• 01-20-2013
    TAPnTX
    Servicing the new Idrive (2012 Sensor 9r
    I have looked everywhere and cant seem to find any docs of servicing the newer Idrive system. I am looking at buying one of these bikes and just wanted to see what it entailed to service the Idrive.
    Thanks,
    Todd
  • 01-21-2013
    Vespasianus
    This post might have some information:
    http://forums.mtbr.com/gt/i-drive-pi...ir-560521.html
  • 01-21-2013
    TAPnTX
    I have seen that, but it is the older System. The new one is totally different.
    Todd
  • 01-21-2013
    norcalchico
    Not much to it. Much easier than the older version.
  • 01-22-2013
    jennifer012904
    Which version of I-drive is on the newer bikes?
  • 01-22-2013
    TAPnTX
    The one that has the flush caps, also called Movie Reels.
    Like This
    Todd
  • 01-22-2013
    jennifer012904
    Like This
    Todd
    Yup that be the one.
  • 01-22-2013
    TAPnTX
    Awesome :thumbsup:
    Todd
  • 01-23-2013
    norcalchico
    Loosen the pinch bolts and the pivots will loosen with two Allen wrenches, sealed headset bearings are in the pivot areas. Not much to maintain.
    Tim
  • 01-28-2013
    Ashleydwsmith
    The problem I have doing this is getting the o rings circular again once put back if that makes sense.
    They sit on the bearing but cannot for the life of me get them round.
  • 01-28-2013
    jennifer012904
    Okay, the one with the reels on the side are completely sealed vs older design?
    Which model is the one with the movie reels? 5,6,7?
  • 01-28-2013
    jennifer012904
    Did you try a little grease to hold them in place?
  • 01-28-2013
    TAPnTX
    Thanks for all the info!!!
    When I take mine apart, I will document how to get it back in there properly. Imight have to make a tool :D
    Todd
  • 01-30-2013
    JACKL
    I just serviced mine yesterday on my 2012 Sensor 9r. I was getting a creaking/popping sound while pedaling. I found that the upper pivot had excessive play and tightening the "movie reels" (after loosening the pinch bolts of course) seemed to fix the issue. But I decided to go ahead and clean everything up.
    It was a pretty straightforward process of taking everything apart, cleaning, re-greasing, and putting everything back together.
    I disconnected the shock and the little bar that attaches next to the BB, so that when I was tightening the movie reels on each pivot, I could check to make sure that that I didn't go too tight and the pivot moved freely.
    It's nice to know that the new I-drive is this easy to maintain, and can be disassembled with nothing more than a set of allen wrenches.
  • 01-30-2013
    TAPnTX
    Thanks for posting about it JackL, I was thinking it did not look too difficult.
    Todd
