Results 1 to 3 of 3
    2000 Zaskar X BB size
    I need a bottom bracket for a 2000 Zaskar X frame that I just got. Any idea on what size to get for it. Is it 68x113?? I am connecting my old Race Face Next cranks to it which are a square taper. Thanks.
    Matt
    Reputation: gm1230126's Avatar
    You only size the bottom bracket shell width to the frames....so pull out your metric ruler and measure the width of the BB shell.....you size the length of the bottom bracket axle to the crank you are using...what did Race Face recommend for the Next crank vintage that you have. They had charts on their website I think they are still up. Good Luck!
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    pretty sure my zaskar-x is a 73mm
