Results 1 to 3 of 3
    Reputation: toycrawler's Avatar
    Sep 2013
    FL fork upgrade ?
    I have a FL 29er with some decent upgrades. Been hitting the trails a lot harder and doing some mild down hill. I've maxed out the fork almost every time I go out. Would it be ok to put a longer fork on it? Looking at a 140 or 120 Fox. I know it will slightly change the geometry of the frame but the head angle is only 72deg.
    Ride in heat
    May 2012
    Any change in the head tube geometry will cause additional forces working on the steerer tube, which can be a reason for the head tube being ripped out its place. I'd suggest you contact Haro's support to consult what is the maximum suspension range you can use on that frame...
    Sep 2013
    Yeah. Good point, I'll give them a call.
  1. Fork Upgrade
    By NFLcheesehead1 in forum Beginner's Corner
    Last Post: 03-04-2013, 08:21 AM
  2. Tora 318 fork upgrade.. What to upgrade to?
    By chadalex78 in forum General Discussion
    Last Post: 02-08-2012, 08:42 PM
  3. 09 Specialized Pitch Fork Upgrade? Which Fork??
    By yellowpasta2000 in forum All Mountain
    Last Post: 05-17-2011, 01:51 PM
  4. Upgrade from 130 to 150 mm fork
    By bing! in forum General Discussion
    Last Post: 04-24-2011, 06:02 AM
  5. Fork Upgrade
    By seayakwc in forum General Discussion
    Last Post: 01-20-2011, 06:05 PM
