Page 8 of 9 FirstFirst ... 456789 LastLast
Results 701 to 800 of 806
  1. #701
    Oct 2010
    Just moved to Norman from Florida and been out to Clear Bay trails the past couple weekends. I was thinning about heading out to Roman Nose this weekend. I wouldn't say I'm in the best riding shape, but i'm not a couch potato, lol. How difficult are the climbs?
    Thanks for any insight.
  2. #702
    Combat Wombat
    Reputation: BrianU's Avatar
    Quote Originally Posted by evilazonic666 View Post
    This is exactly my point...... If we were to continue keeping the trail technical and therefore fun, we'd be at much less risk of loosing it to the ground pounders. I mean they already ***** at us for riding the proper direction when they insist on running against traffic, but being that whomever maintains these trails insists on taking the easy way out and trying to please everyone, they are simply going to run off the primary intended crowd(us). And, when it comes to the constraints of time and sometimes money to be able to afford to go long distances to ride the better areas, we are forced to either not ride or ride in areas that do not meet a standard that is fun anymore..... Very dissapointing. Sounds to me like we need more footballs and fewer gorillas.....lol. I do understand the appeal of a multi use trail but in the end, you have to please everyone, and at this point they seem to be trying to cut certain groups out.......
    I guess I am still bitter from when I used to live. I came from Philly. We HAD one of the largest in city parks in the nation. We had everything from xc race trails to full on dh trails. We lost more than half to the equestrians. It came down to who had more money and could sway the park and rec board..... Ugh.
    The primary reason for changes to the trail in the last several months has been exactly what gt jorgito mentioned, maintainability. And in this case, it was all about the bridges. How many of you knew that there were a total of 14 bridges on what we call the Bluff Creek trail? I was even surprised to here that when the city brought that up during one of their walk arounds of the trail. They were not so much as concerned about the number of the bridges as to how capable we were of staying on top of the upkeep. OEF is legally liable for man made structures. As much fun as they are to build and add character to the trail, maintenance can really start to eat up volunteer time, especially the older bridges. The bridge we removed and replaced last month was in real bad shape and a real ball buster. Anyone involved in that process could understand why we want less bridges. At the same time, the majority of the trail re-routes made this past year have been to tie back into and utilize as much of the existing trail system as possible after removing many of the bridges. We are definitely not taking the easy way out and trying to please everyone. If I were going to take the easy way out, I would just spend all my time riding and just let someone else worry about what happens to the local trails. And if there is one absolute truth to any volunteer work, there is no pleasing everyone.
    There was a time when mountain bikes were prohibited from the trail in Bluff Creek and from your experience in the Philly area, you know that no matter how many people ride a trail nothing can be taken for granted.
    OEF President
    Brian Urquhart
  3. #703
    Mar 2012
    I do appreciate your response. The features that had myself and my riding partners upset were sectionswhere there were multiple lines, in an essence being able to have varying levels of difficulty through them, and now they seem to be smoothed over for ease of riding....... The bridges I totally agree with. Some of them were getting pretty haggard. But alas, as it was posted before I shall continue to ride while I can, in case one day the spot is taken away....... There is still a few areas that are very enjoyable anyway.
  4. #704
    Can someone help me with a problem? I am confused to why air is leaking out by the valve on my rear tire? I was gonna take the tire to a shop to figure it out but I can't take all that stuff off and put it back together right. Any ideas?
  5. #705
    Mar 2012
    Spray the suspected area with a spray bottle full of soapy water..... Find the problem almost instantly
  6. #706
    May 2012
    Quote Originally Posted by Xmahatma_405 View Post
    Check with your local bike shop if they have beginner maintenance classes. Changing tires/tubes is something every biker should know.
    You could also try putting slime in the tire if you don't want to remove the tube.
  7. #707
    Changing tires on a bicycle is one of the easiest things to do. Taking the wheel off the bike is harder than actually changing the tire.
    How to Change a Mountain Bike Tire - YouTube <- that might help you out.
    As far as finding the leak there are a couple of easy ways.
    1st: Take a spray bottle (like Windex comes in) and fill it with water and a couple of capfuls of dish soap (palmolive for example). Inflate the tire to a high pressure, not to high bt enough to make sure it can leak and still have decent pressure. Spray the tire including the outside of the valve stem and the valve core itself down liberally with the mixture. Look for bubbles. Once you find the source of the bubbles youve found your leak.
    2nd: Fill your bathtub up with cool water (try to get it about room temp, it probably doesnt matter but for a small enough leak cold water could make the rubber contract and potentially seal the leak). Again, over inflate the tire/tube assembly. Dunk the tire, valve stem down, into the water and look for bubbles. Rotate the tire slowly about 45 degrees at a time until you are back around to the valve stem looking for air bubbles.
    I do both methods without taking the tube (well i have tubeless now but yeah) out due to the fact that if I have a bad valve core thats leaking I can find it and replace the core without ever dismantling the tire assembly. Saves you a few minutes and some effort, along with the possibility of pinching a hole in the tube.
    2010 Giant Yukon FX
    Pure XCR Wheelset/Geax Saguaro Tires/Tubeless
    Bike Weight Lost: 2.48lbs (1124g)
  8. #708
    Reputation: KEITH21's Avatar
    Big thanks to the draper crew, looks like they have been shoveling sand off the trail. Just wanted to say Thank you to all who are out there working.
  9. #709
    Reputation: BoomerBrian's Avatar
    Anyone ride Draper today? Was going to go but wasn't sure how much rain they had over there.
  10. #710
    Reputation: ChrisMc73's Avatar
    New Bike Shop
    Anyone bee in the new bike shop off McArthur near Memorial Rd, named Charley's Bike Laboratory or something like that?
    I peeked into the window on Sunday, they are a Specialized dealer.
    Shop looks nice.
    Just curious.
  11. #711
    May 2012
    I wasn't aware of Charley's Bike Lab since I don't get over to OKC real often, especially that far north. I found their website with a google search, but I can't post links with my low post count. ( charleysbicyclelab.com ) Looks like a nice shop.
  12. #712
    Psycho Killer
    Reputation: Johnny Nitro's Avatar
    May 2012
    Idea!
    Quote Originally Posted by YukonDave View Post
    I have a co-worker who speaks highly of Charley's. The co-worker is an avid MTB'er and said Charley was a first-class mechanic for Schlegel's before he went out on his own.
  13. #713
    Jun 2012
    Anyone know why there's not a shop in Yukon? It seems like there are enough riders around the area...
  14. #714
    Probably because the city is over saturated with shops and its not that far away. If I had to guess.
    2010 Giant Yukon FX
  15. #715
    May 2012
    I would love to see a bicycle shop in Yukon. But I don't see it surviving for the reasons SuperSlow35th stated. Also if other riders are like me, once I'm set up I don't visit a bike shop very frequently throughout the year.
    But if a shop did open up in Yukon I'd make a point to visit often and buy things.
  16. #716
    Jun 2012
    Are there any group(s) of riders on the west side of the city? I'd like to get a group of consistent riders together for some longer rides and also maybe some traveling.
  17. #717
    Jun 2012
    im n Piedmont. Just getting back into riding. Ive got a couple buddies that i used to ride with quite a bit that are getting geared back up as well. Im building a singletrack at my house. i might be looking for some guys to come out and ride it soon to get it in shape
    later
  18. #718
    Just ride.
    Reputation: OK_MTBer's Avatar
    Full advocate for Charley's. They have exactly what I look for in a shop, owners who have experience in every discipline of cycling and want to share their knowledge. It's rare you'll find a shop that will tell you how to fix something on your bike and even order the tools for you if you want to do it on your own. I respect that.
  19. #719
    Mar 2012
    For those of you who ride draper, how many of you ride the red section, the jump lines, pounddog play ground, and huckleberry hound, and.back in black?
  20. #720
    Im sure every one does... Great fun just not for me.... Ive never been a big jumper
  21. #721
    I havent had the cojones to ride the beginning jump line on black yet. The rest of it, aside from the tall log, I can just blow through. I love the jump line on red.
    2010 Giant Yukon FX
  22. #722
    Mar 2012
    The initial jump line in black seemed easier to me than the jump line in red..... Just going off gap size. Though red was a lot easier to get speed ......either way, I was thouroughly impressed by the jumps and terrain in those sections. Much better than I expected.
  23. #723
    Well Ive personally watched someone snap a collarbone on the jump line on black. So I'm a little gunshy.
    2010 Giant Yukon FX
  24. #724
    Mar 2012
    I could understand that....... That's one reason I'm always a little sketchy on larger gap doubles.....
  25. #725
    Reputation: Naturally Aspirated's Avatar
    Thread revival!!! Plus I figure I should post this from the OEF website for all you Draper riders on here...
    "The quarterly membership meeting will be 7:00 PM Thursday, 2 August at Lake Stanley Draper Trails. We’ll have a brief meeting at the picnic table area, followed by a group ride.
    If you’ve never been to an OEF meeting, are a regular member, or are thinking of joining, this is a great opportunity to get out and meet the membership of OEF, and get some fun riding in as well.
    See you there!"
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  26. #726
    Combat Wombat
    Quote Originally Posted by Naturally Aspirated View Post
    See you there!"
    Thanks for the plug on the meeting! Right now it seems like everyone and their brother (or sister) is heading out of town this week for some sort of summer vacation, but we will still be able to talk about a few upcoming events, answer any questions we can, and most importantly.....will be a good excuse to go for a ride. Hopefully by 7:00pm, the temps will have dropped a little.
    Brian Urquhart
    OEF President
  27. #727
    I'm usually there at that time anyways so I will be there. I know Bill is heading out this weekend as well as I. Brian, I don't know if we've met, but I've been clearing the sand and redigging the niches in the entrance area, and I'm now working on blue.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  28. #728
    Kinda off topic but great news guys. I got a new job that im starting in the next few months with higher pay and less hours. More bike goodies and more time to ride.
    2010 Giant Yukon FX
  29. #729
    Congrats! More time to ride is always a good thing!
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  30. #730
    Definately. Ive been neglecting my bike lately.
    2010 Giant Yukon FX
  31. #731
    Combat Wombat
    That old dog told me Monday night he is going to be in Ocean City for a family reunuon and he also mentioned that he had someone helping him working on the sand. I wondered who he was talking about and thanks for your hard work. We have probably crossed paths at one time or another. I have been riding every Wednesday, usually heading out about 6:00pm and then hanging out with those that do the crit afterwards. Riding group varies , but almost always riding with Shane J (Bluff Creek Trail Boss) and Buella (his dog). I think I am the only one in the OKC area riding an orange Vassago Jabberwocky and an orange On-One Inbred.
  32. #732
    May 2012
    hey dudes, im new to mtbiking and recently rode my first trail.. bluff creek.. i have been back 5 times now haha!!
    I always move over for you guy, you seem to blow past me!
  33. #733
    Awesome Cisc! Bluff Creek is my trail of choice since I live about 10 minutes from it and Draper is just not the trail it used to be for me. I do wish Bluff was a couple of miles longer but I won't complain since the guys have kept it in great riding condition since I can remember. I've been mountain biking since 1998, bluff creek was my first trail. Don't worry about getting passed, soon you will be out there ripping it up like everyone else.
    Still loving my GT's!! find me on the "GT Bike Group" page on FB. I hardly ever hang out in here anymore.
  34. #734
    Reputation: jpatt28's Avatar
    Took my dog to bluff today for the first time and he crushed it. Although he was a little tired at the end, he still managed to get through it. I love that trail, so far my favorite one due to the terrain.
  35. #735
    OKC Trails Question
    I'm from Tulsa and have been riding mountain bikes for about three months now. I've spent most of my time up at Turkey Mountain. I visit the OKC area pretty frequently because my parents and in-laws live in Newcastle. I've got to come down for the weekend in a week or so to celebrate family birthdays and thought I might bring my bike. Where would be the best place to go for someone just visiting and who doesn't know the trails? From Newcastle, both Draper and Thunderbird are pretty close. Thanks for any info!
  36. #736
    Quote Originally Posted by markch View Post
    I would recommend Draper. Last time I rode TBird it was a bit overgrown and the ticks were horrible. Draper is also better marked.
  37. #737
    Quote Originally Posted by BoomerBrian View Post
    Also clear at is a lot more technical. With draper you would have multiple trails all marked.
  38. #738
    Thanks, guys!
  39. #739
    Just rode Roman Nose. That was a great ride with some nice tech spots. Got out just before the rain. Oklahoma City Area Riders-imageuploadedbytapatalk1345310223.915405.jpg
  40. #740
    Rode Clear Bay tonight to change things up and it was horrible. It is overgrown and the sand is out of control. No wonder I was the only person there.
  41. #741
    That's very unfortunate...... i was hoping to get out there next week
  42. #742
    Reputation: dmboarder's Avatar
    Jan 2011
    It's not that badly overgrown. You should have seen it a few months ago. It's really good, considering there's only one guy that I know of who has been doing any trimming. The sand is really bad in spots, yes. Especially the first part until the fire road/bench. After that, it's bad, but not much worse than normal, except for a few little spots. It either needs a big time rain or some people to go rake sand. That's the main problem, there seems to be no one doing upkeep, unlike Draper, etc. If it wasn't for that one guy, who isn't even a part of the group that supposedly does maintenance, it would be almost unrideable. The best part about it is that the ticks seem to have chilled out for the summer.
    There was a ton of people riding and hiking Monday, even though it was blazing hot.
  43. #743
    Quote Originally Posted by dmboarder View Post
    Compared to say Draper it is horrible. I was riding it this spring and stopped because of the ticks and it was really overgrown then. May give it a try again this fall after a few rains.
    Kudos to whoever is trying to keep it up but there no way one person can take of clear bay. Is the track not part of the state park?
  44. #744
    May 2012
    arcadia blows
    Sand prevails at arcadia. Right when you may have some fun speed, blam... sand.
    Bluff nice. Some technical areas. Slow switchbacks... no speed allowed due to these tight switchbacks.
    Got my cardio up, so now im going to make the rounds...
  45. #745
    May 2012
    arcadia blows
  46. #746
    I get pretty good speed at Bluff...
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  47. #747
    Jan 2011
    Yes, compared to Draper, Clearbay is really bad. Summer is always awful with the ticks and short of fumigation I don't know how that could be remedied. There's enough non-sand part to make it a good ride, though. A couple of places could use some chainsaw work. Supposedly, BLN is responsible for upkeep but either there is not enough of them to do it or they just don't, at least not in the summer. Fall, winter, and spring the trails are always in great shape, though.
  48. #748
    May 2012
    sounds good
  49. #749
    Sep 2012
    looking for group rides. not the fastest pace, but open for some technical sections.
    chris<pixelmonkey>
  50. #750
    Combat Wombat
    Quote Originally Posted by pixelmonkey View Post
    chris<pixelmonkey>
    Myself and a few others meet up at Draper every Wednesday evening for a group ride, heading out on the trail about 6:00pm. Numbers vary from a just a couple riders to eight that showed up last week. Pace depends on who is riding. The group usually spreads out and then we stop at the beginning of the different sections, giving everyone a chance to regroup. I also post on the okearthbike.com forum. You can also find information there on another group ride done every Tuesday at Outlaw Creek on the Northwest end of OKC, near Piedmont. You are welcome to join us here at Draper, just look for the guy in the parking lot with the orange Vassago.
    Brian
  51. #751
    Quote Originally Posted by BrianU View Post
    Brian
    Ill try to make it out on Wednesday I need to try out my new bike..... how long do the rides last should I bring my lights?
  52. #752
    Brian
    Do y'all ride the crits? I can never make it but have been trying to work on my speed in those sandy corners. I will try to make it this Wednesday hopefully if work is not busy.
  53. #753
    Combat Wombat
    Quote Originally Posted by DAnREal View Post
    How long it takes us to complete a lap typically varies depending on who is in the group and how many times we stop to BS. With the daylight getting shorter though and not quite dark enough for lights, I am planning on getting back to the parking lot before it gets dark. Should give us an hour and a half riding time. We also usually sit around in the parking lot and have a refreshment or two afterwards.
    We actually started riding every Wednesday last Fall with night riding, so pretty soon we should back to running lights from the parking area.
    You get those wobbly wheels fixed?
    Brian
  54. #754
    Combat Wombat
    Quote Originally Posted by jpatt28 View Post
    The crits are over now that the Tour de Dirt has started the second half of the season and those sandy corners have also always been my nemesis. Even though we do not leave anyone behind, between the stops, a few really hammer sometimes. My goal is to someday make Bill D suffer, although right now that pretty means just not letting him pass me.
    Brian
  55. #755
    Brian
    nope not yet.... they aren't horrible but enough for me to be bothered with.... I was gonna stab at them this weekend just skeptical about it cause for me normally when I work on something ive never messed with before things usually get worse before they get better
  56. #756
    I wasn't abke to make It out tonight I was waiting for some parts to come in ill be out there tomorrow evening (at least i plan on It) with new race face bash guard installed
  57. #757
    Ive been slacking on my riding lately. had alot of family stuff going on and ive been playing soccer every saturday. Hoping to get back out this weekend. Havent even gotten the wife's "new" bike dirty yet.
    2010 Giant Yukon FX
  58. #758
    And I think I need to stop riding everyday or something. I'm feeling burnt out at times...
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  59. #759
    Anyone racing this weekend?
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  60. #760
    Mar 2012
    Bet your ass I am! Superfreakyflo here I come
  61. #761
    Sweet! I'll be shooting that race, but doing the RDR race the next day.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  62. #762
    Mar 2012
    Right on. I'll see you there!
  63. #763
    Mar 2012
    For those of you who ride draper, what do you use for chain lube? I've tried all kinds of dry products and still can't keep the sand out. Getting ridiculous. Been through 2 chains in 5 months, just put my 3rd on. Im sure being on a ss it doesnt help mashing and all, but come on. There has to be some magic lube that actually works out there....
  64. #764
    I'm not racing the flo but am taking my boy to watch it. Haven't decided if I'm racing the xc yet.
  65. #765
    I've been using Rock 'N' Roll gold chain lube. Probably not the best, but it seems to be working.
    jpatt28 you should do the XC race. If you haven't prerode the course yet, it is fast and fun!
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  66. #766
    Just found out the Felt demo truck is gonna be at Bluff Creek on the 30th at 3PM. They will have both mountain and road bikes!
    This will be your chance to test ride a different bike for free lol.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  67. #767
    ^Thats pretty cool I might have to go check that out. I used to have a Felt bmx frame but ive never ridden any of their other stuff.
    2010 Giant Yukon FX
  68. #768
    Combat Wombat
    Draper SFF and RDR Races October 20 and 21st
    I want to remind everyone about the Super Freaky Flo and Red Dirt Rendezvous this coming weekend.
    The Super Freaky Flo will start at 11:00am and run no later than 2:00pm. During this time, The Black, Blue, Red and Green sections will be closed for this event. Please put the word out. This event will be taking place primarily on the north side of the park. We will have the entrances blocked and marked, but there always seems to be at least one person that feels entitled.
    I understand that this is an inconvenience, but please keep in mind that these events provide the majority of the operating funds required for the maintenance and upkeep of our trails.
    The entire park will be closed for the RDR on Sunday, but with the level of traffic on the road and parking lot, we typically do not have problems with somebody not knowing what is going on.
    This will be a first for an event like the Super Freaky Flo. Even if it is not your thing, I bet it will be fun to watch.
    Also Carl will be out there for Trail Aid. If you have yet to buy a raffle ticket for a shot at a 2013 Giant Anthem 1, here is your chance.
    Find more information on the races and the Trail Aid here OEF | Oklahoma Earthbike Fellowship
    Hope to see you there!
    Brian Urquhart, President
  69. #769
    Mar 2012
    Wow. The superfreakyflo race was soooo fun. Very well put together. Mad props to James and Ryan.
  70. #770
    For ya'll that missed out on a good time, check out some of the pics I posted on the OEF forum!
    OEF okearthbike.com Forum &bull; View topic - Super Freaky Flow! Lots of Pics!!!
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  71. #771
    To everyone who put time in preparing Draper for the race, thanks. Draper is in the best shape I've ever seen. Just wanted to say THANK YOU!
  72. #772
    Combat Wombat
    Quote Originally Posted by KEITH21 View Post
    Your welcome! The RDR is our primary club fund raiser every year, so we spend a crazy amount of time preparing. Bill D and a few others were out there practically every day for a couple weeks out.
    Its getting about that time of the year, had to use the lights last night for our Wednesday night ride. When are you coming back out to join us?
  73. #773
    I second that. I had a blast in the race Saturday and walked away with a couple prizes and a great oef t-shirt. Can't wait to win that bike
  74. #774
    Oct 2012
    Thought I would drop in and say hello in this thread. I'm from Ada, and am just now really getting into cycling. I've had a Trek 4300 for a few years now that i've ridden on a few park trails and will be upgrading to something different soon. Anyhow, I'll be riding at my local trails for the most part, but will definitely make it up y'alls way from time to time. I wish I would have joined this forum a week earlier; it would have been a good time coming out to the event y'all just had.
    Since I'm just now really getting into this, if any of you have any advice, (where to ride, safety gear, etc) please let me know. Thanks.
  75. #775
    Last race tomorrow in Stillwater. Who's going?? I'll be there to race for my second time and of course win my new bike!
  76. #776
    Combat Wombat
    I'll be there helping with the TDD setup.
    That is one sweet bike and I would love to throw down some cash and buy several tickets, but I think it raise a few eyebrows if I won it.
  77. #777
    Hey Brian can you pm me directions. I know how to get to Stillwater but am unsure where to go from there. Thanks
  78. #778
    I'll be there. And jpatt28, I already called dibs on that bike...
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  79. #779
    Combat Wombat
    Was asked about directions to the race in Stillwater, so I thought I would post this for everyone.
    Event Flyer
    McMurtry Madness
    Directions
    OEF | Oklahoma Earthbike Fellowship | Trails | McMurtry Lake (West Loops)
    The race is on the east side. Scroll down to the bottom of the map page and you can enter a starting point and get directions. Once you have the "driving directions", click on the "view larger map"
    See you all up there.
  80. #780
    Thanks Brian. Giving myself an hour and half to get up there.
  81. #781
    Had a great time today at the last race. Probably needed to ride it before I raced it but oh well.
    Looking forward to starting the next series already as I just got into this sport. I will definitely be looking forward to more work with OEF and trail rides.
  82. #782
    My little sis won the Women's Cat 3 19-39 class today. Shame I was at work all day. I'll be riding turkey mountain tomorrow morning for my only day off this week though so that should make up for it.
  83. #783
    Combat Wombat
    This Wednesday evening starts the beginning of our weekly "Draper Wednesday in the Woods" night ride. We will be meeting in the parking lot and hitting the trail sometime around 6:00pm. Casual, no-drop ride ride with the pace depending on who shows and how energetic we feel.
    If you do not have lights and would like to give it a try, let me know and you can borrow my bar mount light.
    Look for my green Nissan Frontier truck and orange Vassago single speed in the parking lot.
    Brian
  84. #784
    Jan 2011
    Put a couple rides on your calendars:
    Tom's Turkey Day Ride, Nov 22, 8:00 am. Why do a lame-o 5K turkey trot on Thanksgiving morning when you could ride at Draper? There will be a road ride for those so inclined and a lap (or two) around the trails for the mtb crowd.
    Winter Solstice Ride, Dec 21, 7:00 pm. Celebrate the Winter Solstice with a night ride. It's great fun to see a long line of lights snaking through the trees. Mead and revelry, pagan-style, will follow.
    Both rides will be cool for all skillz levels. Come on out.
  85. #785
    Combat Wombat
    Sounds like a great time! I am usually out of town on Turkey Day, but will definitely make plans for the Winter Solstice Ride.
    Would you mind if I mention this ride over on the OEF forum?
    Brian
  86. #786
    I'll be at Tom's Turkey Day Ride, but won't be able to make the Winter Solstice Ride since I have no lights.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  87. #787
    Jan 2011
    Get Some Lights!! hehe
    Yes, definitely mention it over there. I put it on the Tour De Dirt FB page, too.
  88. #788
    Combat Wombat
    Bluff Creek Wednesday in the Woods.
    We are going to mix it up a little and until further notice, move the Wednesday evening ride to Bluff Creek. I am not sure how long it will take me to get from where I work on HW9 to Bluff with the evening traffic, but we will go ahead and still shoot for meeting in the parking lot at 6:00pm. Also if anyone else would like to make the ride and needs a little more time, give me a heads up and we can work something out.
    Everyone is welcome and this is a no drop ride. No race training laps here.
    Hope to see you there,
    Brian
  89. #789
    Good morning,
    From the look of things, my work is going to take me out from Cali to OKC from March to September. No idea yet if I'll have the opportunity to take a mountain bike but hopefully I'll find a way to make it happen.
    I'm pretty badly out-of-shape after juggling work and law school for four years and don't have much in the way of technical skills, so mostly I'm looking for trails or fireroads that feature a big workout (say, minimum 1 hour / max 5 hours) as opposed to techy stuff.
    Could you give me a recommendation a good place to pick up reading on the trails? Are any of them plotted on OpenCycleMap or AccuTerra?
    Thanks kindly.
  90. #790
    Jan 2011
    Draper. It's not technical at all and you can do however many laps you need to to get the workout.
  91. #791
    Draper and Bluff Creek will be a great place to start and then once you get your legs conditioned and need some more technical stuff go hit up Clear Bay out at Thunder Bird Lake in Norman, OK.
    Feel free to keep everyone posted when you get here and we can help you find some group rides.
    hope this helps,
    Josh
  92. #792
    Combat Wombat
    xxx
  93. #793
    Combat Wombat
    OK...Let's see if I can get this right this time. We will be doing the usual Wednesday evening ride at Draper this week. At the request of riders last week, this week we are going to run it backwards. If you have never done this, it makes for an entirely new trail. We will head out about 6:00 pm, however since it is getting to where there is still some light left at this time of day, we will start off by first cutting over to the yellow and running it in the normal direction. By the time we finish this loop and roll out on the south easement, it should be dark enough that we do not have to worry about running into other riders without lights. We can then cut back east and ride into the green exit. This will be a casual pace, no-drop ride and everyone is welcome to join us.
    Hope to see you there.
  94. #794
    guys mind doing a bit of a techno rain dance so clearbay gets a nice soak before uno mas
    kthx
  95. #795
    Jun 2013
    Hello OKC riders! I just moved into town. After inquiring with several people about the mountain biking scene in town, I had almost lost hope of doing much riding here (of course they were not riders themselves). I am very happy to find this thread, and look forward to exploring these trails. If anyone is planning on riding late afternoons, or this weekend, shoot me an email. I would love to tag along. I hail from TX, and have done most of my riding in San Antonio and Austin. I like technical or fast, but at this point I just want to get out there and ride! Thanks
  96. #796
    Come to draper lake mtb trails tonight at 7pm and join us on our free crit races.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
  97. #797
    Jun 2012
    Are you riding this year?
    Brian
    Is anyone riding nights still?
  98. #798
    Combat Wombat
    Quote Originally Posted by Yukon29&single View Post
    I will not be out there tonight due to personal business I have to take care of, but plan to be out there next week. I post the ride up on the OEF forum, okearthbike.com
    Brian
  99. #799
    Jan 2011
    Monday at Draper is the Bike One ride.
    Tuesday at Draper is the Tuesday Night Draper ride (original, huh?)
    Thursday at Tbird is the (wait for it) Thursday Night Tbird ride.
    Get some lights and come on out.
    Also, Thanksgiving morning is this year's Tom's Turkey Day ride at Draper, while the Winter Solstice ride is December 21. Last year we had over 50 people at the WS ride and it was really cool.
  100. #800
    Reputation: BigHit-Maniac's Avatar
    Well found out a few days ago, that I have orders to Tinker AFB. So, the family & I will be moving to OKC April/May of 2014. I sure hope the biking there is decent... My family is currently in Las Vegas, and I'm in South Korea finishing up my short tour....
    You in Oklahoma City? If yes, come ride with us.
