Results 1 to 39 of 39
    slo65
    Guest
    i-drive creak creak creak
    i know these bikes are notorious for it, but is there anyway to get rid of it? i'm tired of people asking about it on group rides , my bike is an 06 i-drive 5 4.0 (say that 5x's fast), i love the bike aside from the creak, is it the bottom bracket? i had the bike tuned up recently at a shop, works great aside from that nasty creak. i tried searching, but didn't find much, thanks in advance
    Vita brevis
    Reputation: rustus's Avatar
    Might be a bottom bracket. If it is, you can fix it yourself if you have the tools, or take it to an LBS and whatch them do it. All you need to do is remove the crank arms, clean and lightly grease the spindle and crank arm interface, reinstall the arms and torque down to proper specs. I don't know the torque numbers right off hand, but a quick net search should turn them up. If your creak is the bb, this should fix it.
    Reputation: JeffSpicoli's Avatar
    I feel your pain...My '06 I-Drive just started creaking when pumping hard or on uphills....It's pretty annoying ; so consensus is bottom bracket? Or maybe the pivots?... Any feedback on this is appreciated...
    slo65
    Guest
    Quote Originally Posted by JeffSpicoli
    yea it's a loud creak, it's annoying when hammering down on some uphills i'll wait for a couple more people to chime in, the bike's due for a good cleaning but regardless the last time it was cleaned/tuned the noise was still there
    Vita brevis
    My '04 I-drive has never had the eccentric rebuilt and does not creak. The bottom bracket has, however, needed to be serviced a couple of times. I would check the bb first, it is easier to deal with than the I-drive mech. Good luck.
    May the Force be with you
    Reputation: norcalchico's Avatar
    I've had that prob also. What you need to do is take part the i drive assembly with a shimano BB tool. Clean and re-grease the bearings. Do not skimp on the grease. Tighten nice and tight. That should fix the noise. There is a video ( at least there was ) on GT's web site showing how to service the i drive on the 05 and new bikes.04 if it's the second generation i drive.
    Good luck.
    Caution;  Merge;  Workers Ahead! remove, clean, lube and reinstall the dropouts !
    One of the main areas my 2007 ID5 1.0 creaks is at the dropouts..sounds crazy but it turned out to be true...I called the guys at customer service and they tipped me off to the fact that even though it SOUNDS like its coming from the BB it can be the dropouts....they were initially not lubed correctly (or at all for that matter) at the assembly factory ...I guess they fixed this oversight....anyway I did it, pulled the d-outs off of the swingarm, cleaned them and then lubed both the swingarm and the d-outs with phil wood, lubed the bolts, put it all back together and it worked.....as far as the main pivot or the BB link pivot they said that it was most likely the BB pivot that was cuasing the creak and that slathering the bearings and cones in anti-sieze will quiet that area.....
    love the bike ...hate the creak......but no creak for the last 20 hours of riding....
    Glad to hear it worked.
    slo65
    Guest
    Quote Originally Posted by dirtstar59
    call me an idiot but any pics? i'm not sure exactly what you mean (still kinda new at the mech side of riding)
    Oct 2007
    the drop outs are the thing that hold your wheel to the frame.. the little slotted metal pieces on the rear most end.
    slo65
    Guest
    thanks guys i'll give it a try, like you said i really like how the bike performs but it's downright embarrassing when on group rides
    Self Appointed Judge&Jury
    Oct 2000
    Often times a creak will form as a result from riding through a creek.
    Seriously though I used to get a creaking sound from my old school I-drive. I found that the plastic / rubber sleeve at the shock bolt upper and lower was the culprit. I simply sprayed them with silicone occasionally and it solved the problem.
    I've had 3 creaks on my i-drive 2.0. The first was the chain ring bolts (Truvativ Stylo). The 2nd stopped after I replaced the dog-bone, which snapped on a night ride (I assumed that it may have been slightly damaged, and that caused the creaking sound). The third time was the chain ring bolts again. Whenever I get creaking I give the chainring bolts a bit of a tighten before I disassemble the main pivot just to prove I am on the right track, and so far I am 2 for 3.
    Grease the BB-Link Pivot
    Quote Originally Posted by slo65
    Just bought a 2006 GT i-Drvie 5 4.0 off e-Bay. Creaked like mad whenever peddling. Long story short, I replaced the bottom bracket and crankset and still had the creak! Took it all apart again and this time took off the BB-Link Pivot...greased the hell out of everything and used teflon tape on all threads. Also greased the seat post, dropouts, and derailleur hanger. No more creaking with about 20 miles of road and trail riding so far. I think it was the BB-Link Pivot. You'll need 3 special tools for this...
    One to get the crank arms off
    One for the BB (BBT-18 I think)
    One for the BB-Link pivot
    FWIW...I'm a rookie and found these repairs quite easy. Good luck!
    - Ed
    My CREAK is solved! (For now anyways*fingers crossed")..ReretteK is in right direction with the possible solution...BB Link Pivot Lube-Fest/New Crankset/New BB+ginormous amounts of Lube/Grease=No creaking.....When took off old crankset, it was practically bone dry and old BB was kind of beat up....Hope this helps
    Go here
    http://www.gtbicycles.com/usa/eng/manuals
    and get the I-drive manual and supplement. They explain the maintenance pretty good and have exploded views.
    A good cleaning, greasing and proper tightening of the pivots fixed mine too.
    slo65
    Guest
    looks like i have some tools to buy, thanks guys
    Awesome not Rad
    Reputation: farmerjohn's Avatar
    Also grease the bolts on BOTH replaceable drop-outs... I had an iDrive 5 that was creaking, rebuilt all the pivots (heavier grease the better) and then that it was the replaceable dro-outs. I removed them, greased the bolts and the interface and it fixed it
    haha- i got an 2007 i-drive 4.0 a few months ago and i am getting the creaking when pedalling; i called performance and their techs are backlogged about a month so i am gonna have a look myself....we had quite a few floods out here in northern IL, so i think it might be the bottom bracket that needs greasing, but will check out all the other parts also.
    thanks!
    Oct 2000
    Quote Originally Posted by Bruce372
    thanks!
    A real dilemma:
    so yes, it seems its the pivot and not the bottom bracket....i did that first and it still creaked...then i did the two pivots and all was good. i didnt like working on those soft alumunium pivots though....i am too used to dealing with MX bikes where everything needs to be tigned down firmly!!!
    thanks everyone.
    I had a horrible creaking noise from my new Force 3.0 everytime I would pedal hard. Turned out to be the bolts that go through the suspension pivots were loose.
    Wanted to add some info in the interest of helping others if they have this problem. After thinking I had fixed the creaking noise, it returned in full force. After dissasembling and cleaning everything in the suspension and BB, it appears that a lack of grease in and around the bearings on the suspension pivots were at fault. There was a decent amount of grease on the actual bearing but the race area and the sides and exterior were all lacking. A generous application of grease and there isn't a creak to be found under any condition. Finally!
    It was tricky- the creak would come and go with every tightening and greasing. It was especially bad when applying a side load on the pedals and while pedaling. I just hope that i got it for good this time!
    underestimate me
    Reputation: untoco's Avatar
    But it's still creaking:
    i-drive5'07.
    Reassembling BB link and change bearings help but for 2 months. Now it's creaking while pedaling hard and I've reassembled and regreased BB ling again with no success. Trying to remove dogbone for grease but already almost broke lower bolt.
    I'll try to check dropouts but I'm not sure of them as noise generators...
    May be someone till now already has success stories about creaking? (except describing below).
    "We do not stop playing because we are old; we grow old because we stop playing."
    RE- tight
    Quote Originally Posted by untoco
    i-drive5'07.
    Try to re-tighten the i drive linkage. That helped me.
    i-drive5'07.
    Did you try to teflon tape (plumbers tape) on all the threads? Also - make sure you do not over tighten.
    Ed
    rookie rider / rookie mechanic with a 2006 GT i-Drive 5 4.0
    underestimate me
    Quote Originally Posted by norcalchico
    thanx for reply, but unfortunately it did not helped. I've also regreased dropouts but with same success (mean zero luck).
    underestimate me
    reretteK, i've never heard about this tape on threads in bike. Is it some kind of grease instead of normal one?
    BTW, I can't even understand what can creaking in linkage (I'm pretty sure it's a frame - I've changed system and BB to another and still the same). Is it dogbone, or pivot in BB link, or pivot in swingarm? If I'll find it can greatly help to prevent this annoying noise.
    Thanks 2 all for your respective replies which will help me - I'm sure.
    And I still love my ID for it riding feeling.
    x2 on the teflon tape. When I had mine apart, I taped and loc-tited everything possible.
    i used copper impregnated antiseize assembly type grease on all the linkage, dropouts hanger etc.
    be careful using teflon tape on threads, the alum threads can be soft and using tape might cause you to mess up a thread.
    slo65
    Guest
    Quote Originally Posted by tomsmoto
    so the id5 has those plastic removable dropouts, removed them and greased them with some lithium grease (is that ok to use?) took care of the creak, to an extent, it's 90% better.. but towards the end of my first ride it was creaking a little again, any recommendations for a good grease that will last a bit longer?
    underestimate me
    plastic? on my id5 they definitely metal.
    and my creaking was from pivots not from dropouts.
    slo65
    Guest
    i-drive5'07.
    whoops, thought i updated this thread, my creak was very loud and got worse as time went by. sounded like it was coming from the BB, ended up being the rear dropouts like someone mentioned, removed the dropouts greased them all up with some multipurpose lithium grease, creak went away, couple rides later came back very faintly, greased them again and it went away.. can anyone recommend a better type of grease? something that holds up longer
    back on the horse
    Reputation: baconrocket's Avatar
    my lazy streak comes out and i just toss some 90 weight gear oil all over everything. creak goes away for a while.
    I have an old idrive. 99 xcr2000 that used to creak really bad. After rebuilding everything except the shock I still had the creak. After rebuilding the shock-new plastic inner slider thing and new grease-the creak is gone!! Grease the shock pivots and make sure they are not too tight. After about 6 months the creak may return but that just means it's time to take apart the shock again and lube it up good. That is my experience with the idrive creak. Hope it helps.
    Z.
    ... and if we just ...
    Quote Originally Posted by zracing
    Z.
    I agree totally mine is the same re build the i drive on a regular basis too i like tinkering the day after a long ride re grease everything and put it all back togrther
    My tomac gets the same treatment too but never creaks lo l
    Quote Originally Posted by Jon82
    I agree. My point was that rebuilding the I-drive didn't solve the 'creak' for me. Rebuilding the shock did!!
    Reputation: jscusmcvet's Avatar
    Following the easiest of the advice I read on this board, I am not hitting my pivots with 90 weight oil (I had some for my jeep differentials) without even taking them apart, just letting it soak in around the joint... Creak disappeared...
    On One Summer Season Single Speed
    Pocket Pool Savant
    Reputation: mcseforsale's Avatar
    Just for fun...I'll add. I've been chasing down a mild creak (actually, more like a crackle) on my '01 iDrive 4.0 for a couple of years now. The noise is not very loud, but it is a squeeky crackly creak every time I put pressure on the left non-drive side crank arm. Kinda like a quick "chirpchirpchirp" around the bottom half of the pedal stroke.
    This bike probably has almost 5000 miles on it and has been very well maintained. In fact, I have people every week asking me if this is GT's "new" bike because a.) it's so old and b.) it looks so new. The bike has been washed after every few rides (or unless it's dirty/muddy) and all bearings have been repacked with fresh grease every month of use or so. So, needless to say, with my anal-retentive maintenance...a creak drives me frickin' insane.
    Started with the regular maintenance tasks...took apart eccentric, replaced eccentric bearings/races, etc. Lubed up main pivot. Found the derailleur hanger loose (I thought this was the problem until the first ride after fixing it), replaced pedals. I'm still running a square taper BB, examined that, checked seatpost, stem, seat rails. Checked the freehub body on my American Classic disc hub....spoke tension, etc, etc.
    So, fearing the worse...a frame crack, I finally put the bike down on it's drive side and started pushing on the left crank arm, while checking all welds and listenting for the area of the creak. I looked and looked and finally found the issue. The non-drive side bearing cup for the i-Drive eccentric is moving ever so slightly in the bottom bracket shell of the frame. This explains why it has been so sporadic...it's because when I wash the bike, the creak gets some lubrication from the water and soap and it takes awhile to go away.
    So, I took the eccentric apart, lubed the bearing cups and re-installed them. Problem solved. I will add this to my yearly maintenance (which is quite extensive) and will now know where the creak comes from.
    Sorry to Crank Brothers for sending my "creaking pedals" back (although, thanks for the free rebuild), American Classic for buggin' you on the phone about my "creaking rear disc hub" and GT for bugging you, too.
    HAHAHAHA!
    Thanks,
    AJ
    "Stop smirking. It's irritating" - Judge Judy
