Page 7 of 7 FirstFirst ... 34567
Results 601 to 656 of 656
Thread: GT Grade
  1. #601
    West Chester, PA
    Had to re-tape my grails yesterday. Pulled the tires off to remove a giant Stan's booger in each one, and the beads ripped up the edges of my tape pretty bad. What a freakin PITA. That center channel makes it real hard to get the tape in there while trying to stretch it. These rims were a nice intro to the wonders of road tubeless, but I'm definitely not going to miss them when they're gone.
  2. #602
    Nov 2008
    The moment when you just can't remember why you took the fenders off...
    At least it was fun.
  3. #603
    Apr 2016
    Drove up to the North Cascades Highway on Friday. 41 miles with about 3,800 feet of vert. All paved.
    This was the turn-around point. This is why they close the road.
    Scenery.
    And then the way out.
  4. #604
    Aug 2010
    Looks like an amazing ride! Thanks for sharing the pics!
  5. #605
    Quote Originally Posted by 92gli View Post
    The same thing happened to me last week. In between trying to get the Kenda Happy Medium SCT's to seat (horrible experiencie, btw) and my undiscriminated usage of my plastic levers I ended up busting my rim tape. I also found out that using high pressure (> 45 psi's) on these builds is not recommended.
    I'll retape them again next week and will be extra careful with the pressure and levers.
    ps. the new Maxxis Terrane 33mm might be a better alternative to the hard-to-seat Kenda Happy Medium's.
  6. #606
    West Chester, PA
    Quote Originally Posted by dekaru View Post
    I can't get the rear wheel to seal. I thought it was good but there's sealant coming through a few spoke holes. I must have screwed the tape up again. I think I'm going to solve the annoyance the best way possible- throw money at it. Mavic ksyrium wheels are calling me. No holes to tape.
  7. #607
    Give the Hunt wheels a try, excelent value (and looks!) for the money
    https://www.huntbikewheels.com
  8. #608
    Last week I finally decided to go road tubeless with my grail rims, using stan's tape and schwalbe pro one tires. Had the exact same problem you described. Getting the wheel on caused the tape to get messed up and leak through spoke holes.
    After 2 attempts, i grabbed some gorilla tape, cut it to 21mm and slapped it on (1 layer). The tape went on perfectly smooth on the rim and the schwalbe's seated up on my first attempt after that. Ditch the stan's if that's what you're using.
  9. #609
    West Chester, PA
    I'd consider waiting for their wheels if I was going to get carbon, but wouldn't wait on them for alloy. There's nothing that special about them.
    Quote Originally Posted by fumanju View Post
    I got a roll of wider tape and it seems to be working better. It's 25mm. Goes up the bead shelf a little bit.
    Even though I fixed the issue, I still made an impulse purchase. DT spline R32 wheels are on the way from Germany. Price was too good to resist. They need tape too, but I went for the looks and like how the hubs convert to every axle standard out there.
  10. #610
    Reputation: sml-2727's Avatar
    Nov 2013
    Well I went out for a road ride today and looking at mountain bike trails I decided to try a little off road, now I had the tires pumped up to 100psi with the stock mostly slick tires and actually did a lot better than I thought it would, Now the one thing I do hate about road type bikes is drop bars...what would it take for me to go to a flat bar? Im thinking probably everything (brakes/levers/shifter...etc)
    2018 Spot Mayhem
    2016 Salsa Bucksaw
    2016 GT Grade Carbon
  11. #611
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by sml-2727 View Post
    And a longer stem, because you won't have the length the bars add.
  12. #612
    West Chester, PA
    Got rid of that crap formula front axle and switched to a maxle stealth. So much nicer looking and it doesn't sound like a zipper when you insert it. Have to carry a 6mm in the saddle bag now though. Have a DT RWS rear skewer but would like to find something less bulky for that too. With tubeless, I rarely have to remove the wheels these days...
  13. #613
    Reputation: cbj2012's Avatar
    The Maxle fits that is pretty cool to know. That much look so much nicer too.
  14. #614
    West Chester, PA
    Yep. They have a maxle stealth road version that matches length and threads perfectly.GT Grade-img_20170411_171528.jpg
  15. #615
    Reputation: steelcityadv's Avatar
    Dec 2015
    Sent from my SM-G900V using Tapatalk
  16. #616
    Nov 2008
    In case someone was wondering about framebags. Here is a Blackburn Outpost (Medium) in a 2016 55cm frame. That's is a spare toob between the seattube and the framebag. Good bang for the buck.
  17. #617
    Aug 2010
    Well, I did a complete dipshit thing last night. Bunny hopping a railroad tie in small chain ring/small cog on a dirt road the chain popped off and wedged between the chainring and the chainstay. It chewed up the chainstay a bit - not terrible, but took a little chunk out. Anyone else on a carbon Grade have a similar occurrence? It looks like the top layer of carbon is pretty much decorative, and there doesn't seem to be damage below that.
  18. #618
    Dec 2015
    Some Grades
  19. #619
    West Chester, PA
    Finally got my DT Spline R32 wheels from Germany. Damn these things are mean lookin. And so nice that they come with every hub adapter possible. Also recently got ergon saddles for all my bikes. Love them! Not much left of my original bike... just the cranks, FD, post, brakes and brifters.
  20. #620
    Finally got my DT Spline R32 wheels from Germany. Damn these things are mean lookin. And so nice that they come with every possible hub adapter possible. Also recently got ergon saddles for all my bikes. Love them! Not much left of my original bike... just the cranks, FD, post, brakes and brifters.
    super nice! what size is it?
  21. #621
    West Chester, PA
    53...
  22. #622
    53...
    If you ever decide to sell it or if you wish to change it for another one size larger let me know :P
  23. #623
    West Chester, PA
    My local performance store has the 2016 105 carbon on sale for $1800. The one that has the green stripes. They have several sizes, 53 and whatever xl is. This version isn't shown on their website anymore but the manager said tbey have a good amount still in their system. They're doing an extra 15% off this weekend too. You would be under 1600 with this deal 😱
  24. #624
    wow, sounds great! i'll check it out, thanks! i did not particularly like the green version of the 105. I have the 55 black/white version but it's a bit too big for me. I like the bike so much I'm seriously considering buying the same model just to get the right size (bought it online) ... I'm 5'9 and had to swap for a 90mm stem and push the saddle almost all the way to the front. I am flexible but I don't enjoy a slammed body position.
    Nov 2008
    Finally I got my hands on the Easton EC70AX bar. One nice thing about the bar is the coarse surface for the stem attachment. I'm not an expert on carbon bars but haven't seen that on any other carbon bars, road or mtb. I still put some carbon paste during assembly, just in case.
    Weighed in at 220g vs 312g of the original Al bar.
    I was waiting to get the same bar as the GT original but in carbon. Actually the Easton is a little bit narrower at the drop ends.
    The bends are actually quite different. I like the Easton better, I have always had a slight feeling that my hands are slipping down on the GT bars. Also I was able to setup the brifters so that it's easier to reach the brakes.
    Waiting for a test ride to be done.
  26. #626
    May 2017
    Speaking of handlebars... removing the bar tape from the "GT Droptune RS Ultra Light" on my GT Grade Ultegra 2014, I found the designation "RA68A.2 440" etched into the bar end.
    This hints that the original bar would be a rebranded TranzX JD-RA68A.2 made in Taiwan. The TranzX PDF catalogs list the following specs:
    Material: Alloy #2014-T6 DB
    Center: 31.8mm/120mm
    Reach (C-C): 70mm
    Drop (C-C): 120mm (360/380/400mm)
    Drop (C-C): 130mm (420/440/460mm)
    Flare Angle: 16°
    There is another model called JD-RA68A which identical specs but using 6061 instead of the 2014 alloy - I assume this must be what GT chose to call the "Super Light" variant. My "Ultra Light" variant isn't very light either at almost exactly 300g.
  27. #627
    May 2017
    Oh and Bianci rebrands the same bar here, too:
    https://www.bianchistore.de/en/bianc...ar-alloy-ra68a
    (interestingly, Drop & Reach listed by Bianci differ a little bit from the original TranzX specs and in fact come closer to what I measured on mine).
  28. #628
    Nov 2008
    After a couple hundred kilometers with the Easton Bar I can say it's good. I was waiting for a bigger effect on reducing the road buzz but I'm fine with the result. My expectation were pretty high after changing my seatpost to a Ritchey WCS Carbon Link Flexlogic. Superb seatpost btw. As said the Easton hook shape fits me better. It's a nice upgrade.
  29. #629
    Aug 2010
    Not a lot of chatter among the Grade owners. Hopefully everyone is out there racking up miles on their Grade. I was getting a little rear brake rub and needed to clean my drivetrain, so I stuck the bike in the stand and took care of those last night. While mucking with the rear brake, I noticed that the rubber boot on the front dérailleur cable has pretty much disintegrated and my shift cable isn't in the greatest shape. Has anyone replaced this boot? If so, what did you use? I'm thinking of trying a V-brake boot as I can't seem to find one meant for a shift cable. Suggestions?
  30. #630
    Nov 2008
    I would try the v-brake boot.
    I had a bigger hole in my Hutchinson Sector 32 that Stans wouldn't fix. Tires have been ridden only for 2200km. I went the lazy route and slapped on some Casco Liquisole glue on it only from the outside while the tire was still on the rim. Put 5,5 bar in it and rode the first 50km with zero pressure loss. Normally I use about 4,5 bar on the rear tire. I'll use the same stuff to patch other cuts before they get any bigger or filled with sand.
  31. #631
    Mar 2016
    Just to tell that Hutchinson Overide fit in tube 38 version. They measure 37mm on my Alloy. It is a tight fit though: https://www.strava.com/activities/11...R&v=1501264797
  32. #632
    Aug 2017
    Hi all, wanted to contribute some pics to the thread as a thanks for helping me land on the Grade as my first road-ish-type bike.
    It took a few rides to get things dialed in and accustomed. Such as working on my new found fear of upping and downing curbs (lol). After a solid 3hr ride today I think I have things where I want them. And I think I'm addicted to this thing. Loving the combo of speed, distance, and off-roadiness.
    Onto pics. Let's give some love to the economical end of the spectrum.
    Here's my '17 Claris:
    I love how the frame looks. Triangle is small on this 53cm frame.
    So as of '17 the Grade no longer comes with a carbon fork on the Sora and Claris models. Here's what the new alloy fork looks like.
    As for future plans... I really really really miss having full hydro-brakes. It's the feel and modulation that I love, and this (well, all) bikes deserve to have that. Maybe a Tiagra-hydro groupset + post-mount calipers at some point? Or if Shimano brings Hydro down to Sora level I'm completely fine with that.
  33. #633
    Looking at a deal on a 2016 Carbon Grade, $600 difference between 105 and Ultegra, thinking it is not worth it but looking for some input! Cash could be used to upgrade some other things like wheelset.
    Excited to get on this ride.
  34. #634
    Quote Originally Posted by calibrit View Post
    By all reports I’ve seen, it seems the 105 5800 series shifts every bit as good as the ultegra 6800 series, just with additional weight. I’ve got 6870 (di2) on my Grade, but if I was looking for mechanical right now, I’d probably be aiming at the 105 5800 series. Seems to hit that “best bang for the buck” sweetspot
  35. #635
    Reputation: Jacobray's Avatar
    Jun 2014
    I went with 2015 Ultegra because of the hubs, more than anything. DT 240s are bulletproof and the Ultegra was just a bonus. I assume the 105 is hydro, as well?
    You're gonna be happy either way...go with your gut and ride it.
  36. #636
    Quote Originally Posted by Jacobray View Post
    Yeah 105 brakes are the same as the Ultegra as I understand. I looked at the hubs too, $600 goes a long way though!!!
  37. #637
    Aug 2010
    FWIW, you couldn't build the wheelset on the ultegra grade for $600... Check out the price of the 240 rear hub. Even if you're thinking of going with carbon wheels, the ultegra might make sense. You could relace the 240 hubs to carbon hoops and sell the unused Grails. Also, I'm pretty sure the levers on the 105 bike are not the carbon ones on the ultegra. Not sure if that matters to you or not, but the 105 hydraulic levers are not the same as the carbon levers that are ultegra uses. The 105 stuff is still great, just wouldn't want you to be disappointed.
  38. #638
    WillWorkForTrail
    Jun 2012
    Agreed, 105 is a solid group. I made some changes and upgrades to my bike, it was not originally 105, but I went to 11spd 105 and haven't had a single problem with it. I recently replaced the chain because the wear gauge said I should, but shifting was still solid and no excess noise to speak of, the new chain shifts smoothly and is still quiet, so it seems like the rings and cassette aren't worn much. Again, shows how solid the 105 is. Like mentioned, new wheels may cost more than the difference - but are the stock wheels tubeless ready? I forget. If not, that might be a step you want to take. Either way - this bike is a blast to ride.
  39. #639
    Hi all
    I'm looking at a GT Grade Carbon Tiagra as my first ever non mountain bike, getting 35% off so it's a good deal. One thing that's confusing me - it has a PF30 shell with what seems to be a square taper FSA Vero crankset. Must be some kind of adaptor..? It sounds ugly/heavy so I'm keeping an eye out for a BB30 crankset to replace it with. I assume switching it to a standard PF30 BB will be straightforward? Will probably get a LBS to fit the bearings, just don't want to be stuck with a cartridge BB.
    Any other bits that I might want to replace from stock?
    Thanks all
  40. #640
    Couldn’t make a decision so I bought an rlt rdo.
  41. #641
    Aug 2010
    The new 10spd Tiagra stuff is pretty nice; I know a couple friends with it on Spesh Diverges. Your low points (like any Tiagra bike) are going to be the crankset and wheels. I'm not sure what GT uses to mount a square taper BB in the PF30 shell, but I worked on a Jamis that had a PF30 bb and it had a threaded aluminum tube pushed in there. It was a real pain to get it out, but once out the PF30 cups pushed right in.
    That said, the praxis works adapter GT uses on the 105 and Ultegra bikes is a pretty solid BB. I have several thousand of miles on mine with zero issues. I'd definitely consider going that route if you like Shimano cranks. They weigh a little more than some of the BB30 stuff, but they are solid.
    calibrit - which level RLT RDO did you buy? How do you like it? If I was in the market for a new gravel bike right now, it would be high on my list.
  42. #642
    Quote Originally Posted by SlipperyToad View Post
    Thanks for the reply.
    Yes, if there's an adaptor stuck in there I think I'll just leave it. It would be OK to fit a hollowtech BB I assume? I could then pick up an Ultegra crankset on eBay at quite a good price.
    Bit of a shame not to use the BB30. At the moment it's stopping me from buying it. I'm worried about being stuck with a square taper set up.
    Bike shop took a photo, doesn't give much away.
  43. #643
    Aug 2010
    That looks like your standard square taper bb... since the adapter is a standard 68mm width, you should be able to pull out that square taper bb and screw in a hollowtech bb no problem.
  44. #644
    Sorry, double post.
    Ok thanks SlipperyToad. Doesn't sound too painful.
  45. #645
    Re RDO. Rival. Ultegra is silly expensive.
  46. #646
    Sep 2013
    Please can you show a pic of the threaded side too, ta.
  47. #647
    Nov 2008
    Getting ready for the ice, snow and darkness with a new wheelset with dynamo lights
    https://ep1.pinkbike.org/p6pb15341112/p6pb15341112.jpg
    Shutter Precision PD-8 QR 28H
    Hunt 4 Season Gravel disc
    DT Swiss Revolution
    Shimano SM-RT66 160mm
    DTSwiss 350 135mm 28H
    DT Swiss Revolution
  48. #648
    Dec 2017
    Hi - I too am looking at the Carbon Tiagra...as a roadie not wanting to be stopped from exploring a few tracks. I have been through all the posts, which have confirmed I am going in the right direction - and will spend the rest of my life worrying about wheels and tyres I am still a little confused with sizing - and wont be a able to try the bike first. I am 5'10 (177cm) with an inside leg of 32.5" (82.5cm). The first bike shop suggested a 56 - but later changed to 55 when I challenged them....I have seen suggestions in this forum that the 53 may also be suitable. My roadbike fit data was 733mm saddle to bottom bracket and a reach of 544 from saddle to bars. Any words of advice before I push the button?
  49. #649
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    Can be, but not on all bikes, for example:
    Save Up to 60% Off Disc Brake Road Bikes - Motobecane Century PRO Ti Titanium Ultegra R8000 Hydraulic Disc Brake Road Bikes
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    06 Cannondale Rush
    99 GT XCR
    93 Raleigh MT 200
  50. #650
    I'm 5'11 with a similar inside leg to you & went for the 55. It's a good fit, might try a 90mm stem just to see but it's not uncomfortable at all. I have 19cm of seatpost showing.
    I switched a couple of parts & the bike is now under 8.5kg on my not-very-accurate scales. Not bad at all, should be very respectable with a light wheelset.
  51. #651
    Aug 2010
    I'm with jbuckingham, I'd guess you'd be happiest on a 55, but obviously bike fit is largely a matter of personal preference I'm 5'8" and ride a 55 with a 90mm stem - 31.5 cycling inseam and about a +1 ape index. I wanted the extra stack height of the 55 (I'm getting old), otherwise I'd have gone with the 53.
    Just in case you're open to ordering a bike online, Jenson USA still has at least one Grade Ultegra in 55 on sale for $2300. Using Active Junky, you can save off that too.
  52. #652
    Oct 2011
    I’m 5’10” and also chose the 55 over the 53 to get the increased stack. However, as a result, I don’t have much seatpost showing and I’m running a 90mm stem. But the upright position was important to me. I think a 53 is a better fit for someone looking to be more aero or who wants more seatpost showing to gain more compliance in their ride.
  53. #653
    Dec 2017
    Cheers all....I have decided to track one down for a fit
  54. #654
    Aug 2016
    Quote Originally Posted by humphuk View Post
    I am a similar size to you and went for the 53 and I am so glad I did, it’s plenty big enough for me I recon the 55 would of felt huge, but each rider likes a different riding position. I would try both sizes if you can
  55. #655
    Jun 2016
    Think you better 53 I'm 187 with 88 for me 56 fine, 55 size not too much difference in geometry to cover 10cm. worst case you always can put 10-20mm longer stem, much better than adjust sizing by shortening it.
  56. #656
    Jun 2013
    I was finally able to sell my Grade over the holidays after more than a year of trying. It was carbon with tiagra drivetrain and some upgrades, and I'm surprised how much trouble I had selling since it had very low miles and I wasn't asking crazy money for it. I have a hunch that it being a GT drove forks away, since GT overall have gone significantly down market. The last time I saw a GT bike was at Dick's Sporting Goods, and not even Performance carries them anymore (at least in my area). GT's customer service is not good either, as even getting a hold of anyone is not an easy task. Best of luck to you all on your Grades!
  1. Up grade
    By Jcomer in forum Beginner's Corner
    Last Post: 01-27-2014, 05:17 PM
  2. Replies: 0
    Last Post: 02-18-2013, 02:31 PM
  3. RIP...best up-grade so far
    By motopail in forum Niner Bikes
    Last Post: 12-23-2012, 01:54 AM
  4. AC Separation Grade 3
    By bikepunk13 in forum Colorado - Front Range
    Last Post: 06-20-2012, 09:26 AM
  5. Bearings: grade 300 versus grade 25
    By JonathanGennick in forum General Discussion
    Last Post: 07-11-2011, 07:31 AM
Members who have read this thread: 82
