Results 1 to 3 of 3
    Aug 2013
    HELP! 2010 GT Sensor 2.0
    Hey guys,
    Hoping someone out there can help out this newbie. I recently bought a '10 GT Sensor 2.0 on ebay and the guy shipped me a strange bag of miscellaneous parts that apparently are for mounting the front wheel since the rest of the bike is properly assembled. The parts I have left are two 15mm bearings, a thin 15mm ring, a black dust-cap/spacer thing, and of course the 15mm thru-axle. He gave me some complicated instructions for mounting the wheel but it just doesn't line up properly, not to mention there is still wiggle room along the axle when it is fully threaded and locked. LBS confirmed my suspicions and thought there should be two of the black caps, one for each side of the wheel.
    So please, if anyone has or had this bike could you tell me how your bike came as far as parts on the front wheel required for mounting. Also if you wouldn't mind, some close up pictures would be a huge help.
    Thank you in advance!
    -Josh
    Attached Thumbnails Attached Thumbnails HELP! 2010 GT Sensor 2.0-1226768_10151671693352858_1935155271_o.jpg
    CT3
    CT3 is offline
    Hoodwink
    Reputation: CT3's Avatar
    May 2010
    tried to respond to your pm on my phone that didnt work out. that looks the be the bearings from the from the front wheel, and the dust cover/spacer for them. i took pics last night but it seems they didnt save on my phone nor did the pm send. Ill take them again tonight. if there is only one cap, then yes you are missing one.
    Aug 2013
    Thanks a lot for the response. After much frustration the seller was finally able to explain to me how to mount the wheel with those parts. Seems to be rolling fine now, my only concern being dust and dirt making its way into the bearings since one side does not have a cap. Crossing my fingers that I can obtain one from GT...
  1. PLEASE HELP! 2010 GT Sensor 2.0
    By NH.mtb in forum Bike and Frame discussion
    Last Post: 03-16-2014, 01:12 PM
  2. Paid Spam: 2010 GT Sensor 9'r
    By nshadow in forum 29er Bikes
    Last Post: 11-23-2011, 02:02 PM
  3. 2010 GTw Sensor Frame Geometry
    By jeffj in forum GT
    Last Post: 07-14-2011, 02:54 PM
  4. My "new" 2010 Sensor 3.0
    By ak57 in forum GT
    Last Post: 06-27-2011, 06:12 PM
