Results 1 to 2 of 2
    the mono shock flange weld on IDxc 4.0 2005
    I have an ID XC 4.0 2005 Below is a rough top view of the part in question.
    My first frame cracked on the mono shock weld that connects to the down tube.
    crack was on the perpendicular weld >> right here >>>>>> --------------
    | d |
    | o | parallel welds>>>>>
    | w |
    | n |
    T
    U
    B
    E
    What I want to know:
    It seems as if the weld on my new frame as well as the old frame does not cover the seam.
    In other words it is only on the mono shock flange and not any of the weld connects to the down tube of the frame as if it missed its mark. I suppose a pic would better explain but I am wondering if this is the correct spot for the weld.
    I ask because I am seeing paint crack right on the seam much the same as my last frame did befor it cracked.
    Awesome not Rad
    Reputation: farmerjohn's Avatar
    Lets see a picture....
