Results 1 to 2 of 2
    Reputation: SocalMXer88's Avatar
    Loose rear wheel
    I have a 2009 Force 3.0, and noticed the rear wheel has some free play. I checked all bolts on the rear of the bike and re-tightened the axle, and it still moves a little. It appears to move horizontally, and something is loose or worn out around the hub or bearings...its not the spokes or swing arm. What could be causing this problem?
    GT Force three point zero
    May the Force be with you
    Reputation: norcalchico's Avatar
    I would take your rear wheel into a shop and have them re-tighten the axel. I had the same issue before. What hubs are they?
