Results 1 to 12 of 12
Thread: 2009 Zaskar
    2009 Zaskar
    Does anybody have a rough idea how much the carbon zaskars weigh?
    Reputation: gm1230126's Avatar
    Not sure what they've changed on the frame for 09 but the one I have I just scaled at 61.3 ounces which is 3.83 lbs. This is an xl so I'm sure a medium would be closer to three and half ponds or a tad over that.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    XCRACER
    Zaskar 08
    This is my 08 Zaskar and as it sits its 20.61LBS. I dont think the frames have changed from 08 to 09.
    Size and specs please.
    XCRACER
    Zaskar 08
    FRAME: 2008 GT ZASKAR CARBON
    FORK: 2008 ROCK SHOX SID WORLD CUP w/LOCK OUT
    CRANK SET: TRUVATIV NIOR CARBON CRANKS
    BOT. BRK.: TRUVATIV GIGA PIPE EXTERNAL BEARING
    PEDALS: CRANK BROS EGG BETTER TRIPLE TI SHORT SPINDEL
    FRONT DERAILLEUR: SHAMINO XTR
    REAR DERAILLEUR: SRAM X.O CARBON SHORT CAGE
    SHIFTERS SRAM X.O TRIGER SHIFT
    CASSETTE: SRAM X.O 11-34
    CHAIN: SRAM HOLLOW POINT
    RIMS: STANS NO-TUBE
    FRONT HUB: DT SWISS 240
    REAR HUB: DT SWISS 240
    SPOKES: 14/15 GUAGE DOUBLE BUTTED
    NIPPLES: ALLOY
    SKEWER SUN RINGLE FLEA
    FRONT TIRE: KINDA 2.0 KARMA DTC
    REAR TIRE: KINDA 2.0 KARMA DTC
    TUBES: STANS NO-TUBE
    FRONT BRAKE: AVID JUICY ULTIMATE CARBON DISC
    REAR BRAKE: AVID JUICY ULTIMATE CARBON DISC
    BRAKE LEVERS: AVID JUICY CARBON DISC
    CABLES: AVID HYDRAULIC
    HANDLEBAR: KORE CARBON RISED BARS
    STEM: KORE RACE
    GRIPS: E.S.I. FOEM
    HEADSET: FSA
    SADDLE: SDG I-FLY I-BEAM
    SEAT POST: KORE I-BRAM CARBON
    SEAT CLAMP: ALUMINUM SEAT CLAMP
    Oct 2007
    Nice ride?
    May I ask how tall you are? I am 1.90m and some say I would need a L others say XL.
    cheers,
    Al
    XCRACER
    Size
    I am about 6'-1" Tall. I think you should ride both sizes and go with the one you like most.
    How tall is Wells? He rides an XL
    XCRACER
    Tall
    From Cycling News Todd is 6'-2". I measured last night and I my wife says i'm 6'-1 1/2" tall. So there you go.
    Alien Surf Team
    Reputation: Razorfish's Avatar
    Rocket boosters are cheating.
    Reputation: smithy's Avatar
    3.83lbs?! That's quite a "bit" over the claimed 1.2kg for a Medium sized frame...
    3.83 is for the pictured XL frame
