Page 13 of 13 FirstFirst ... 3910111213
Results 601 to 622 of 622
Thread: GT Grade
  1. #601
    West Chester, PA
    Had to re-tape my grails yesterday. Pulled the tires off to remove a giant Stan's booger in each one, and the beads ripped up the edges of my tape pretty bad. What a freakin PITA. That center channel makes it real hard to get the tape in there while trying to stretch it. These rims were a nice intro to the wonders of road tubeless, but I'm definitely not going to miss them when they're gone.
  2. #602
    Nov 2008
    The moment when you just can't remember why you took the fenders off...
    At least it was fun.
  3. #603
    Apr 2016
    Drove up to the North Cascades Highway on Friday. 41 miles with about 3,800 feet of vert. All paved.
    This was the turn-around point. This is why they close the road.
    Scenery.
    And then the way out.
  4. #604
    Aug 2010
    Looks like an amazing ride! Thanks for sharing the pics!
  5. #605
    Quote Originally Posted by 92gli View Post
    The same thing happened to me last week. In between trying to get the Kenda Happy Medium SCT's to seat (horrible experiencie, btw) and my undiscriminated usage of my plastic levers I ended up busting my rim tape. I also found out that using high pressure (> 45 psi's) on these builds is not recommended.
    I'll retape them again next week and will be extra careful with the pressure and levers.
    ps. the new Maxxis Terrane 33mm might be a better alternative to the hard-to-seat Kenda Happy Medium's.
  6. #606
    West Chester, PA
    Quote Originally Posted by dekaru View Post
    I can't get the rear wheel to seal. I thought it was good but there's sealant coming through a few spoke holes. I must have screwed the tape up again. I think I'm going to solve the annoyance the best way possible- throw money at it. Mavic ksyrium wheels are calling me. No holes to tape.
  7. #607
    Give the Hunt wheels a try, excelent value (and looks!) for the money
    https://www.huntbikewheels.com
  8. #608
    Last week I finally decided to go road tubeless with my grail rims, using stan's tape and schwalbe pro one tires. Had the exact same problem you described. Getting the wheel on caused the tape to get messed up and leak through spoke holes.
    After 2 attempts, i grabbed some gorilla tape, cut it to 21mm and slapped it on (1 layer). The tape went on perfectly smooth on the rim and the schwalbe's seated up on my first attempt after that. Ditch the stan's if that's what you're using.
  9. #609
    West Chester, PA
    I'd consider waiting for their wheels if I was going to get carbon, but wouldn't wait on them for alloy. There's nothing that special about them.
    Quote Originally Posted by fumanju View Post
    I got a roll of wider tape and it seems to be working better. It's 25mm. Goes up the bead shelf a little bit.
    Even though I fixed the issue, I still made an impulse purchase. DT spline R32 wheels are on the way from Germany. Price was too good to resist. They need tape too, but I went for the looks and like how the hubs convert to every axle standard out there.
  10. #610
    Reputation: sml-2727's Avatar
    Nov 2013
    Well I went out for a road ride today and looking at mountain bike trails I decided to try a little off road, now I had the tires pumped up to 100psi with the stock mostly slick tires and actually did a lot better than I thought it would, Now the one thing I do hate about road type bikes is drop bars...what would it take for me to go to a flat bar? Im thinking probably everything (brakes/levers/shifter...etc)
    2016 Santa Cruz Hightower CC
    2016 GT Grade Carbon
  11. #611
    cowbell
    Jun 2012
    Quote Originally Posted by sml-2727 View Post
    And a longer stem, because you won't have the length the bars add.
  12. #612
    West Chester, PA
    Got rid of that crap formula front axle and switched to a maxle stealth. So much nicer looking and it doesn't sound like a zipper when you insert it. Have to carry a 6mm in the saddle bag now though. Have a DT RWS rear skewer but would like to find something less bulky for that too. With tubeless, I rarely have to remove the wheels these days...
  13. #613
    Reputation: cbj2012's Avatar
    The Maxle fits that is pretty cool to know. That much look so much nicer too.
  14. #614
    West Chester, PA
    Yep. They have a maxle stealth road version that matches length and threads perfectly.GT Grade-img_20170411_171528.jpg
  15. #615
    Reputation: steelcityadv's Avatar
    Dec 2015
    Sent from my SM-G900V using Tapatalk
  16. #616
    Nov 2008
    In case someone was wondering about framebags. Here is a Blackburn Outpost (Medium) in a 2016 55cm frame. That's is a spare toob between the seattube and the framebag. Good bang for the buck.
  17. #617
    Aug 2010
    Well, I did a complete dipshit thing last night. Bunny hopping a railroad tie in small chain ring/small cog on a dirt road the chain popped off and wedged between the chainring and the chainstay. It chewed up the chainstay a bit - not terrible, but took a little chunk out. Anyone else on a carbon Grade have a similar occurrence? It looks like the top layer of carbon is pretty much decorative, and there doesn't seem to be damage below that.
  18. #618
    Dec 2015
    Some Grades
  19. #619
    West Chester, PA
    Finally got my DT Spline R32 wheels from Germany. Damn these things are mean lookin. And so nice that they come with every hub adapter possible. Also recently got ergon saddles for all my bikes. Love them! Not much left of my original bike... just the cranks, FD, post, brakes and brifters.
  20. #620
    Finally got my DT Spline R32 wheels from Germany. Damn these things are mean lookin. And so nice that they come with every possible hub adapter possible. Also recently got ergon saddles for all my bikes. Love them! Not much left of my original bike... just the cranks, FD, post, brakes and brifters.
    super nice! what size is it?
  21. #621
    West Chester, PA
    53...
  22. #622
    53...
    If you ever decide to sell it or if you wish to change it for another one size larger let me know :P
  1. Up grade
    By Jcomer in forum Beginner's Corner
    Last Post: 01-27-2014, 04:17 PM
  2. Replies: 0
    Last Post: 02-18-2013, 01:31 PM
  3. RIP...best up-grade so far
    By motopail in forum Niner Bikes
    Last Post: 12-23-2012, 12:54 AM
  4. AC Separation Grade 3
    By bikepunk13 in forum Colorado - Front Range
    Last Post: 06-20-2012, 09:26 AM
  5. Bearings: grade 300 versus grade 25
    By JonathanGennick in forum General Discussion
    Last Post: 07-11-2011, 07:31 AM
