• 12-03-2012
    gilhop
    Sensor 1.0 Pivot Overhaul Cost?
    In May I purchased a 2011 Sensor 1.0 and rode maybe 400 miles on it so far. I know it was probably premature but I wanted to get the pivots serviced just to make sure everything is in working order or if something needs to be replaced it is.
    I've already had the LBS do the work so all I'm wondering is if I need to learn to do this on my own for next time because of the cost. They ended up charging around $110 to get both pivots and the BB serviced and to replace the bearings in the pivots, is that what's usually expected for that kind of a job? Thanks, I'm new to the full suspension side of mountain biking so this is all a little confusing to me.
  • 12-21-2012
    tone22
    once you get used to doing it you can do it yourself in 10-15mins. i do my i-drive 5 once a month
  • 01-04-2013
    jennifer012904
    Are there any write ups on how to do it?
  • 01-05-2013
    Vespasianus
    This post might have some information:
    http://forums.mtbr.com/gt/i-drive-pi...ir-560521.html
  • 01-05-2013
    jennifer012904
    Awesome. Thanks
    I've got almost 200miles on my GT Sensor 9R 2012. This info will come in very handy.
