Results 1 to 40 of 40
    Feb 2006
    Not a single post on the RTS??
    Sure it has a poor susp design but got GT into the full susp world. Just thinking if the all-alum models might be worth picking up as momentos or retros. Any tips, parts replacement problems, pics of sweet rides?
    Sneaker man
    Reputation: mik_git's Avatar
    hmmm yought there was plenty of post on RTS's, and they wern't a bad design they were actually pretty good and people still use them nowdays... and they won a world title 1st time anyone ever used one in a race
    Reputation: gm1230126's Avatar
    Search it....there's tons of posts here and if you wonder over to retrobike they are very common. There's even an RTS riders club/group post at retrobike. If you wade through the gallery in the first post you'll see some nice pictures of them.
    Keep in mind hammer. Per your profile you started mountain biking five years after the RTS first came out. It was designed with a specific purpose and that may not be what is needed or want today but at the time there wasn't much better to choose from. As with all new things change and improvements come faster. Which may make it seem to you like the RTS was a "poor susp design".
    Here's a great post from last year that talks about the RTS and GT's suspension designs in some detail.....it's well worth the read.
    http://forums.mtbr.com/showthread.ph...39774#poststop
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    Sneaker man
    hey gm, are you un-banned now? ...good
    Reputation: brettels's Avatar
    Gt Rts 2
    Here is a pic of my GT RTS 2.
    Owned since new (1995).
    Have changed the bike setup to a full XT Group set and Judy SL forks as the bike came standard with LX and Mag 21's.
    Complete bikes, frames and other parts show up occasionly for sale.
    I have a spare frame and shock to keep this one going.....
    Feb 2006
    Quote Originally Posted by brettels
    Sweet set up. Mine is also a '95, 16" frame. Now doing a rebuild but trying to not hurry. Found a Bomber fork with my preferred chrome lowers, which I think matches the ball burnished frame. Still love this Busby designed, semi-active, lock out linkage type. It's not a plush susp but running very little sag makes this a great climber, hardtail like. Will post pics later.
    Gt Rts
    Have changed the bike around since the last post....
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    I rode and raced my team RTS from 1996-2008 and if I could find a top section for my swingarm I would still be riding it today. That bike was just so much fun to ride.
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Dirt mag had a feature on the RTS as part of their "bikes that changed the face of DH" series in issue 82. Quite a good read, they noted that an RTS would "still be good fun even today" The bike pictured in the article belongs to a retrobike forum member. Thay also said "believe it or not this really was as good as it got back then" .
    Feb 2006
    Quote Originally Posted by Zoke2
    You raced the RTS for 12 years? XC? Any tips on set up? Topped out or with sag? What was the race weight? I'm putting on a 100 mm fork but will that jack up the geometry too much to affect handling?
    Gt Rts
    I have been riding and racing mine since 1995......
    Still keeps up with the more modern designs.
    Rear ends turn up occasionaly on ebay and the like for the RTS....
    As far as forks go, I wouldnt put anything above 80mm on the front as it will screw up the geomentry.
    The most I have had is 80mm with a set of Judy SL's with a long travel kit.
    Also check the rear Noleen shock to make sure its still got gas as I have two shocks running on just the spring which isnt ideal....
    Nov 2007
    "You raced the RTS for 12 years? XC? Any tips on set up? Topped out or with sag? What was the race weight? I'm putting on a 100 mm fork but will that jack up the geometry too much to affect handling?"
    yes I did ... and yes it was all XC ...my setup -1996 team RTS which was ink blue but I had it stripped and anodized red- wieghed in at 26 lbs ... I ran an 80mm Zoke Z2 fork with Ti springs and for the Noleen rear shock I changed the steel 450 lb spring for a Ti 500 lb spring and all the hardware for the shock mount and rocker arm were Ti ... I ran it with no sag and pretty stiff (lots of preload on the rear shock) It has an all XT drivetrain with a short cage RD and around 2001 I converted it over disc brakes (bb7) and Zoke Z5 air fork
    Keep it at 80mm at the max as this will stuff that geometry.
    Ran mine stiff as well with no sag.....
    Race weight, not to sure as Im not ione to worry about weight.....as long as it feels right.
    Generally ran mine with the Judy SL 9Long Travel Kit 80mm) and full XT Groupset (M737 and M739).
    Do you have any photos?
    Nov 2007
    the first pic is before the disc conversion and the second pic is after the disc conversion
    Gt Rts
    Nice looking bike.....
    I like the disc setup as well. Was it easy to convert the rear to disc?
    Im currently building another....will post some photos up at some stage...
    I'll keep an eye out for a rear end for you....they pop up now and again.
    Nov 2007
    I made a custom mount out of aluminum for the rear caliper ... because the bike has large flat dropouts I just made a mount and bolted it on but I have also used a A2Z adapter on it as well
    and if you can find a swingarm let me know ... i've been looking for a year
    Gt Rts
    Started on the 2nd RTS build.
    Images below:
    Frame
    Build so far
    With my other RTS
    Nov 2007
    looking good Brettels ... I had 2 at one time ... my first was a 93 RTS-2 that cracked the frame and GT replaced it with a Zaskar frame and the second one is the 96 team RTS in the pics I posted. seems like there are still a lot of them in the UK and AUS.
    Gt Rts 2
    Ok...here is the latest version, trying out different parts etc to come to the final makeup for both.
    Added some Manitou Blacks and my favourite saddle - Vetta SL.
    Will probaly end up with one RTS with Rockshox Mag 21's and cantilever brakes (period correct) and the other RTS with the Judy's.....
    Gt Rts 2
    Ok......settled on one RTS.....
    See image...
    Go SOLAR...
    Reputation: larlev's Avatar
    My roommate had a RTS-1. All I remember about that bike was that it weighed a ton. The rest of us rode stumpy HT's and he could plow through anything. Ah....the memories, no wife, kids, just beer and riding.
    "As Built", by me in 95. Frame number 06930161 was purchased late in 94 and it took six months to piece together, pay for, the rest of it. I saved some bucks by not going full XTR and then spent it elsewhere on the bike. I did do the XTR rear cog set and thought it was worth it. It has the TI replacement bolt set from GT for the frame. Big weight savings there. The only steel is the stearer tube. 26.2 lbs as shown. The rocker bearings are crunchy, not lose, but they need to be replaced. I blew up the Judy damper in about three weeks when it was new and replaced with a Risse damper and White Bros. springs. Way better setup. Yep, that's custom paint on the Judy. You can see red under some scratches.
    I just broke a finger off of one of the pawls in the Ringle rear hub. Bummer. Should have gone King.... I got a King in the front though. I've had it out a couple of times with only 5 of the 6 fingers in the rear hub. So far so good but I know it won’t last long.
    A new King built wheel for $500 or $1900 on a 2009 Force 2.0? I test drove the Force and love it. Kind of heavy from what I'm used to and I would really miss my 20 tooth up front. I digress…
    Museum piece?
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-100_2255a.jpg
    Reputation: ozpablo's Avatar
    Original One Owner
    Had my RTS-3 since early 1995. Used it for cross country racing and everyday riding all over Australia. Started our purple but it's gone through a few colour changes since then! It was my only bike until 2008... when I bought a Force 3... WOW! I thought the RTS was good but the Force 3 is awesome!!! Now the RTS is about to undergo a rebuild - transferring all the bits on my Force that I've upgraded over to the RTS. Just finished removing the old brake mounts from the rear triangle, ready for a respray and disc brakes (see pic). Next will be putting on the Marzocchi forks (with the travel wound right down). 15 years old and still going strong!!!!
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-scan0035.jpg
    GT Force 3 ('08) | GT i-Drive 4 2.0 ('06) | GT RTS 3 ('94)
    heres a pic of my RTS-3
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-rts-3.jpg
    Ride on!
    Iím waiting on my Noleen to come back from the shopÖ Canít wait. Itís the first time serviced since 95. I road hard for two years then I didnít ride too much after getting married and then a house. Heck, I still have the original tires on the bike.
    Whatís your RTS story?
    Currently unemployed, lost 25 lbs and ready to ride again!
    Bicycles, Bar-B-que and Beer. The best times Iíve ever had. Donít lose them!
    How much did it cost? The guy I bought it from said he hasn't done anything to the bike at all. any sugesstions, tune up maybe? so far i've replaced the derailuer hangar since it snapped on me and recently put some oury grips on it.
    $100. This includes return shipping as far as I know.
    https://j6shocks.com/uploads/Bservicerequest.pdf
    When I got my bike, the rear barely sagged when I sat on the bike. Coming from a hard tail, I loved the way it road.
    I recently have been getting back into shape and noticed that the rear sagged more than it used to. 15 years, what do you expect? Kind of springy. I tried adjusting the spring tension and was worried from GT instructions that said not to over tighten the preload. Then I raid another posters comment about the loss of the nitrogen charge in the Noleen. The Nitrogen charge is like the air in an air sprung shock. The Noleen is both air (nitrogen) and spring, not to mention oil dampened. Nice setup for sure.
    Teal 14.5" RTS
    Got my old one spruced up again. Original anodized frame (custom teal color) with Original Mag21s repainted using a new rattlecan "ano-look" paint. I need to touch up the anodized QR parts and pedals. Still lots of fun on technical trails.
    Now, I just need to get myself some retro Smoke and Dart tires. I wonder if you can still get gumwalls?
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-rts-side-bb.jpg
    I like it!
    Quote Originally Posted by GilroyGuy
    Have you got your shock back yet? I'm interested to hear what it's like after the service.
    Is your shock the piggy back Noleen (NR3) or just the standard one (NR1)?
    I got the Noleen back and I'm waiting on the Risse for the front. It should be here by Friday. Dam this seems like forever.
    Turns out that Noleen $100 didn't include the shipping, so the total was $112. The unit looks good and I think the spring is preloaded a bit tighter than I had it, but not shure. Noleen wants to know your weight and riding style before servicing, so I'm going to try it has is and see what happens. I think it's going to be a winner.
    Hey Oz, put some pics up when you have it back together. I'm interested in the rear disk mod.
    You did a nice job getting rid of the old break posts.
    RTS + Disc Brakes
    I've been slack!! Haven't done much more since the last pics. (too busy riding before the wet winter weather sets in!) I've slightly modded the A2Z disc mount to fit the cromoly rear end of the RTS... all it took was some careful filing of the A2Z bracket to change the shape slightly and some smoothing around the RTS dropouts to provide a flat clamping area. The pics show the rear triangle with my GT Force 3 wheel with 185mm Avid rotors... I'll only use my old 160mm rotors on the finished job. I was just checking to see the disc had plenty of clearance. As you can, see the rear triangle needs a bit more sanding and repainting before it's all done. I also just found a crack in the main frame bottom bracket pivot where the shock wishbone mounts - bugger!!! Oh well, now that winters starting to set in, I'll probably get back to work on it so it's all ready for Spring!
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-img_0227.jpg
    RTS Update
    Finally got my act together and have sent off cracked main frame for repair... frame repair gurus down here in Oz reckon they can fix it!! Plus, they're also going to bead blast frame and powder coat the frame in Flame Red. I'll post a pic when I get the frame back.
    how screwed am I? I noticed this crack when I was changing the rear tire, would I be able to weld it myself? And would it be a bad idea to continue riding my bike even if it was just on paved roads?
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-0818001307.jpg
    RTS Rebuild Update
    Finally got my powder coated main frame back and the old RTS is almost finished! Just need a front derailleur to get it back on the trails. Drilled larger holes in frame cable mounts to allow full length gear cable housing. Finished fitting discs. (One day I'll get around to bleeding the Tektro brakes and run the hydraulic cables through the frame cable mounts as well). Marzocchis fitted... but need to wind down travel as they look a bit too high for the frame!!!
    Attached Thumbnails Attached Thumbnails Not a single post on the RTS??-gt-rts3-updated-1.jpg
    Very Cool! A new bike! Love the disc breaks.
    I Love the RTS, i've put together an rts 3, i'll try to post a picture of it... http://twitpic.com/23odit
    I just was givan a RTS-2 1996 I think. I'm having the worst time finding some info on how to remove the old bearings from the rear suspention rocker.Ive tried using a press with no luck. Just wondering if any of you all have done this job before and could lead me in the right direction. So far I think the bearings a seazed in the rocker and I might have too try and find a different one. Any help would greatly be appreciated.
    Reputation: zonoskar's Avatar
    This is my RTS 1 or team. Since I got the frame with no decals and no components, I don't know. It was manufactured 06-1993.
