Page 31 of 45 FirstFirst ... 21 27 28 29 30 31 32 33 34 35 41 ... LastLast
Results 751 to 775 of 1118
  1. #751
    Reputation: stecz20's Avatar
    i just found one of these listed on my local craigs list... im 6'0" what size should i be looking at? im gonna take a look at it tomorrow!!! awsome thread...
  2. #752
    Reputation: gm1230126's Avatar
    Quote Originally Posted by stecz20 View Post
    18" c-c
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
  3. #753
    Quote Originally Posted by gm1230126 View Post
    18" c-c
    thank you... thats what size it is..
  4. #754
    1997 gt lts-2
    Could not pass on this!!! In great shape and ridden a handful of times... $300 from Craigslist...... SN#S7KA1961 Can't really make out how that reads, but maybe one of you guys will...
    Ive been looking hard at a karakoram, thought i had my heart set again!!! After seeing this, ill be looking for a matching Zaskar...
  5. #755
    Hey all I have an lts-3 that I acquired a couple years ago that I'm looking to sell, but I would like to get some more information first. The serial is S7IA4411. Can anyone help with some information? Thanks!
  6. #756
    lts 2000 front derailer
    hi can anybody tell me what front derailer i should have i this frame or one they reconmend many thanks
  7. #757
    Sep 2012
    May i know how old is GT LTS-2
  8. #758
    GT LTS Hoarder
    Reputation: johntheroadie's Avatar
    Dec 2005
    For anyone who keeps wondering where is a replacement shock for your trunion-mount frame, here's your answer! I should've known that the answer was so simple to be found on ebay! Just take an old eye-to-eye shock and thread a trunion mount onto it! So simple!
    I love the sellers response to the one question...
    Q: is the rear shock completely, properly mounted?
    A: Hi Yes, the rear shock have a special adapter from factory. That's the way it should be mounted Thanks
    Now we know how it should be, so I don't want to hear any more questions about rear shocks. Item number 221124944622 for those who want it done right.
  9. #759
    There's a good simple tip on the trunion....
  10. #760
    Feb 2010
    It's been a while since I've been on here, and I've only read up to about page 8 on replies. I just bought a STS frame to build up instead of the LTS one that I still haven't gotten around to. I just moved and have a buddy that used to be a bike mechanic and he's gonna help me with the build in exchange for beer.
    I'm curious if anyone has, or has a source for, the liners to guide the cables through the frame? I'd much rather get the routed the right way than have to zip tie them to the frame.
  11. #761
    Feb 2010
  12. #762
    Pickin' n' Grinnin'
    Reputation: btl68's Avatar
    If anyone has a great condition LTS or STS frame for sale, send me an PM.
    Edit: No more need for this, as I just purchased a used Ellsworth Moment.
    Last edited by btl68; 11-12-2012 at 04:57 AM. Reason: No more need for a LTS or an STS
    Ignorance is bliss until they take your bliss away...
  13. #763
    Aug 2005
    Quote Originally Posted by btl68 View Post
    How about a complete LTS? PM sent.
  14. #764
    Pickin' n' Grinnin'
    Quote Originally Posted by GT_guy View Post
    PM's answered, offer sent, awaiting reply.
  15. #765
    Singletrackmac
    Reputation: singletrackmack's Avatar
    Oct 2012
    Pivot replacement parts LTS 3
    I need to get pivot replacement parts for a 96/97 LTS-3. Does anyone know where I can find the lower and upper pivot replacment parts for this bike?
    Get out of the gutter and onto the mountain top.
    "I only had like two winekills captain buzzcooler"
  16. #766
    Reputation: Betoh00's Avatar
    you can find the replacement parts you need along with the sealed roller bearing kits at Betd... GT Lts and Sts spares : Mountain bikes and componets by BETD Goldtec
  17. #767
    Feb 2010
    Can anyone post some pics with close-ups of cable routing on a STS? I just turned over my frame to my buddy to build it up for me and he's concerned about how the cable comes out of the down tube for the front deraileur and also about proper length for the rear deraileur. I'm assuming a good loop is required for the rear, but not sure. Are there any special fittings that should be used where the cables come out from the frame or anything else special that should be considered???
  18. #768
    GT LTS Hoarder
    Dec 2005
    I'm not proud of these pictures....
    This is the way it's done on my STS. The other bike that I never ride is even worse than it.
    I have a short section of cable liner that gives is some protection, but I hardly think its enough. As seldom as I ride it anymore, I have no intention of changing it, so maybe someone else has it it run differently and better than my setup.
    Just make sure your rear derailleur has a bit of a gentle curve to it when the suspension is fully extended between the top tube and rear triangle. If it is run totally straight, it could cause ghost shifting as I found out the hard way.
    I just used regular metal cable ends on mine and haven't had any problems.
  19. #769
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by johntheroadie View Post
    Ooh I do love that STS...
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  20. #770
    Quote Originally Posted by singletrackmack View Post
    • GT LTS/STS : • Milwaukee Bicycle Co. • Ben's Cycle
  21. #771
    rear disc brake fouling
    please can any one help i have fitted one of those a2z disc brake adapters and replaced the horstlink bottom brushes baiscally when i spin the rear wheel the disc dont touch on the pads but when i pedal or turn a corner it rubs quite badly its a real nightmare am that close to giving up has anyone had this experience with these adapters or having rear disc brakes on a lts ? my friend reckons its the frame flexing and lts cant run rear disc brakes because of this and were never desighed to have them but i dont think thats exactly true because am sure 99 lts had disc brakes correct me if am wrong please help me guys its took me months and months to build this bike from scatch i really dont want to give up
  22. #772
    Did you bolt the adapter to your left rear dropout along with the skewer atachment? Send pictures. I did one on my wifes 96 small lts-1 and it worked just fine except when i had to take the rear wheel off. No rubbing of the rotor when everything is bolted up snug.
  23. #773
    Check out the other options for Disk Brakes on page 27 of this forum...
  24. #774
    Quote Originally Posted by doralswheels View Post
    thank you so much for the reply our do some pictures now and upload them
  25. #775
    Quote Originally Posted by Betoh00 View Post
    thanks for the reply yes i have but am not keen on drilling holes am not confident it doing that i dont understand why the a2z mount dont work well it does its just this rubbing
