Results 1 to 16 of 16
    Apr 2014
    Stan's Grail and 42c tires, possible?
    Anyone running 42c tires on Grails?
    Stan's website says up to 40c, but looks like others are running wider with no issues.
    I wanted to use WTB Resolutes, which are 42c.
    Nov 2013
    https://weightweenies.starbike.com/f...36644&start=30
    Down toward the bottom of that page, there's a 42mm Gravel King comment.
    Apr 2014
    Quote Originally Posted by tangerineowl View Post
    Nice!
    Thanks for the link. Look like I'm good then.
    mbtr member
    Reputation: scottzg's Avatar
    I don't have any experience at all with the gravel king, resolute, or grails.
    There's a couple issues. The most obvious is that tires dramatically wider than their rims have a lightbulb shape and they handle funny. More significantly, some tire beads err on the tight side and some on the loose side. The difference is less than a mm, but at high pressures (and especially with lightweight noodly rims like grails) that can lead to a sudden blow off under the right circumstances.
    As a bigger guy whose experienced multiple blow-offs on supposedly compatible mtb tires/rims, the thought of a blow-off on a road/gravel bike is terrifying. I wouldn't assume that since a oversize tire from a different manufacturer was ok that anything similar was alright. 2mm of advertised width is meaningless, it's not even the etrto measurement.
    I don't mean to be some nannying ninny, just be careful.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Im rolling 43/48c on crests..
    mbtr member
    Quote Originally Posted by jrm View Post
    Crests are a mtb rim. Road tubeless rims are designed around higher pressures and aren't so worried about a wide tire pulling the bead hooks outward.
    Mikhail Kalashnikov
    Reputation: Chippertheripper's Avatar
    Sep 2014
    Iím pretty sure I had 45c riddlers on my grails when I had them without any issues whatsoever.
    I now have a set of the new crests. Less aero, but way lighter.
    jrm
    jrm is offline
    Quote Originally Posted by scottzg View Post
    yup and with smaller tires i use tubes...YMMV
    Sep 2014
    I donít understand this. Crests are wider, and both are rated for the same tubeless psi.
    mbtr member
    Quote Originally Posted by Chippertheripper View Post
    They are not rated for the same size tubeless psi at anywhere close to the same size tire. Crest is rated for up to 40psi and a 64mm tire, Grail is rated for up to 116psi and a 32mm tire. Completely different.
    Ignore the manufacturer's recommendations at your own risk.
    Mikhail Kalashnikov
    Sep 2014
    116psi is for a 23mm tire.
    For 32mm+, youíre looking at 45psi.
    Which, from my seat is close enough to being the same as a crest, since the op was asking about a 42ís.
    mbtr member
    Not sure why you're struggling with this. Tire pressure loads a rim in a different manner than tire width. Make assumptions at your own risk.
    Mikhail Kalashnikov
    Armature speller
    Sep 2004
    I used to run 26" Roval Control SL rims with a 16.5mm inner width with 2.25" tyres no problem.
    They were designed for 1.9-2.25".
    Now my road rims are wider and I worry about 32mm tyres being too big...
    Reputation: SLCpowderhound's Avatar
    Currently running Resolutes on Grail rims, no problem at all.
    Sent from my Pixel using Tapatalk
    Apr 2014
    Quote Originally Posted by SLCpowderhound View Post
    Stan's also got back to my email and said it was OK.
    mbtr member
    Quote Originally Posted by steinercat View Post
    Game on!
    Mikhail Kalashnikov
  1. 700 42c vs 29er 1.9?
    By Spootnic in forum 29er Components
    Last Post: 07-03-2016, 11:43 AM
  2. review: Stan's Grail Team Wheelset
    By chairthruster in forum Wheels and Tires
    Last Post: 04-14-2016, 12:59 PM
  3. Nano 40c vs. Rock n Road 42c
    By 1 cog frog in forum Cyclocross
    Last Post: 01-25-2016, 07:48 AM
  4. 38C - 42C Tubeless gravel/commute tire
    By stephend9 in forum Gravel Bikes
    Last Post: 04-25-2013, 12:47 PM
  5. holy grail SS crank????
    By rammalammadingdong in forum Singlespeed
    Last Post: 01-25-2011, 02:23 PM
Members who have read this thread: 61
