Page 36 of 36 FirstFirst ... 26 32 33 34 35 36
Results 876 to 884 of 884
  1. #876
    I think my next step is to contact a GT dealer tomorrow and hope that they can order the part for me. I'm in Roanoke, VA, and they have a dealer in Lewisburg, WV, which is more or less on the way to Snowshoe, where my son is racing downhill next weekend.
  2. #877
    Feb 2014
    You can also try McMaster Carr- they have a huge assortment of fasteners and are reasonably priced. We use them for a supplier where I work.
    McMaster-Carr
  3. #878
    Quote Originally Posted by 153stars View Post
    By looking at those the threaded end is smaller than shank to get one non OEM best bet to get one much longer shank and have machined and threaded, the socket head is shorter normal as well. OEM or machine shop , machinist or BETD in UK probably only option. Good luck get spares.Find dealer
    Store Locator Fury looks same they will know GT Fury Spares : Mountain bikes and componets by BETD Goldtec
    in black steel Metric shoulder bolts, Allen, Class 12.9 steel black oil finish - Bolt Depot They are called shoulder bolts Shoulder Screws & Stripper Bolts | MSCDirect.com I think they are M6 x M5 .80 pitch then you need the shank length I am sure you can get them get it all measured up and start google
    Thanks for the links! Those Bolt Depot bolts and the GT Fury Bolts look like they would work.
  4. #879
    Quote Originally Posted by hishalls View Post
    McMaster-Carr
    I ended up going with McMaster:
    McMaster-Carr
    Here are the original and new shoulder screws (which are black and silver):
    Just got them in the mail today and they fit! The hex wrench size is 3mm instead of 4mm, which is fine.
    They were $1.37 each (I ordered 4) and 2 day shipping was $7.39, from Georgia to Virginia.
    Thanks hishalls!
  5. #880
    Here is the gif from McMaster, with dimensions:
    GT Sanction and Force reference thread-alloy-steel-shoulder-screw-diagram.gif
  6. #881
    I am having a very hard time getting the bolts out from the dog bone and was wondering if anyone had any tips. Just soaked them in PB Blaster.
    Edit-After repeated soakings in PB Blaster I put the heat gun to it and was able to break it free. No cross threads, just some very effective loctite.
  7. #882
    Crack in rear triangle
    I have noticed a crack in my 2009 Force frame that was purchased in 2010. Has anyone had any good/bad experiences with GT? Should I be optimistic or am I SOL???
    Attached Thumbnails Attached Thumbnails GT Sanction and Force reference thread-0307151633.jpg
  8. #883
    I haven't had any major issues with my 2008 and it's got over 4000mi on it. I would just take that over to a welder and he'll patch it up good as new. They are still some of the best bikes for the money. Frames are made overseas though so that's the thing we have to accept when paying less. Still love my bike though!
  9. #884
    Feb 2014
    Yes, it is a common problem, I had similar cracking problem, and some other GT Sanction owners as well. Try to get a new one from the GT through your LBS, or try to contact Taiwanese Ebay sellers, if you are lucky enough you may get a new triangle with a low price.
