Results 1 to 44 of 44
    I like turtles
    Reputation: TiGeo's Avatar
    Post up your 1x drivetrains
    I converted my standard Shimano double setup over to "ghetto" 1x:
    Wolf Tooth 42t n/w ring
    Shimano Ultegra short cage 11-spd r. der (set the spring to the tighter setting)
    Shimano XT 11-40 11-spd cassette
    Praxxis Works chain guide
    Wolf Tooth Road Link
    Works great but looking forward to picking up the new Ulegra RX clutched r. der for extra chain retention when it comes out soon.
    My next bike will probably have Sram 1x with a 42/10-42 which I think would be a *little* better range than I have now plus the superior 1x technology. Just have to get used to the double tap.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Dec 2009
    i have rival 22 shifters + apex1 derailleur + e-thirteen 9-44 cassette + sram s2200 crankarms + doval 34t oval chainring
    Bikesexual
    Reputation: jcd46's Avatar
    Mine is all apex1 42t/11-42 in the back. I do ok with that setp up, although not fancy.
    Sent from my LGMS210 using Tapatalk
    just get a bike and ride!
    Oct 2016
    Rival 1 hydro with 42 up front and 11-42 rear (NX cassette I think).
    Excellent on the road, though I could use a little more high gear if I am out with guys on full blown road bikes.
    Perfect on dirt paths.
    A bit over geared on gravel/single tracks.
    Dec 2009
    which tires do you use? i use 34t chainring but with 29x2.10 tires
    Oct 2016
    38c triggers, but probably swapping to resolute 42s
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    ok I am swapping a 2x compact Rival 22 group to a gravel bike - I bought a Sram 1x 42t front ring, and looking at rear derailleurs.. I see in the Rival line there are type 2.1 and now the newest 3.0 - and I cannot find out the differences in the versions... I am pretty sure the cage length has nothing to do with it as both cages are available in the 3.0 version...
    Thanks in advance
    FF
    "If I'm leading, I'm bleeding."
    Oct 2016
    No difference outside, just the torx screw on the clutch.
    Sram says it provides a "smoother torque curve for a quieter, more consistent operation and feel".
    Mine is type 2.1, and has been flawless. My wife's Apex 1 is type 3, and has also been flawless.
    May 2017
    Mine's a cross bike I use for the odd gravel ride/race. Rival 1 with 38/11-32. Chainring is Raceface, brakes are Spyres, everything else is Rival. I think a bit more range on each end (40/11-36, maybe) might be a better match for the gravel riding I do, but I don't need that kinda range for CX and I haven't felt like spending the money yet.
    Reputation: mnyquist's Avatar
    Rival 1 shifters/brakes, Rival 1 derailleur, Easton EC90 crank with 44T chainring. Switching to AB oval 42T ring, shortly. KMC X11SL chain.
    Human Test Subject
    Reputation: Volsung's Avatar
    Chorus 11 with a 40t Wolf Tooth chainring on an Ultegra crankset. Cassette is a custom 14-34 Ultegra. Shifter and derailler are Chorus with Hope jockey wheels.
    It might be a 38t in the pic and I may have a Roadlink on, but it wasn't necessary so I removed it.
    Attached Thumbnails Attached Thumbnails Post up your 1x drivetrains-32783365_10155614585983358_2472850089509388288_o.jpg
    You change your own flats? Support your LBS and pay them to instead.
    I like turtles
    Mine
    Sent from my SM-G950U using Tapatalk
    The Top Cap Guy
    Ok thanks for the answers... one other quick question... I am running DT240 hubs and if I get a XD driver for them I can run one of the bigger cassettes like a 10-42 with the rival 1 long cage stuff right - the derailleur can handle a 42 - is the XD the only way to get those big gears and still have a 10t? or is it even worth the 10 if I have a 11t now.
    FF
    May 2017
    As far as I know, the XD driver is necessary to get the 10t at all, regardless of big cog size. There are some non-XD cassettes with 42t+ big cogs with 11t small cogs.
    Oct 2016
    You will need the XD driver and end cap to run a 10t.
    Is it worth it? Thats up to you. If you have enough low gear and don't top out the high end, then no, its not.
    A 42t with an 11-42 has the same high gear as a 38t with 10-42, and you get a lower gear.
    Or you can split the difference and run a 40t and gain on each end.
    The difference between 10 and 11 is quite a bit.
    Bicycle Gear Calculator
    I like turtles
    I don't need anymore high end with a 11-40 and a 42....could do a 11-42 to get a little more low end. I do think the 10 gives you a little more range but certainly not a deal breaker.
    Oct 2016
    It is more range, quite a bit, but if you don't need it, there's no point.
    It's an expensive upgrade, the XD driver and end cap is over $100 for a DT hub, and any of the decently light weight cassettes are over $200.
    Dec 2009
    rival 22 shifter
    apex1 rear dear
    e13 9-44 cassete
    34t doval chainring
    Aug 2017
    Iím runnng SRAM Red shifters, Force 1 rear derailleur, crank is Praxis carbon (38) and the cassette is an e13 (9-46).
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by TiGeo View Post
    Its 10% more. So you can run a 40 and its like a 44 with an 11t.
    Fatbike, XC bike, Gravel Bike....
    I like turtles
    Uphrade to Force 1 hydros complete. Went with a Sunrace 11-42 and kept my Wolf Tooth 42 ring. Kept the Praxis Works guide. Works flawlessly and much better chain retention.
    Similar to OP's setup, 46t wolftooth front, 11-4X(6?) XT rear, 105 der, and a roadlink. Only a few rides, and haven't done enough climbing to determine if it'll work as is long term.
    Switched back to eggbeaters, and an 80mm stem, otherwise ride as pictured. Still figuring stuff out though!
    Reputation: ladljon's Avatar
    1x14
    Attached Thumbnails Attached Thumbnails Post up your 1x drivetrains-dscn3285.jpg
    Tread killer....
    Jan 2018
    Thatís a nice bike!
    Jan 2018
    Quote Originally Posted by garcia View Post
    Very nice!
    Aug 2017
    SRAM Red levers and brakes, Praxis carbon crank, SRAM Rival rear derailleur and E13 cassette (9-46)
    Nov 2013
    10 speed:-
    Red shifters
    JuinTech calipers
    Jagwire cables/housing
    Red crank
    Wolftooth 38t
    XO short-cage 2.1
    1080 11-36
    z1r
    z1r is offline
    Apr 2014
    So, I just sold my cross bike tha had a 1x10 drivetrain consisting of a clutched Shimano SLX rear derailleur and Microshift thumbshifter. It was fitted fitted with straight bars:Post up your 1x drivetrains-9u1rs24h.jpg
    It was bombproof and economical. I ran a 38 tooth front ring and 11x36 cassette.
    I recently discovered that the frame on my commuter bike, an old custom CX bike, was cracked. So, I decided to build up a Macho Man frame I had. Well, someone suggested I contact the builder, I did, and he said send him the frame.
    So, assuming it is repairable and I get it back, I was thinking of building it as a 1x10 instead of the 3x10 it was. I'd like to keep it as inexpensive as possible since I have already dumped most of my "fun" money into the Macho Man build. I also like the clutched derailleur. So, I'd have to replace my derailleur and shifters at a minimum since the Shimano MTB derailleur won't work with 10 spd road shifters. I could stick with bar end shifters if I picked up a set of Microshift bar end shifters. They make a set that works with Shimano MTB derailleurs.
    Or, I could switch to SRAM. My other two Gravel/Cross bikes have SRAM drivetrains. One has a Rival 22 Hydro setup and I love the shifting and brakes but hate the feel of the hoods. Not comfortable for me. The other has a 2x10 Apex setup and while it has mechanical discs, the hoods feel much more comfortable. Since my commuter is out of commission I have been riding my "road" bike that has a 2x10 Shimano 105 drivetrain. Riding it daily for the last two weeks I have discovered just how much more comfortable the Shimano brifters are for me.
    It sort of makes sense to try to go the SRAM route since the majority of my gravel/cross bikes are already SRAM equipped. And, I can get a brake only left lever and 10 speed right lever.
    Looking for suggestions since I'm having a hard time deciding for myself. Too bad the Shiano 105 brifters don't play well with the clutched 10 speed derailleurs.
    Reputation: Nubster's Avatar
    SRAM Rival 40T up front.
    Wolftooth 20T out back.
    Stopping is provided by TRP Hylex.
    Post up your 1x drivetrains-14233027_10154482311934291_2858376979452597215_n.jpg
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Norco Torrent HT 7.1
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    Quote Originally Posted by z1r View Post
    So, I just sold my cross bike tha had a 1x10 drivetrain consisting of a clutched Shimano SLX rear derailleur and Microshift thumbshifter. It was fitted fitted with straight bars:Click image for larger version.
    Go 9 speed with the 10 speed shifters.
    Quote Originally Posted by me;
    Of all the paths you take in life, make sure that most of them are dirt.
    Make
    America
    Gravel
    Again
    z1r
    z1r is offline
    Apr 2014
    That was the setup I was running. Actually, it was a 1997 vintage XT 8 speed derailleur.
    Worked like a champ with both my 7 speed and 10 speed shifters. But I'd really like to run a clutched derailleur and as far as I know, they don't make on for a 9 speed. If it gets too complicated or expensive I may just buy a set of 105 Brifters and stick my spare XT derailleur on; I bought two in 1997, lol.
    You could get a Gevenalle rear derailleur in you flavor of choice (8/9/10 or 11). They have a stiffer/tighter(?) spring than normal and pair up nicely with a NW ring.
    "Just remember, all bikes have front suspension once you put your hands on the handlebars!" - 1SPD
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    Here's my setup on my TKO:
    Ultegra 6800 Crank
    Wolftooth 36t chainring
    XTR M9001 cassette 11-40t
    XTR chain
    Ultegra RX rear derailleur
    Shimano Brifters (R685 I think?)
    Oct 2016
    SRAM 10-42 with a Force mech, standard stuff, a bit different at the front as I'm running a Middleburn crank and 36 tooth narrow/wide Middleburn ring.
    Cutthroat 1 by mapledocumentdesign, on Flickr
    Curmudgeon
    Reputation: shif's Avatar
    • SRAM Force 1 type 3 long cage derailleur
    • Force 1 cranks
    • XTR pedals
    • Absolute Black oval chain ring, 38t
    • KMC X11SL Ti-N chain
    • Sunrace CSMS8 EAX, 11-40, 11-speed cassette
    • Wheels Mfg. bottom bracket
    • White Ind. XMR hubs
    Jul 2016
    SRAM GX long cage derailleur
    Sunrace 10/42 casete 10 speed
    Absolute Black 42 oval chainring
    SRAM force carbon brakes/shifter 10 speed
    TRP hydro, cable actuated brakes
    SRAM force carbon cranks
    Jan 2018
    Is everyone using a chain guide with the 1x setup?
    Nov 2008
    Quote Originally Posted by j102 View Post
    Nope. With a good dropless style chainring a clutch style derailleur you don't need one.
    Jan 2018
    Quote Originally Posted by AZ Stumpy View Post
    A cluch derailleur helps, but I thought people would still use a chain guide for the extra security.
    Nov 2008
    Here's the setup on my Vault:
    Ultegra 6800 Crank
    Wolftooth 40t chainring
    XX1 cassette 10-42t
    XTR chain
    XTR Di2 RD-9050 long cage derailleur
    Shimano Di2 Brifters ST-R785
    Bikesexual
    I dont have a clutch der. So far zero chain drop, even under pressure.
    I like turtles
    I have Sram Force 1 which includes a clutch r. der. and a n/w ring...I still run a guide just because.
    Jan 2018
    Quote Originally Posted by Cheshire Cat View Post
    Nice!
    Jan 2018
    If I change mine to a 1x, I would run a chain guide.
  1. Replies: 10
    Last Post: 01-11-2016, 09:02 AM
  2. Mixing SRAM Drivetrains - 10 speed front + 9 speed rear
    By M0riarty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-25-2011, 04:54 PM
  3. Replies: 0
    Last Post: 05-11-2011, 03:08 PM
  4. Final Sprint - Spinning out 2x10 Drivetrains
    By rkj__ in forum XC Racing and Training
    Last Post: 04-25-2011, 10:45 PM
  5. SRAM X9 3x10 vs Shimano XT 3x10 DynaSys Drivetrains
    By CasinoKiD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 09:43 PM
Members who have read this thread: 185
