Results 1 to 12 of 12
    hillcycle
    Apr 2015
    GT Avalanche 3.0 2010
    Hey i have said bike above and i am a noob at this game.
    I need new Wheels,Tires, Brake Discs and Brake Cables but wouldnt have a clue trying to find some aftermarket upgrades.
    Feel free to assist the noob.
    Last edited by Samuel Colosimo; 04-25-2015 at 03:14 AM. Reason: its 2010 model not 2009
    Sneaker man
    Reputation: mik_git's Avatar
    I don't know what you get, but I get a million banner adds for Jenson USA all over this site at the moment, they are pretty good...
    You could try the good old Local Bike Store (LBS) they usually have stuff... or
    JensonUSA
    PricePoint
    CambriaBicycleOutfitters
    Wiggle
    ChainReactionCycles
    Wheels, whats wrong with them? Just wanting an upgrade, or they are knackered? You can spend a little or a lot, complete wheels or build from scratch - assuming the non-dics version of your bike, getting rim brake wheel sets are getting thin on the ground these days, but used or liquidation sales can give you some good bargains (add ebay to the above list), but you can alwyas build a good set of rim brake wheels for not too much.
    Tyres, I like Continental, Michelin and Panaracer, other people liek other stuff... tye things see what you like, they wear out so you replace often.
    Cables just get some shimano ones.
    2003 Yeti ARC
    2008 GT Zaskar Reissue
    1996 GT Xizang
    2012 Cannondale Synapse 3 Carbon
    2012 Cervelo R3
    2015 Look 675 Light
    hillcycle
    Apr 2015
    Here's the thing. One night in Bacchus Marsh i left my bike chained up at the train station.
    Being the idiot that i am i chained my bike on with the quick release wheel.
    After one night at the station, some dero stole my wheels.
    To leave me with no way home in the pouring rain of a night time. Shattered.
    hillcycle
    Apr 2015
    Also need brake discs and rear gear cable
    hillcycle
    Apr 2015
    This bike comes factory with 26" wheels, can i put bigger on? Is that something id want to do?
    hillcycle
    Apr 2015
    How do i know what parts will fit with my bike???
    Jun 2013
    No, you can't put bigger wheels on. Cables, best to go to your local shop if you're not familiar with what you need. For wheels, you can browse the online retailers like JensonUSA, Pricepoint, Art's Cyclery for 26" wheels. You need to pick ones that are compatible with your fork (9mm QR, or 15mm thru-axle, etc) and same for the rear (standard QR). Pay attention to pick a wheel with a hub that is compatible with your disc brakes (6 bolt or center lock).
    hillcycle
    Apr 2015
    Quote Originally Posted by matadorCE View Post
    Cheers appreciate it
    hillcycle
    Apr 2015
    Sizes Xsmall, small, medium, large, xlarge, xxlarge
    Colors Blue/Black, Silver/Black, Red/White
    Item ID 20918
    Frame & Fork
    Frame Construction TIG-welded
    Frame Tubing Material 6061 Custom Butted/ Hydraformed Aluminum DT
    Fork Brand & Model SR Suntour XCM, 100mm travel
    Fork Material Aluminum/chromoly, single crown
    Rear Shock Not applicable
    Components
    Component Group Shimano mix
    Brakeset Tektro mechanical Disc brakes, Alloy linear levers
    Shift Levers Shimano Rapid Fire
    Front Derailleur Shimano M -330
    Rear Derailleur Shimano Alivio
    Crankset SR Suntour XCT-302, 22/32/42 teeth
    Pedals High Impact nylon MTB with Steel Cage
    Bottom Bracket Cartridge Sealed
    BB Shell Width Unspecified
    Rear Cogs 8-speed, 11 - 32 teeth
    Chain Shimano IG-31
    Seatpost Alloy Micro Adjust, 31.6mm diameter
    Saddle WTB Pure V Sport
    Handlebar GT MTN Riser
    Handlebar Extensions Not included
    Handlebar Stem GT ATB
    Headset 1 1/8" Tange Seiki
    Wheels
    Hubs Alloy disc
    Rims Alex ASD-1
    Tires 26 x 2.10" Kenda Nevegal
    Spoke Brand Stainless, 14ga. (2.0mm)
    Spoke Nipples Brass
    hillcycle
    Apr 2015
    Bump
    Sneaker man
    budget?
    But offhand, what I'd get (all bought from chain reaction or jensonusa):
    Fork: DT Swiss 100
    Drivetrain (shifters, cranks, derallieurs, brakes) Shimano M9050 groupset
    Wheels: Mavic Crossmax.
    ...OK not really, but gives you an idea of what you can spend, so you need to give us an idea of how much, $300 or $3000
    2003 Yeti ARC
    1996 GT Xizang
    2012 Cervelo R3
    2015 Look 675 Light
    hillcycle
    Apr 2015
    I don't wan't to spend anymore than what the parts are worth that i am replacing.
    Hopefully their are stronger after market options...
  1. Replies: 0
    Last Post: 02-27-2015, 04:32 AM
  2. Replies: 1
    Last Post: 02-06-2013, 04:21 PM
  3. Replies: 0
    Last Post: 02-06-2013, 12:50 PM
  4. Replies: 1
    Last Post: 07-27-2011, 09:59 AM
  5. GT Avalanche Expert 2009-where to buy?
    By ckyamaha in forum Beginner's Corner
    Last Post: 03-12-2011, 05:19 PM
