Results 1 to 6 of 6
    Reputation: cmeride's Avatar
    Sep 2004
    2014 Sensor Seatpost question
    Hi there, just picked up a used Sensor and i know its a 34.9 seatpost but do you have to use a shim for a rockshox reverb dropper post ? I dont see any mfg's out there making a 34.9 dropper post ? Or am i wrong ?
    Mar 2006
    34.9 is the diameter of the outer edge of your seat tube I believe. Your seatpost CLAMP is 34.9, your seatpost is likely 31.6, which would be the inside diameter of your seat tube.. I don't own a sensor but my zaskar is this way.
    Sep 2012
    New GTs are different, the seatpost diameter is huge!
    From the specs:
    Seat Post: RockShox Reverb Stealth, 34.9mm, 125mm drop
    Seat Clamp: All Terra Alloy Bolt-On, 38.1mm
    cmeride: the Reverb is available in the 34.9mm size. Not sure where you're from but I've seen them at *Chain Reaction Cycles | MTB | Road | TRI | Run before
    Sep 2012
    For some reason sram don't have the 34.9mm option listed on the product page, but there's information about it here:
    RockShox Reverb Updates | SRAM
    Industry Loudmouth
    Reputation: ska todd's Avatar
    Jan 2003
    The MY14 Sensor & Force both use a 34.9mm post (38.1mm clamp). Droppers are available from RockShox and KS in this size (and are used oem on higher end models). If you can't find one you can use a 31.6mm post and shim it. Shims are available thru QBP that will go 34.9>31.6.
    -ska todd
    Quote Originally Posted by ska todd View Post
    QBP actually doesn't carry shims this big. USE make them and they are very nice anodized aluminum. Looks lke Chainr Reaction stocks them.
    USE Aluminium Shim | Chain Reaction Cycles
  1. 2014 GT Sensor and Force 27.5
    By NH Mtbiker in forum GT
    Last Post: 01-24-2018, 01:49 AM
  2. 2014 GT Sensor Elite demo bike
    By jazclrint in forum GT
    Last Post: 01-24-2016, 07:18 AM
  3. 2014 GT Sensor and Force 27.5
    By NH Mtbiker in forum 27.5
    Last Post: 06-19-2013, 09:01 AM
  4. 2012 Sensor 9r seatpost clamp size?
    By jvm051 in forum GT
    Last Post: 02-19-2013, 06:52 PM
  5. Replies: 0
    Last Post: 07-20-2011, 10:55 AM
