Results 1 to 3 of 3
    Mar 2013
    rigid fork for 96 gt karakoram?
    Hi.
    I have a '96 gt karakoram. Ripped off the orig gt rigid fork in 96 to put on rockshox. I foolishly tossed orig fork in a move 1o yrs ago. I broke the rocksox and plan to go back to rigid as i use for towing burley / weehoo.
    I was going to grab a surly 1x1, 80mm corrected, cheap and respected. I'm guessing this is close to stock?
    (1) Is this the right fork dimension wise to get?
    (2) I plan on grabbing a new headset too. Any suggestion on cheapos that would work well?
    All have 260mm steer tubes.
    80mm VERSIONS:
    Rake: 45mm
    Axle-To-Crown:
    413mm
    Weight, canti only: 1.01 kg (2.24 lbs)
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Quote Originally Posted by bwwbww View Post
    Hi.
    I have a '96 gt karakoram. Ripped off the orig fork in 96 to put on rockshox. I foolishly tossed orig fork in a move 1o yrs ago. I broke the rocksox and plan to go back to rigid as i use for towing burley / weehoo.
    80mm VERSIONS:
    Rake: 45mm
    Axle-To-Crown:
    413mm
    I have a '96 independent fabrications that i use with the Surly fork and it was designed around the same fork standard of that era. The 1x1 fork is set up to fit a bike that had between a 80-100mm fork (the standard fork travel for that era as I recall). It'll work fine.
    I prefer the Canecreek 40 headset for a combination of usability, durability and longevity. Good reasonable headset that is proven and could be transferred to a new bike if need be in the future.
    Try this: HTFU
    Mar 2013
    thanks Rockcrusher.
  1. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  2. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  3. Replies: 7
    Last Post: 09-30-2012, 04:09 PM
  4. Replies: 5
    Last Post: 11-27-2011, 05:18 PM
  5. Replies: 44
    Last Post: 10-03-2011, 07:48 AM
