293
    Dec 2012
    BHC, thanks for responding...
    I'm in the UK, I was speaking with the UK supplier today and they don't supply the part... They suggested a US or Australian specialist provider maybe able to help.
    Do you have an email for your supplier please? Even better if you had a link to the part or component number etc....
  19. #294
    bhc
    bhc is offline
    Look at this old thread
    Haro Mary SS - conversion
    After my reply might help you
  20. #295
    Dec 2012
    Bhc - thanks for that..
    Your links led me to being able to talk my LBS into ordering one in for me to try before I buy... 1/10 Mary here I come.....
  21. #296
    In my quest to build a SS 29er; I was able to find this brand new 2007 Haro Mary XC frame/fork in a friends basement. Built it up with the most reasonable components I could find for the price.
    Stans NoTubes Arch wheels with HD hubs (used)
    Schwalbe Racing Ralph's 2.4
    Raceface Evolve crankset
    Raceface Ride seatpost
    Charge Spoon saddle
    Sunline V1 bars (owned)
    Oury Brown grips
    Easton EA50 stem (owned)
    Hayes Stroker Trail brakes
    Ashima airotors
    32x18 gearing
    Manitou Tower Pro en route
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-harymaryxcss.jpg
  22. #297
    Dec 2012
    I just love my Mary, I ride it to work every day, 20km off road across Salisbury Plain each way....
    Resprayed powder coat, elixir brakes, Roval control wheelset, schwalbe tyres, carbon 600mm bars (big mistake, Easton monkeys on order). Brings this in under 26 pounds..
    Original stem, post, saddle and cranks....
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-image.jpg
  23. #298
    Dec 2012
    Quote Originally Posted by blb228 View Post
    I wish I had a friend with a basement full of goodies....
    Nice looking bike...
  24. #299
    Reputation: mrjustin007's Avatar
    Looking for an geared XL Mary frame & fork - PM me if you got one you don't need anymore.
    WTB: Bontrager Comp Fork & Syncros metal top cap
  25. #300
    Dec 2010
    Here's another one of mine
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1364256576.305596.jpg
