Results 1 to 9 of 9
    Reputation: mrjustin007's Avatar
    1992 GT Richter 8.0 Help
    Looking for source for a derailluer hanger, front derailleur size and size for seat collar.
    Thanks!!
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    try http://derailleurhanger.com/ and you can have the LBS measure for the seatpost clamp size and derailleur clamp size
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: gm1230126's Avatar
    Quote Originally Posted by mrjustin007
    Thanks!!
    If a 92...you need the derailleur hanger with the small finger that sticks up? If so retro supply on eBay has them listed for around 25. It's a steel frame so the front derailleur size is 28.6mm as is the seat collar. Hope that helps......need a picture?
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    If this pic (lower right corner) is what you need for the hanger...retro supply on ebay. Derailluerhanger.com doesn't stock this one....unless they just added it....I've been telling Wheels Mfg for four years that they should start making it.
    Thanks GM - that one on the Bravada looks right. At $25 that hanger is more than I paid for the frame.
    question: Is there some kind of yoke for the front derailleur cable?
    yes there was but they are near impossible to find. It fit between the seat tube and the bridge... just use plastic cable noodle and make sure the cables not hitting the paint. That's the way I have my Psyclone set up....it works fine.
    Is the plastic cable guide for the u brake the same thing? I have one from a Karakoram, but the Karakoram is pre-groove tube.
    Reputation: kikaha's Avatar
    Feb 2007
    one of my gt faves...................
    Quote Originally Posted by gm1230126
    Would the seatpost be 28.6?
    WTB: Bontrager Comp Fork & Syncros metal top cap
