Results 1 to 36 of 36
    Air Pirate
    Reputation: Bokchoicowboy's Avatar
    1997 GT LTS 1 pivot/bushing info
    I just picked up a 1997 GT LTS 1 frame that needs new bushings at the bottom-bracket/lower pivot as well as the upper seatstay pivots. I found a source for most of this on E-bay, as well as those neat bearing replacements made by BETD in the UK.
    I noticed the guy on Ebay has a bearing replacement kit listed, but the packaging in his pictures shows the year 1999.
    Does anyone know if this bearing replacement kit was meant to retrofit (replace) the bushings? And if so will they fit the 1997 model frame?
    Reputation: gm1230126's Avatar
    Bens Cycle in Milwaukee has both on line and eBay stores.....NOBODY has more of this stuff than VINNY. Just call and ask for VINNY. He bought pallet loads post GT/Schwinn days before Pacific took over.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    Air Pirate
    Thanks, gm1230126.
    I looked at the stuff listed on the Ben's cycle website and the parts for my year frame do not show up there. I bit the bullet and ordered the needle bearing parts from BETD in the UK. I figured it would be better to get those and have several years of quiet enjoyment out of the frame. I plan to replace the other bushings with the BETD stuff as they crap out.
    Now I have to find a 27.0 seatpost that I like.
    GT LTS Hoarder
    Reputation: johntheroadie's Avatar
    Dec 2005
    As far as I know, the 1997 LTS-1s orignally came with bushings, but they share the same suspension parts as the STS and subsequent LTS/STS bikes. Sure the frame changed a bit, but the suspension mechanics remained the same. So I'm pretty sure the newer needle bearing kits will fit into a 1997 LTS-1 with no problem.
    If you really wanna know, I have a old GT needle bearing upgrade kit (probably the same as the one you saw on ebay....they even say 1999 on the package) in my parts bin and I can give you the measurements if you'd like. I bought one set as a backup and another just for the trunion mount shock chips (those can be shockingly expensive).
    My order took awhile to ship, but BETD products are well worth the wait. My old LTS-1 had them and I NEVER serviced them because I never had to. Right now I have the upper and lower needle bearing kits in my LTS-2 and they are great as well. Just put a dab of loctite on the threads to keep the bolts and nuts from working loose.
    Oh yeah, when you find a nice 27.0 seatpost, let me know. I need one too.
    Air Pirate
    Do you know which of the bushings the needle bearing kit replaces? From BETD I ordered replacement chips, the main pivot (near bottom bracket) and the rear pivot on the linkage. The upper pivot (near seat-tube/top-tube nexus) seems mostly okay, but I would like to replace the dropout (Horst-link) pivot hardware if I could, so if the kit on Ebay will do the job I will order that as well.
    GT LTS Hoarder
    Dec 2005
    Whats the part number on the kit you're ordering? The one I have is # 280294 LTS/STS Rebuild service kit for 99. It comes with needle bearings for the upper, lower and seatstay pivots. This one still has a stainless steel bushing on the horst pivot. Is this the same one you're looking at?
    GT LTS Hoarder
    Dec 2005
    okay, I dug my old LTS out of its spot and looked at it closely. My kit looks like it will work for the lower main pivot, horst pivot and seatstay pivot. There are not enough parts to fix the upper pivot because it uses several existing parts (bolts, cone washers) on the 1999 LTS that the 1997 lacks. Sorry about the misinformation. If you got the kit, it probably will not work for all of the pivots.
    Air Pirate
    Thanks for the extensive research. I may still grab the kit. I received an email earlier from BETD. They already shipped the parts I ordered. Order was made last night. Hopefully Royal Mail is faster than USPS.
    GT LTS Hoarder
    Dec 2005
    Not a problem. If you need any help just let me know, I'll try to help you out as best as I can.
    Air Pirate
    Thanks John. BTW - do you know what size front derraileur fits on this bike? I currently have a bike tha runs a larger seatpost than the GT, so I am thinking the current bikes seat-tube is larger diameter and possibly the front derr is going to be too large...
    GT LTS Hoarder
    Dec 2005
    The seat tube is 31.8 in diameter. All of mine have top swing front derailleurs but I have gotten a bottom swing to work on my old LTS. Its a pretty good stretch but if you can get a bottom swing to work, you'll free up the water bottle mount because the front derailleur won't wind up being between the water bottle mount screws.
    Air Pirate
    On Friday I received the BETD bearing sets I ordered. Of course there were no installation instructions, so I looked at the BETD website and found some illustrated instructions in a PDF document.
    Following this, I was able to remove the old lower main pivot bushings and install the new bearing set. The instructions were not really clear where I was to place a couple of o-rings, so if anyone knows where these go it would be great. Do they go between the outer bolt and the bearing, or between the bearing and the nylon spacer (with the indentation)?
    Also, when I tried to install the bearings at the rear of the link (seatstay bearings) I had some trouble. Before removing the stock bushings this area had a tight, complete fit. When I tried to tighten up the bolts the link would tighten up only on one side, making a large gap appear on the other side between the link and the bolt, plus pushing out the bearings from their sleeve. If I tried to tighten the bolts up as equally as I could there was a gap on both sides between the seatstay and the linkage, allowing the washer to move back and forth.
    The instructions talked about fitting a 1mm washer (supposed to be included in the kit but wasn't) then tightening the bolts to "center" the link, then removing them and retightening the bolts after the centering was done. I had some M8 flat washers that filled the gap and allowed me to tighten the bolts without any bearing shift, but If I take them out again the gap/bearing shift reappears.
    Do you think I can ride with these flat washers in place between the seatstay and link? They are the same diameter as the stepped washers that press against each side of the bearings.
    GT LTS Hoarder
    Dec 2005
    I stuffed my o-rings and between the washer and bearings. I'm not sure if that's where they were supposed to go...but that's where mine went.
    I'm not sure about the seatstay bearings. My LTS-2 is a different linkage design and still has bushings there (no bearing upgrade available) and my current LTS-1 still has the original bushings in them.
    All I can provide you is a picture of my old LTS-1 that I sold several years ago. I'm not sure how it went together (or even if the bearing kit is from a BETD kit), but it was rock solid and never gave a hint of problems. Sorry I couldn't help you out more.
    Air Pirate
    Looks like a different bearing set, or at leas the attachment hardware is differrent. The BETD set for the seatstay/link have nylock nuts on the inside of the link. I'll have the bike together sometime this weekend, so I will let you know how it rides with the setup as it is.
    I had fired an email off the BETD day before yesterday but I still haven't heard from them.
    BTW - I heard people used the SRAM Jonnisnot lube on the original bushings to keep them quiet. That stuff has been discontinued. Do you know of a replacement lube?
    I also have a 1997 GT LTS-1. That squeaking is really pissing me off. I'm going to have to do what you are doing. I bought a couple "RockShox GT LTS Coupe Deluxe Shock
    Type: 1998 Coupe Deluxe 700lb 16591" from icyclesusa.com and the "GT Pivot Needle Bearings". I'm hoping that will help. I'll take pictures and post them once I get them in. Maybe we can make this thread the definitive guide to stopping the 1997 GT LTS 1 from squeaking.
    Air Pirate
    Howdy swaustex,
    The real solution to elimination of the LTS-squeek is indeed replacing the bushings with bearing sets. I finally got my LTS built up and got it out on some trails this past weekend and yesterday. No squeeks with the new bearings I got from BETD in the UK. The BETD stuff also makes the bike pretty rigid latterally compared to the old stuff.
    The only pivots that still have the original bushings are the top front and the Horst links. As far as eliminating or minimizing the bushing squeeks with a lube, I finally learned that the Jonnisnot lube was pretty much the same thing as silicone based grease, such as the 99.9% stuff you can get in some hardware store plumbing departments for use on Delrin, Nylon, and other plastic parts that cannot tolerate lithium based lubes.
    I debated pulling the pivots apart to apply some silicone grease but was afraid the really dried out bushings would just explode if I tried. So I just grabbed some pure silicone based spray lube I recently picked up to spray on my garage door hardware and sprayed some on the pivots and let it penetrate for a bit.
    No squeeks. I am going to replace the bushings on these pivots with the rest of the BETD offerings in about a month, so I figured the lubricating will do until then.
    Air Pirate
    Finally uploaded the pics of the LTS frame I picked up for $50.00
    Grubby thing:
    Tape is over the stripped bolt on the upper seat-stay linkage:
    Took the parts off of this Access frame:
    Put the parts on the GT:
    Only things new/changed are the new BETD bearings in the bottom pivot and seatstay linkages, new BETD travel adjuster chip (set for XC), NOS XT front derailleur to match the rear, and new seatpost & clamp. Polished the frame to a nice shine.
    I have had the bike out for several rides now. I am used to the difference in handling compared to the hardtail frame I was riding previously, and I have to say the LTS is a really well thought out design. The way I am positioned on the bike it handles with a neutral bias in technical stuff and downhill, and sits steady on seated uphills. I didn't have the derailleurs adjusted in right so I experienced a couple of gear jumps when I tried to climb out of the saddle, but I am pretty sure I have it dialed in now. One thing is for sure, this frame was the best $50.00 I ever spent!
    GT LTS Hoarder
    Dec 2005
    very nicely done! Congratulations on getting it together!
    One thing you can check into about those "ghost shifts" is to make sure your rear derailleur cable housing between your top tube and seat tube is long enough. If it's too short, the suspension action will put tension on the shifter cable and cause the rear derailleur to move ever so slightly. Work the bike through its suspension travel and when the rear suspension tops out watch the rear derailleur to make sure it's not causing it. I found that out when my bike shop put cable housings on my STS that were way too short and was causing the derailleur to shift. Worked fine when on the bike stand, but when ridden it would never stay in gear.
    Prone To Internet Drama
    Nov 2008
    Nice!
    I just started converting my LTS to a new 9spd drivetrain...
    SRAM 970 11-32 cog
    SRAM 971 chain
    SRAM Attack twist shifters
    Shimano LX quality freehub
    RaceFace Team 9spd. chiainrings
    It will nice to have something up to date on my bike The funny thing is I can keep up with people just fine on this bike on all but the most extreme trails. The bike does climb and handle well IMO but is a little sketchy on steep and technical downhills and dropoffs. Sure there are better bikes out there, but you still have to pedel them and keep them on the trail. I think the LTS is still a decent designed bike for most of my riding, it's not the coolest bike out there, but it's pretty cool when people see mine and say "hey what kind of bike is that" and when I tell them it's 13 years old they usually say "man, it looks brand new".
    Nov 2008
    Quote Originally Posted by Bokchoicowboy
    Howdy swaustex,
    I use Tri-Flow on my stock pivots. I have to lube them every three or four rides or I get the "creak, creak, creak". I just shoot some Tri-Flow on them, let it soak in, and wipe off the excess and it seems to work pretty good but is short lived. I hope my stock pivots last for another year or so so I dont have to shell out the big bucks for the BETD bearing kits but we will have to see. Im not really sure which pivot creaks the most since I always lube them all, but I would be interested in finding out.
    GT LTS Hoarder
    Dec 2005
    Quote Originally Posted by mojavehanna
    I get asked that a lot too out on the trails. The last comment that someone made on my LTS was "Wow, that's a funky frame!" It's ironic to me because that's how I usually describe most of today's current FS bikes.
    nothing too modern for me
    Reputation: spline72's Avatar
    May 2005
    I replaced mine 5 years ago with BETD kit on my LTS 1000 from 1997
    Heres my original 1997 LTS with a BETD complete kit on
    heres another close up of the rear end
    Also my new build NOS LTS 1000 frame built up with components that matched the intention of the frames designer, but were not avaliable when the bike was designed.
    closer detail of non standard rear pivots
    Notice the built in disc tab
    also the additional machineing to the underside of the upper pivot link,
    Also somone posted pics with rubber o rings behind the bolts that atatch too the trunion mount through the travel chips, I know they dont go there. Did you get them in a kit?
    let me know and I will have a look at mine and see where they were supposed to go.
    spline
    Air Pirate
    I would love to have a rear swingarm that has the disc brake tabs on it like you have Spline72. BETD has some sort of bolt on tab item but I cant figure out how it would attach. I don't know if I want to try the A2Z adaptor either.
    May 2005
    The orange LTS has a BETD disc brake addaptor, they do 2 types that fit onto LTS's that have 2 pre drilled into the chainstay.
    If your brave you can drill them yourself as I think one hole is pesent in all GT LTS chainstays already, but I have never owned one of those.
    You can always find a fix for any given situation, just depends if you think the reward is worth it.
    I run the original Rock Shox disc brakes on the orange one, It came with the front but i retr fitted a rear disc to it, best decision I made.
    after that there was no looking back
    Jun 2010
    Im having a fabrication/welders weld me a disc brake mount onto the rear right hand seatstay. the dropout is 6-10mm thick and the tubing at the ends is 3mm so it shouldnt be to hard. ive had to do allot of homework to find out the background around artificially heat treating aluminium frames and to find a company that can supply the solution to heat treat the area thats welded shortly after its been done. but im looking forward to fitting a disc brake to this old beast.
    ******However i cant find any catalogue images or spec sheets/lists of what spec the frame came with?? the headtube for instance is very "shallow" and i dont know what forks to set it up with (e.g. single shock 100.120,130mm or triple clamp - to the top)
    i read somthing about somone on this page saying they hav a new 9sp set up??
    i was thinking if its single clamp forks then ill set the frame up "cross country",9sp?
    But if its triple clamp forks then i might set the frame up downhill, single front chainring? -
    but will it take it??
    ****any feedback welcome****
    ps i know im mental 4 even considering WELDING mounts on but im clever enough and balls-e enough! ;-)
    May 2005
    Hear is the specifications of my LTS 1000 ds when I bought it in 1997/8.
    Colors Acid Orange, ball-burnished
    Model LTS-1000 DS
    Suggested Retail Price £3240.00
    Weight Unspecified
    Year 1998
    Brake Levers Shimano Deore XT
    Brakeset Rock Shox disc front/Shimano Deore XT V-Brake rear brakes, Shimano Deore XT levers
    Front Brake -
    Front Brake Lever -
    Rear Brake -
    Rear Brake Lever -
    Bottom Bracket Shimano BB-UN72
    Bottom Bracket Shell Width 68mm English
    Bottom Bracket Spindle Length Unspecified
    Chain Shimano CN-IG90, 1/2 x 3/32`
    Chain Size 1/2 x 3/32`
    Chainrings 22/32/44
    Crankset Shimano Deore XT, 22/32/44 teeth
    Front Derailleur Shimano Deore XT top-swing
    Front Derailleur Type Unspecified
    Handlebar Azonic riser
    Handlebar Extensions Not included
    Handlebar Stem Kore Lite 3
    Head Tube Angle 69.7
    Headset 1 1/8` threadless WTB grease guard
    Headset Diameter 1 1/8` threadless
    Largest Rear Cog 30
    Number of Rear Cogs 8-speed
    Pedals Shimano PD-M535 SPD
    Rear Cogs 8-speed, 11 - 30 teeth
    Rear Derailleur Shimano XTR SGS Rapid Rise
    Rear Shock Rock Shox Coupe Deluxe, 4.0`/5.0` travel
    Rear Shock Travel 4.0`/5.0` travel
    Saddle SDG Ventura Comp, chromoly rails
    Seat Post Diameter 31.6mm
    Seat Tube Angle 74.0
    Seatpost Kore Lite II, 31.6mm diameter
    Shift Levers Shimano Deore XT RapidFire SL
    Smallest Rear Cog 11
    Fork Crown double triple-clamp
    Fork Material aluminum/magnesium, double triple-clamp crown
    Fork Travel -
    Frame Angles 69.7 head, 74.0 seat
    Frame Construction welded
    Frame Tubing Material 6061 T6 aluminum
    Chainstay Length 42.6cm
    Fork Rake 1.6`
    Top Tube Length 58.3cm
    Wheelbase 109.1cm
    Front Hub Rock Shox
    Front Rim Mavic X517
    Front Tire Tioga Factory XC kevlar
    Front Tire Size 26 x 1.95`
    Rear Hub Shimano Deore XT
    Rear Rim Mavic X517
    Rear Tire Tioga Factory XC kevlar
    Rear Tire Size 26 x 1.95`
    Spoke Brand WTB stainless steel, 2.0mm double-butted
    Spoke Gauge 2.0mm
    Spoke Holes 32-hole
    Spoke Material stainless steel
    Spoke Nipples alloy nipples
    Spoke Type double-butted
    Available Sizes 14.5`, 16`, 18`, 19`, 20`
    Brand GT
    Component Group Shimano Deore XT
    Fork Rock Shox Judy XL
    Frame Material Aluminum
    Hubs Front: Rock Shox, Rear: Shimano Deore XT
    Rims Mavic X517
    Tires 26 x 1.95` Tioga Factory XC kevlar
    Type Mountain
    Recommended Use -
    Suspension Full Suspension
    It's more than possible to run a triple crown fork at the front as long as you don't go too long with the fork, mine has a travel of 100mm for the original LTS with the triple clamp Judy XL's and then the pikes on my new one at 145mmm to 100mm tunable, single crown.
    Any thing longer than that can make the bike feel a bit too tall, a mate of mine bought a second hand LTS fitted with more recent boxxers on it & it felt a bit chopperish to ride & a bit too tipped back over the rear wheel.
    As far as gearing goes I have 8 speed & a 9 speed setup and prefer the 9 speed setup,
    just depends on your requirements I suppose.
    good luck with it & post some pics when its done.
    Quote Originally Posted by Garsarrow
    If you put them on the "rear right hand seatstay" you are mental.
    GT LTS Hoarder
    Dec 2005
    Quote Originally Posted by gm1230126
    You'd be even more mental if you were going put it on the right hand chainstay and just ditch the other side. Remember GT's single sided swingarm prototype back in 1999?
    Attached Thumbnails Attached Thumbnails 1997 GT LTS 1 pivot/bushing info-gtblue.jpg
    1997 GT LTS 1 pivot/bushing info-gtblue2.jpg
    Jun 2010
    Errrrrr. . . . . . . .i meant the left side!! on the fabricator hes changed his mind and now wont do the job!
    he says the tubing is tooo thin but i measured it and at the dropout end is 3mm (there are two small holes either side of the inside seatstay dropout ends) and the dropouts are between 6 and 10 mm.
    I was told if the welder heats the dropout 1st (thicker part of the weld) then wen they weld the bead along the disc mount it will enable the dropout to melt/weld at the same temp as the thiner tubing
    (the disc mount will be of the same material and in between the thickness of the dropout and the tubing)
    Jun 2010
    here the frame, like new, 1 mark/dent/scratch? the rest is completly untouched! picked it up 4 a bargain too
    Attached Thumbnails Attached Thumbnails 1997 GT LTS 1 pivot/bushing info-gt-lts1b.jpg
    1997 GT LTS 1 pivot/bushing info-gt-lts1a.jpg
    Reputation: SuperJETT's Avatar
    I just have to post as I bought a mid-90's GT Strike yesterday from a guy who had it in his garage untouched for 12 years. He just doesn't ride anymore. When I was leaving, his wife mentioned the mountain bike they need to get rid of before move as well so I took a look and I'm almost positive it's one of these, polished aluminum and everything.
    Looks cool, but I think I'll stick with my KHS, though I did get the Strike for a steal at $180 with Dura Ace/600 components in excellent shape.
    KHS
    Motobecane
    Fisher
    Kona
    GT LTS Hoarder
    Dec 2005
    dude, where are you at and do you have any pics?
    I don't have any pics, but I just bought the road bike yesterday and could give you their e-mail if interested. The front wheel was off and I really only looked at it for like 15 seconds but it was polished aluminum with the funky rear shock suspension and bright yellow stickers.
    KHS
    Motobecane
    Fisher
    Kona
    An original GT Strike from the 1995 GT Road Bike catalog.
    Attached Thumbnails Attached Thumbnails 1997 GT LTS 1 pivot/bushing info-page-10.jpg
    Oh...and an early original 95 GT Fury for you boys that are too young to know better and think it's a fat tire flyer
    Attached Thumbnails Attached Thumbnails 1997 GT LTS 1 pivot/bushing info-page-5-2-.jpg
    GT LTS Hoarder
    Dec 2005
    Quote Originally Posted by SuperJETT
    ah i guess that's okay. I'd only be interested in it if I could scoop it up for cheap, if it was my size and and it was in really good condition. I spent plenty of time on skinny tired bikes too. Matter of fact, I still have some friends that are trying to get me back into road riding....
