Results 1 to 11 of 11
    Shred all that can be
    Reputation: sickspeed16's Avatar
    Just In! 09 Sanction Frameset!
    just came off the truck.. and MAN is it beautiful... two things that worry me, the rear maxle does not go in easily due to a slightly offset axle path (it squeaks alot when I'm screwing it in and has left marks on the maxle on the lever side.) and the second not so much, looking down the HT there are a few burrs from where the downtube and toptube connect.. should I file them down or is it not needed? Pics will be up soon.
    "This sticker is dangerous and inconvienent, but I do love Fig Newtons"
    Reputation: nato_the_greato's Avatar
    I wouldn't worry too much about either, unless it's actually impairing function. If you can post a picture, I'd like to see how far off the axle path really is. It may have been damaged in shipping, or it may just be a manufacturing error. It's probably within tolerances and is probably not a safety issue.
    I'd only file down the burrs if they interfere with the steer tube on your fork.
    Pics:
    So here are the pics, I also found this small hole see pics that I'm not sure I should be worried about or not.. any info would be great...
    The frame!
    The Maxle
    The hole
    Ok nevermind I don't have pictures then.
    Ok so thats the hole.
    and here is the Maxle
    That hole is a bit worrisome. I don't think it'll fail catastrophically, but it does say "this weld wasn't made properly." If it were my bike, I'd be thinking about a warranty at this point.
    Training wheels ON
    Jan 2009
    Quote Originally Posted by nato_the_greato
    x2. It should be sent back. You'll be saving yourself headaches and time.
    On the maxxle, you should try and loosen up the replaceable dropouts. It may just be a slight missalignment that could be causing that. If you are really iffy about the hole, then send it back. I personally wouldn't because it is pretty tiny. I'd get something to plug it though. I would send it back because you may have 3 different issues including the burrs. If the maxxle never lines up properly you may have disc brake issues as well. Your whole tire will be out of alignment and that to me is a bigger issue than the hole.
    Still loving my GT's!! find me on the "GT Bike Group" page on FB. I hardly ever hang out in here anymore.
    Maxxle problem was solved with a little emry cloth and I'm not worried about the weld so yeah, thanks for the help guys.
    Nov 2008
    Where did you bought the frameset?
