Results 1 to 2 of 2
    Whats the go? (Carbon force pro question)
    I have an 09 Carbon Force Pro frame that I bought and built up.
    When I got it there was nothing in the holes that the derailleur cables run through, so I
    have no idea whether they are meant too run a full length outer casing or the what looks too be alloy
    plugs in the holes are cable stops or just a guide for the outer cable.
    If anyone could let me know what the standard set up is I would appreciate it.
    Andy
    Reputation: nato_the_greato's Avatar
    Mine has plastic cable stops in the holes, but I generally prefer full-length housing for the standard shift housing.
    If you're using Nokon, then it'd make sense to use the cable stops.
    Former bike mechanic; current idiot.
