Results 1 to 2 of 2
    Reputation: katsooba's Avatar
    Nov 2008
    GT Ruckus 2012 I2I shock size?
    Hi guys,
    i have a GT RUCKUS with the fox RP2 BV shock , and wanted to know what is the I2I size of this shock and what is the recommended coil shock for this frame
    thanks!
    17' Canfield Jedi 27.5" - The fast just got faster!
    15' Canfield Balance - The go to guy of the bike world!
    Reputation: winter's Avatar
    I don't believe GT makes a full suspension Ruckus for 2012. Even if they did, GT seems to be moving away from Fox products and toward Rock Shox and Marzocchi products. Are you sure your Ruckus is a 2012 model? According to GT's website, the only 2012 Ruckus is a hardtail.
    The 2011 Ruckus (looks very similar to the 2012 Fury) used a 8.5 inch eye-to-eye 2.5 inch travel rear shock.
    The previous generation Ruckus (also known as I-drive 7) was made in 2006 and 2007 and used an 8.75 inch eye-to-eye length 2.75 inch travel rear shock.
    The shock hardware for 2011, 2006, (and I assume for 2007 as well) were 22mm width with 8mm bores on both ends of the shocks. I use Fox DHX4 coil on both my 2006 and 2011 Ruckuses without problems. Hope this helps.
    Go on ahead, I'm gonna take a breather.
