    Reputation: dorongr's Avatar
    I-Drive 5 2006 geometry
    Hi,
    I've been trying to find the geo specs for those frames, but can't seem to find them...
    Does anyone know where to find them? I need to compare them to another bike to find the differences...
    Reputation: cmarshack's Avatar
    New design for 06
    5" travel Fox Float RP3 shock, 7.25/1.75 standard length
    Hydroformed down tube with integrated headset(not included)
    GT I Drive 5 1.0 Geometry
    Size H angle S angle T angle HTL TTL STL STL (top) Drop BBH TTH FC Rake CSL Whl Base Hor TTL TT slope wrad TTD LL
    S 69.5 73.0 91.2 100 535.7 380.0 450.0 -5.73 339.7 760.8 641.7 39 432.33 1073.94 560.00 18.2 334 40 518
    M 69.5 73.0 88.9 110 559.6 404.4 474.4 -5.92 339.9 781.0 668.9 39 430.78 1099.56 585.00 15.9 334 40 518
    L 69.5 73.0 88.9 130 573.9 419.0 489.0 -6.06 340.1 796.4 686.1 39 429.82 1115.82 600.01 15.9 334 40 518
    Geometry measured at topout full extension
    31.6mm Seatpost
    Sorry, can't get it to come out right after the post. The chart looks fine before I post it then gets out of whack after. Oh well, if you count fromleft to right you should be able to get the # you are looking for ie: bottom bracket hieght is 9 from the left.
    Where did you find the chart? I can't seem to find anything even close to GT's geometry on thw web...
    Reputation: ocguy2004's Avatar
    Quote Originally Posted by dorongr
    i put this together from different sources...some from gt website...other from an lbs site.
    hope it helps.
    Attached Files Attached Files
