Results 1 to 8 of 8
    Jan 2009
    94 Zaskar Seatpost diameter...???
    Anyone know the proper diameter I need for a seatpost on a 94 Zaskar?
    I don't have 94, but my 93 and 95 both measure at 26mm steat post.
    Jan 2009
    I thought I had it figured out at 27.0, then I got your message, your sure about your answer, 100%? 26.0?
    I thought I found out that a 95 Zaskar was a 27.0.......
    Took off the seat post, and sir you are correct, it's stamped as 27.0. Sorry, I measured the diameter with my crappy ruler.
    Reputation: gm1230126's Avatar
    Quote Originally Posted by hatake
    If you're running a 26.0mm seat post in those you are ruining the frame.... closing the seat tube too much. I have a Purple anodized 1993 93 model built in 06 of 92 in my repair stand right now for a build up and it takes a 26.8mm. The 1995 models take a 27.0mm. Hatake you shouldn;t have to measure if the bikes came with a post and are original the seat post size should be stamped on the post at the minimum insertion line.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    Yes it was 27, an operator error in using a crappy ruler. I hope you didn't buy 26mm based on my incorrect observation.
    Rudy Project Eyewear
    Reputation: JFalcetti's Avatar
    Nope, I figured it out on my own and got sick deal on a titanium seatpost (titec).
    Keep a coat of Phil Wood oil on that post.
