Results 1 to 10 of 10
    Reputation: cmeride's Avatar
    Sep 2004
    Anyone running a Pike 150 27.5 on their Sensor 275 ?
    Its just wrong for GT to put that crappy fox 32 non-Kashima on it especially at the Pro model.
    Just wondering if the 150mm would alter the steering/Geo too much ?
    I could buy the new 140 air cart for the pike, but dont want to spend $ if i dont have to.
    Sep 2012
    I've been considering the same thing, but I haven't even bought the bike yet.
    I'd be worried that a 20mm increase in travel would be too much, but I think lowering to 140 would be OK.
    The other option is a 140mm Revelation, not quite as good as the Pike but still better than a 32mm Fox.
    Reputation: socalMX's Avatar
    I think it would be fine, one of the knocks from a few reviews was the front end being too low.
    Sep 2004
    So here's the Pike 150 and with 2 rides on it, it feels great on the downs but wonders a bit on steep climbs. I could live with it if i had to but for $35 to drop it down to 140 it's a no brainer. 140 is the sweet spot for sure. It did raise the BB a bit (only like a 1/4") so more ground clearance is good. The pike is SO much better than the Fox 32 it had. I still believe GT should at least spec these with the Pike or Fox 34 on the Carbon models. I dont like the way the RD cable is routed by the linkage, have to use zip ties to keep it from interfering with the front chain ring. Now there's a rub through where the zip tie is when the linkage moves through its travel. Maybe internal routing through the front triangle ?? Now im looking to upgrade the rear shock to the new Monarch RT3. Heard some great talk about it at Otter. Too bad they dont make the size for the Monarch plus...
    Attached Thumbnails Attached Thumbnails Anyone running a Pike 150 27.5 on their Sensor 275 ?-img_20140416_080425.jpg
    Anyone running a Pike 150 27.5 on their Sensor 275 ?-img_20140416_080451.jpg
    Sep 2012
    Looks great! I see you've got a dropper on it again.
    I just got my Carbon Sensor Pro last weekend and I've started doing some mods already. I'll post it up soon
    Sep 2004
    Yeah picked up a Reverb Stealth on the cheap as it was an warranty replacement.
    Mar 2013
    Quote Originally Posted by cmeride View Post
    I wrap cotton electrical insulation tape around the frame to prevent this.
    Sep 2012
    Your cable must be routed differently with the XX1 install, on mine with the standard RD/shifter the cable is nowhere near the chainring.
    Reputation: cbj2012's Avatar
    Agree 140mm is the way to go. Here is min with 140mm Pike
    Anyone running a Pike 150 27.5 on their Sensor 275 ?-10307187_10152365113841223_5496629676711247070_n.jpg
    I have no problem with the cable routing on my bike.
    Sep 2004
    Nice !
  1. Anyone running a 150mm Pike on their Ripley?
    By tortfeasor in forum Ibis
    Last Post: 07-25-2016, 11:49 AM
  2. Replies: 22
    Last Post: 08-22-2014, 07:27 PM
  3. Pike owners.... what pressure are you running?
    By AZmtncycler in forum Niner Bikes
    Last Post: 01-15-2014, 02:36 PM
  4. Pike owners.... what pressure are you running?
    Last Post: 10-07-2013, 10:21 AM
  5. Replies: 2
    Last Post: 07-29-2013, 06:36 AM
