Results 1 to 3 of 3
    Mar 2005
    Utility for translating location (longitude/latitude/altitude)
    Is anyone aware of a utility that will translate trackpoints (likely in GPX format) by a set amount, i.e. add 10 meters to the elevation?
    I have a number of tracks that I'd like to merge. I'm assuming the accuracy of each individual track (and can mostly prove it), so would like to adjust each to a common point.
    I've found there are some Perl modules for reading/parsing/writing GPX data, so I could write my own, but I suspect I'd spend as much time figuring out how to get the modules installed on my Windows PC as I would coding up the transformation.
    Potentially I could also use GPSBabel to convert to CSV, import into Excel, transform, then reverse ... in lieu of something else, that might be the quickest.
    Two Tired
    Reputation: CheapWhine's Avatar
    Dec 2005
    Changing the elevation is pretty straight forward since there is a single field that is already specified in meters. Changing location is a by an offset is a bit trickier because it is measured in degrees and you will probably need to change both latitude and longitude to implement your offset.
    Since your elevation change is straightforward, a simple replacement should do the trick. Here is a bit of Perl code that seems to do the trick without using any special packages. I did some testing, but your mileage may vary.
    print "What is the name of the file you want to convert? ";
    my $file = <>;
    chomp $file;
    die("No input file $file") if (! -f $file);
    print "What vertical offset to you want to add? ";
    my $offset = <>;
    chomp $offset;
    my $out = "new_$file";
    open IN, "<$file" or die "Can't open input file $file";
    open OUT, ">$out" or die "Can't open output file $out";
    while (my $line = <IN>) {
    while ((my $loc = index($line,"<\/ele>")) >= 0) {
    my $s = substr($line,0,$loc+6);
    $line = substr($line,$loc+6);
    $s =~ s/<ele> *([0-9.-]+) *<\/ele>/<ele>/;
    $s .= $1 + $offset . "<\/ele>";
    print OUT $s;
    print OUT $line;
    close IN;
    close OUT;
    print "Updated file is $out\n";
    Let the good times roll.
    trailroller.com
    Mar 2005
    Thanks for the snippet.
    You're right, it is reasonably straightforward ... I was blinded by have multiple tracks in one .gpx and thinking I needed to parse the XML. I'll take your code and add a simple search for the first instance of the track name and then the close of the track.
    Quote Originally Posted by CheapWhine
    my $file = <>;
    chomp $file;
    my $offset = <>;
    chomp $offset;
    print OUT $s;
    print OUT $line;
    close IN;
    close OUT;
