    Serial Number Location on 2010 Force 1.0?
    Not under the BB.
    Looking all around & dont see one.
    Black paint isnt helping.
    Anyone know where I should look?
    "Life is tough; it's tougher when you're stupid." -John Wayne
    It is absolutely under the bottom bracket. Sometimes the paint makes it very difficult to see.
    Wink
    Quote Originally Posted by zombinate View Post
    Sorry, "absolutely" not there.
    Thanks anyway though
    Actually, I found it.
    Would help if I wasn't so lazy & cleaned of some dirt first but it was ABOVE the BB & crank.
    It was on the rear/underside of bracket that the bb hangs off of.
    (Not sure what that pivot is called)
    Such a tight spot I can barely read the numbers.
    Had to get my phone in there to take pics so I could blow it up to read.
    I believe that's referred to as the main pivot. My 09 force had the serial number there too. Makes sense as that is part of the front triangle, as opposed to the linkages. Had to take pics from both sides to get the complete serial# though.
