Page 17 of 23 FirstFirst ... 7131415161718192021 ... LastLast
Results 801 to 850 of 1136
  1. #801
    Reputation: loggerhead's Avatar
    Quote Originally Posted by morlysafer View Post
    Saw this on my local craiglist and thought I would share, looks clean.
    GT LTS 2000 FULL SUSPENSION MOUNTAIN BIKE
    Seems like a little too much for that bike.
  2. #802
    Dec 2012
    I think I have a LTS or a STS but can tell which is which. SN reads: 029600280 18 Want to post pics but need a few more posts!
  3. #803
    GT LTS Hoarder
    Reputation: johntheroadie's Avatar
    Dec 2005
    It's easy:
    LTS = Aluminum
    STS = Thermoplastic
  4. #804
    Dec 2012
    Hello LTS enthusiasts! Beginner rider here wondering if I could get some info on my newly acquired GT. I picked it up for $125 from a friend. I am still unsure if it is a LTS or a STS or what series, but in any case it could use some work. Seems like it has some good components on it but the front gear (name?) has some rock guard and a chain guide but it seems like the chain jumps off like crazy! Also the Rockshox Duke SL seems to be real squishy and may need a rebuild. What about those brakes and shifter?, any good?
    Any additional info would be great!
    SN: 029600280 18
    Kooka stem and crank arms
    Cane creek headset
    Risse Racing rear shock
  5. #805
    Oct 2010
    Looks like a '96 STS. Assuming the frame's in good shape I'd say you got a good deal. The Risse rear shock is a nice upgrade. Fortunately, if the rear shock's bad it's an easy replacement for you since your STS doesn't have the trunion mounted shock of the later STSs and LTSs. I'm not familiar with bash guard/chain tensioner setups, but your jumping chain could be from a bent or worn front sprocket, or misalignment somewhere in the drivetrain. Also, looks like the dropout might not fit quite right?
  6. #806
    Oct 2010
    By dropout I meant the derailleur hanger. Just had a look at mine (98 STS) and there's a similar, if somewhat smaller gap. Yours has probably just seen more use than mine...
  7. #807
    Reputation: HingeT's Avatar
    Dec 2012
    If anyone is interested, I posted a video on YouTube of dissecting a 1997 GT LTS-5 elastomer rear shock.
    It wont let me post a link to the video since my post count is less than 10. Whatever... Just search YouTube for "GT LTS-5 Elastomer Rear Shock Disassembly/Assembly"
    It toasted. My current plan is to get a elastomer rear shock from a 1996 LTS-3 and swap some parts to make it fit the LTS-5. I have read a couple places that this is possible.
    After I get the rear shock fixed, then I am going to take a look at the forks. I think they may need some work too.
  8. #808
    Aug 2005
    Quote Originally Posted by HingeT View Post
    Here's the link for you.
  9. #809
    Dec 2012
    Hey does anyone know if there is any way to get the rear derailleur cable back inside the frame? I have the rear brake cable routed correctly but the derailleur doesn't seem to have any internal routing.
  10. #810
    GT LTS Hoarder
    Dec 2005
    A wire clothes hanger, tape, patience, and a bit of voodoo did it for me.
    Take your seat tube out. Straighten out a wire hanger until it was perfectly straight and push it straight though the from the seat tube to the head tube. Tape replacement cable onto tip of wire hanger. Pull said wire hanger backwards though with cable attached. Bravo, you are done...
    Wait, did you remember to put the cable housing on first???
    Repeat process... but with cable housing on between shifter/head tube...
  11. #811
    GT LTS Hoarder
    Dec 2005
    And don't forget the cable ferrule....
    What, WAT???
    Repeat process...
    Third time is a charm....
  12. #812
    GT LTS Hoarder
    Dec 2005
    Quote Originally Posted by Methuselah View Post
    Ditto here. The dead give way is the cantilever cable hanger that is on the rear triangle.
    None of the 97 models had a hanger on them. The only other option was if someone swapped rear triangles with you...
    You got a heckova deal provided the frame isn't broken... I'd gladly give you your money back on it + shipping if you can't get it sorted. lol
    Whatever you do, don't pitch those Kooka cranks in the bin.... people are stupid crazy about those... hint hint.... check e b a y
  13. #813
    Dec 2012
    Does anybody know where I can get new boots for the RST 381 shocks? Mine shredded.
    Also looking for the adjuster cap wrench. Or is there another tool I can use to disassemble the shock? I am guessing channel locks would work, but I would prefer to have a proper tool.
    And I am guessing I will need new elastomers for them as well. I found a set for $40, but maybe there is some place cheaper?
  14. #814
    Dec 2012
    Nevermind on the boots. I went ahead and ordered some Lizard Skins fork boots.
  15. #815
    Dec 2012
    Quote Originally Posted by johntheroadie View Post
    Well I tried the coat hanger, but what did it was some floral wire! Key word patience. Seat removal is a must. Thanks!
  16. #816
    Dec 2012
    My GT LTS-5 project bike.
    <iframe width="420" height="315" src="http://www.youtube.com/embed/xxLaI8MY9fs" frameborder="0" allowfullscreen></iframe>
    https://www.youtube.com/watch?v=xxLaI8MY9fs
  17. #817
    Dec 2012
    I put together another video for how to convert an LTS-3 rear elastomer shock to fit an LTS-5.. I hope this helps people with dead shocks on the LTS-5's. I think the LTS-4's had the same elastomer shock as the LTS-5?
    <iframe width="420" height="315" src="http://www.youtube.com/embed/52qd3Z8cl4Q" frameborder="0" allowfullscreen></iframe>
    https://www.youtube.com/watch?v=52qd3Z8cl4Q
  18. #818
    It's easy:
    LTS = Aluminum
    STS = Thermoplastic
    Not really. Mine that I bought in 96' was an LTS but was thermoplastic. STS came out right after.
  19. #819
    unbelievable find for that price. do you plan on keeping the 1x9 setup? if not put another ring on and run it 2x9 with a derailleur and you won't have to worry about the chain falling off anymore.
  20. #820
    Dec 2012
    Hey everyone! First post here.
    I'm looking at a GT LTS4 on craigslist in my area. It is totally stock and looks to be in a very clean state. They are asking $185 for it. I've done a bit of research throughout this forum and that seems like a pretty good price, but what do you guys think? I like the vintage aspect of the bike and I like the idea of bringing an older, but well respected frame, up to speed with components and retrofits.
    Please let me know what you guys think.
  21. #821
    My beloved '96 GT LTS-1 days may be numbered.. discovered a small crack developing on the drive side chainstay right next to the big chain ring.. checking with some local welders to see if they can put a bead across it to keep it from spreading..
    Just wondering if you guys have a chain stay (or frame for that matter) for a 19 inch LTS laying around that you would like to sell..
  22. #822
    Look for a good tig welder mate, it shouldn´t be a problem to weld it.
  23. #823
    Quote Originally Posted by hartar View Post
    I have an 18" thermo that I just stripped down that I am planning on listing soon on ebay. Just haven't found the time. Has a risse air shock. Have an alps 4r spare practically new as a spare and all titanium bolt for all pivots. Ti. bottom bracket as well.
    Gonna try to list it next week off of work.
  24. #824
    Quote Originally Posted by loggerhead View Post
    cool!! I will be looking for it. I found someone to weld my swingarm.. hopefully it will turn out okay... his work looks real good..
  25. #825
    got my swingarm/chainstay fixed!! looks real good and charged $50.. they fixed the crack and also built up where the chain and chainring grinded the chainstay down over the years..
  26. #826
    Dec 2012
    That's cool that you could get the swing arm fixed! Can you grind it down flush, or would that weaken it too much? Are you going to paint it?
  27. #827
    I am not going to grind it flush.. It was a crack and they just put a bead over it.. I will not paint it, since my bike is the polished aluminum type.. You can't see it since the crank hides it.. I am just going to put a chain slap guard over it..
    yeah, its cool I can get it fixed... now I won't be to afraid to put more money into it.. I want to upgrade the drive train... full XT/XTR..
  28. #828
    It's the holiday's!!! Go nuts. Full xtr.
  29. #829
    Feb 2010
    I've attached a few crappy cell phone pics below of my build that I've finally seen to fruition after a few years in the works. Hopefully the weather will cooperate here soon and I'll get a chance to go out and see if I can avoid breaking my collar bone in my first outing on a FS rig!
    I like to think that most of the gear on her is nearly top of the line (period corrected) with some new parts mixed in as well.
    I'd like to draw some attention to the pic where the front derailleur should be mounted. I had both a top and bottom pull derailleur on hand for my buddy to install, but he couldn't figure out how to get either of them to work, so after the hour plus that he spent routing the cables through the frame (magnets involved), he just tied the cable off to the post, so I'm currently set up for a single speed crank.
    I'm tempted to just take the extra rings off and run a 1x8 setup, but I'm curious what products I should be looking for to make this a reliable setup. I've been out of biking for over 10 years now, so I'm not up to speed on all the latest and greatest setups and/or conversions. I don't want to jump the chain off or have other related issues. What advice can anyone offer?
    Any/all advice would be appreciated. Thanks in advance, and you all rock!
  30. #830
    Quote Originally Posted by miataeric1 View Post
    Go back to page 8, post 768 and you will see how the derailleur is spose to work. Remember that Shimano make 2 types of front derailleurs. A top swing cage, were the swinging cage is above the clamp (which is what you want ) and a bottom swing cage, were the swinging cage is below the clamp. You also must get the correct inside diamater clamp that is part of the derailleur, so you need to measure the diamater of the short snub, were the derailleur mounts. I think it is 31.8 or it might be 34.9, i am not sure. You can see that the cable comes up from the bottom of the frame, so look for a hole in the frame,were the cabe and housing come out of the frame. You will also need the top swing derailleur to be a bottom pull (the cable pulls down). You should look back on these pages and stop at all of the STS type bikes to help you with your build. Hope this helps with your build.
  31. #831
    Its official. The last one of my four gt lts' up for sale on ebay.
    GT Lts STS Thermoplastic 18'' Full Suspension Mountain Bike Frame | eBay
    Any questions, let me know.
  32. #832
    Pretty frame.. how does that Cane Creek work.. any good?.. I prefer coil over suspension.. I find air shocks too harsh..
  33. #833
    I didn't use it enough to find out. Only rode it probably two to three times and it was on the street. My fav was the fox alps 4r that I am selling. Funny, I find coils on this bike or any other too harsh.
  34. #834
    Mar 2011
    how much would someone pay for this?
    I'm trying to sell up some of my MTBs. If this is the last to sell, I'll keep it and go nuts on making it light for XC racing duties. I've got bearings already - so it'll last me for a long time.
    It sits at 11kgs in current form with Crossmax SLRs, but I've worked out how to shave off more weight
    - New Stem (currently EA50 to 3T stem) - 50g
    - Rear derailleur, (currently M770 XT to M972 XTR - 40g
    - Crankset (currently Stylo 3.3 GXP to M970 XTR) - 100g
    - Front derailleur, (currently M770 XT to M980 XTR) - 30g
    - Front and Rear brake calipers (M770 XT to M980 XTR) - 50g
    - Shimano Durace chain (currently some old Sachs chain) - 50g
    - Cut off V-brake posts on forks - 50g
    - Pedals (currently M520 LX to M980 XTR) - 70g
    That means logically, I can shave off about 440g (yes, I'm a weight weenie. A 10.6kg GT LTS would be awesome...
    Current rides: 1996 GT LTS-3, Bianchi Nirone C2C, Giant Trinity
    SOLD: 2009 Giant Anthem X0, 2008 Orbea Alma Carbon Team
  35. #835
    Jan 2013
    Stoked!
    I wanted to find a full suspension mountain bike for my wife (who am I kidding, a 2nd mountain bike for me) and I wanted to get something unique and older. I saw a GT LTS locally on Craigslist a few months back and started to do a little research to see if they were worth a hoot. I found this thread and was really surprised to see these bikes had such a following still. Not many of the other "vintage" full suspensions have that, and compared to the other bikes I've seen, there are still a good amount of parts out there to keep these babies on the trail. Turns out the guy had already sold the bike, but in the meantime I read through all 34 pages of this thread and searched patiently to find one. Finally, I snagged a 1998 LTS 2000 on eBay and it just arrived! I can't wait to get started on my retrofit/ upgrade plans. Once I get 10 posts I'll put some pictures up.
  36. #836
    GT LTS Hoarder
    Dec 2005
    Bob82pigdog;
    Congrats and welcome to the LTS thread..
    And davevo_82... I wouldn't sell your LTS. Very few people would appreciate it in the state it is in and you won't get much money out of it. I say put her on a diet and see how low you can go.
  37. #837
    Huckin' trails
    Reputation: David C's Avatar
    And throw some carbon wheels on it, you're gonna get way more bang for your bucks than all those fancy upgrades
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  38. #838
    Aug 2005
    If anyone needs an LTS, mine is posted over on Pinkbike
    I've also got a 91 Karakoram and a nice vintage 88 Karakoram listed as well.
    Time to thin the herd a bit. PM me with any questions.
  39. #839
    Reputation: gm1230126's Avatar
    Quote Originally Posted by GT_guy View Post
    Dude are you serious? "the bike that started the GT mountain bike empire" Seriously an 88 Karakoram started the GT mountain bike empire? Nice bike bro, but there were many before it and many that were raced and ridden to more glory in building the GT early yr mountain bike glory. It had it's glory when named bike of the year by Mountain Bike mag in 95.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
  40. #840
    Wow IronV6s adapter is just awesome, does anybody else has something like that in order to use a regular shock?
  41. #841
    Huckin' trails
    I was wondering what's the patents status on the LTS design and overall frame ? Thought it would make one hell of a fun winter project to actually weld and build one home-made LTS for one's who got the resources and time ?
    And perhaps improve the design to make it even better, I mean technology has evolved since then. As for me I'm no expert, so I couldn't really suggest any specific upgrades to the design, but I'm sure you guys already have your list
  42. #842
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by David C View Post
    A standard patent lasts 20 years unless I am mistaken. It starts from the time it is applied for, not when it is approved. In order to renew the patent I am almost positive that the design must be significantly changed otherwise it expires and is anybody's game. That said, if you want to play with or make a design similar or identical to what GT did on the LTS, you are free to go and have nothing to worry about even if their patent is still valid unless you intend to profit from the design. That is where things get hairy for the one infringing on the patent.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  43. #843
    GT LTS Hoarder
    Dec 2005
    I'm in agreement with mtbnozpikr; Common sense would tell me that if you were to make a one-off LTS-type bike for yourself, any patent infringing would be irrelevant. However, I would also add that if you tried to market and sell your bike in competition with other bike manufacturers (yes even small-time builders), that is where the problem will arise.... You can bet you will get a call from the team of lawyers representing Specialized...
  44. #844
    GT LTS Hoarder
    Dec 2005
    Well, while we are on the subject, I want to say that I don't have an axe to grind against Specialized...I just feel like the horst pivot had so much potential and when Specialized beat everyone else to the patent office, it pretty much squashed all hope and potential that it could have had for all of mountain bikers. It pretty much told all other manufacturers to find another way to make their suspension work. Granted, they did and we have a bunch of choices now, but at that time, it seemed like cheating us bikers out of a great suspension concept and the development thereof was just wrong.
    In a business sense, it made sense to secure and lock in their future, but like racing regulations, it limits all that potential that could have been opened, if so many other suspension gurus could work and utilize the design...
    Oh well...I'll close by showing my Titus Rockstar chainstay...it still wears a nod of permission from the "big S" to say it's okay legally.. I guess you could google the patent numbers and see what the status of them are..
  45. #845
    In case anybody is looking, I am selling some pivot sleaves and a fox alps 4r shock for the lts/sts frame
  46. #846
    Feb 2013
    Hi
    I'm from Portugal and i have one red GT Lts 3000 ds!
    I'm looking for the exploded view of the Rockshox Deluxe shock to rebuild mine!
    Thanks for this great forum!
    Regards
    Virgilio
  47. #847
    Quote Originally Posted by Virgilio Araújo View Post
    Hi
    Regards
    Virgilio
    I have that manual if you want to look at it.. maybe you will have better luck than I did.. my shock was blown out and no parts available, So I had to buy a new shock from Yasusu.. which is an awesome shock by the way.. I was lucky since I have a '96 and do not use a trunion.. if you have an email.. I will send you the manual..
  48. #848
    Feb 2013
    Thanks hartar
    Can you send me your's by PM?
    I can't send yet pm's...
  49. #849
    Feb 2013
    sundoparamim hat gmail dot com
  50. #850
    rubber side down
    Reputation: TAOS1's Avatar
    Feb 2013
    Lts-dh
    I love the LTS. I had the "XC" LTS 1 and cracked the rear, GT sent me a XCR frame as a replacement. I also have my LTS DH from 1993;
    I modified it for XC when I moved to FL since I broke my XCR and waited forever for the replacement from then Pacific Cycles. I just pulled it out this weekend and cleaned it up. So stoked to take it to the freeride area at Markham Park in Sunrise FL
