Results 1 to 31 of 31
    GT Avalanche - Need Frame Advice
    I'm looking into a entry level hardtail and was looking at the Avalanche 1.0, 2.0 and 3.0. Does anyone know if the frames are identical in the three models. I was looking at the 2.0today at Performance and it was going for $499. If the frames are identical I was thinking of going for the 3.0 which was on sale for $399. I plan to use this as a second bike. As I upgrade componenets on my full suspension I was planning on migrating those components over to the Avalanche frame.
    Nice day for a ride..... Moderator
    Reputation: Bikin' Bric's Avatar
    Sep 2003
    The Avalanche 1.0, 2.0, 3.0 all share the same 6061 hydroformed butted aluminum frames. I bought an Avalanche 2.0 in the spring just for the frame because they are the best fitting frames I've ridden (for me at least).
    Check out my build here
    RatchAttack's 2008 GT Avalanche 2.0 custom build
    Thanks Attack. Do you think it is worth paying the extra for the 2.0. I do like the white frame over the colors that the 3.0 comes in. By the way, your bike is awesome. I also want to slowly build up the Avalanche frame; just need a good solid frame to build on to. Is there any other info you can provide on the Avalanche frame. I also on one of the other postings a member said that the 3.0 frame was not the same as the frame on the 1.0 and 2.0. Do you know if that is true. Something about the 3.0 does not use the hydroformed tubes.
    Sep 2003
    Quote Originally Posted by 10sballs
    The frames are all the same, I checked them all out when I bought mine. I bought the 2.0 just because it was white, otherwise I would have gotten a 3.0 and used that frame. Either way I ditched all the stock parts on ebay, etc and got back most of my investment. If you like the color of the 3.0 go for it, it is the same frame as the 2.0 and 1.0
    Thanks Attack.
    I'll probably go with the 2.0 since I also like that white frame.
    nono
    The 08 avalanches are not of the same. Go observe the top tubes of ava1.0, 2.0, 3.0
    Hellvin, I was at Performance the other day looking at the Avalanche frames. I need to go back and look closer at the toptube like you mentioned. The sales guy pointed out that the 3.0 frame is made in china, while the 1.0 and 2.0 are made in Taiwan. He felt that the 1.0 and 2.0 frames were better for that reason but couldn't give me any specifics. Do you know if the 1.0 and 2.0 are actually different, What is it about the toptubes that make the frames unique.
    i think...
    maybe thicker tube stronger, more rigid...?
    Do you think all three frames (1.0, 2.0 and 3.0) are different? or is the difference between the 3.0 and the 1.0/2.0.
    For the 08 mods,
    For the 08 models, all 3 are different...
    Does anyone know what is the difference between the '08 Avalanche 1.0, 2.0 and 3.0 frames, other than the 1.0 and 2.0 frames are made in Taiwan and the 3.0 is made in China. For that reason alone the local Perfromance shop felt the 1.0 and 2.0 were the better frames.
    Really looking for specifcs between the three frames. More than "they are different".
    Sep 2003
    I've compared them all side by side and there is no difference except the front of the top tube of the 3.0 frames are not hydroformed. The 1.0 & 2.0 are exactly the same. All 3 frames are made of 6061 aluminum and have the same geometry.
    Thanks Attack. I think I'm still leanig towrds getting the white 2.0. When you were shopping around did the LBS say anything regarding the 3.0 being built in China versus Taiwan where the 1.0 and 2.0 are built.
    Sep 2003
    I've never heard anything about frames being built in different places.
    Top tube sizing
    The top tube of the ava1.0 is thickest while the 3.0 is the thinnest. I'll try to take pics of all 3 bikes when me and my friends meet up again.
    Went down to the local Performance shop today and placed an order for an Avalanche 2.0 in white. They actually had an Avalanche 2.0 with hydraulic discs for the same price on their website, but unfortunately the hydraulic version only came with the blue frame. Really wanted the white frame, so I'll just live with the mechanical discs for a while.
    aww
    Oh...why? The blue one looked quite nice as well...but if you already have plans for upgrades then to get the hydraulic brakes version would be pointless. But the Tektro auriga comp is actually not bad brakes.
    Ratch, how difficult was it to change over to a 9 speed. can I just go pick up a new 9 speed cluster and put it on the hubs that come with the 2.0. Will I also need to change the rear deraileur and rear shifter?
    Sep 2003
    The 9 speed cassette will fit on the hub no problem, you will have to change the shifters and the rear derailleur to something that is 9 speed compatible. You will also have to buy a 9 speed chain. You may or may not have to get a 9 speed front derailleur (they have narrower cages than the 8 speed ones, sometime you can get lucky and they work no problem, othertimes not so lucky).
    I use the Sram X9 derailleur and shifters, Sram hollowpin chain, and Sram PG990 cassette. Its the best setup I've ever used, totally blows away all the Shimano stuff I used before.
    Hope this helps.
    Thanks Ratch. Can't wait to get the bike.
    I agree with you the SRAM X.9. I have that on my FS with X.7 shifters. Do you know how the X.7 rear deraileur is? I saw it for $60 at JensonUSA.
    Sep 2003
    I've got an X7 on my XCR I-Drive and it works well. I found that the biggest difference in the X7 vs. X9 setups were the shifters. That said, the X7 setup on my I-Drive is STILL better than any Shimano stuff I've had (I've ran everything from Deore to XT, albeit it was older stuff between 1999-2005).
    Thanks Ratch. I think I'll look for a good deal on the X.7 shifters and rear deraileur, and go with a 9 speed cassette. Looks like the PG990 is a pretty high end cassette. Are there any other SRAM 9 speed cassettes that are decent but a little lower in price that you would recommend. I saw the PG990 at JensonUSA for $99, little more than I wanted to spend. What did you get the PG990 for?
    Sep 2003
    I paid full pop of $100 for the 990, well worth it though, I've been using the same cassette for 3 years now (over 3500km) but have made sure to change the chain after every 500 km or so for longevity of the cassette. I've seen the 990 on sale for $65 at pricepoint.com.
    http://www.pricepoint.com/detail.htm...8&hprice=64.98
    Pricepoint has a deal on the X7 shifters & derailleur setup for $85
    http://www.pricepoint.com/detail/128...COMBO-2008.htm
    They also have the PG970 cassette for $35 which is Sram's midrange cassette (similar to Shimano LX/XT level, whereas the 990 is more XT/XTR level).
    http://www.pricepoint.com/detail.htm...8&hprice=34.98
    Thanks Ratch. Can't wait to get the bike. Need something to work on since I can't get on a bike right now. Recovering from a broken collarbone.
    Sep 2003
    Ouch, hope you have a speedy recovery.
    Ratch, I've been waiting so long for my 2.0 to be delivered I've now started questioning myself on the size I ordered. I'm 5' 6'' with about a 29" inseam. I ordered a small frame. For my F/S ride I have a '08 stumpy fsr comp, also a small frame. Since I'll be riding the the 2.0 on more mellow trails, mostly with the kids, I'm now thinking I should maybe go with the medium. I straddled the medium at the Performance shop and I the top tube was pretty much right there so I didn't try riding it around the parking lot. But since I won't be using this for aggressive riding I'm thinking the medium might be better. What's your thoughts?
    Sep 2003
    Well, I'm 5'11" with a 33" inseam and I ride a size large. The avalanche frames are on the short side which makes them rip technical trails. Very tight wheelbase on these bikes. My size large has a 23.5" effective top tube which fits me pretty good. If you are in doubt just measure the ETT of your stumpy and compare it with the Avalanche.
    Ratch, the ETT of the 2.0 small is 21.49, the 2.0 medium is 22.7 and my stumpy 21.9. I just went to the neighborhood bike shop that carries GT and they had a Outpost in a medium frame. I felt a little stretched out on the medium, probably would have to go with a shorter stem if I bought the medium. I looked on-line on the GT site and the geometry of the Avalanche and the Outpost are identical, so the Avalanche in the medium will probably feel the same. Your right about the wheelbase, the 2.0 small has a wheel base of 40.15. My stumpy is at 42.7.
    When my 2.0 small makes it to my local Performance shop, I'll try out a medium 2.0 before I make my final decision.
    Sep 2003
    If the small fits better than run with it. You'll never like a bike that does not fit right.
    The Avalanche and Outpost have the same geometry because the Outpost frame is actually the same frame as the older Avalanches (My 2003 Avalanche was the same frame as the 2008 Outpost).
    Ratch, thanks for your help. I think I'll go with the small.
