Results 1 to 5 of 5
    Prez NMBA
    using mapsource without the CD's
    does anybody know how to set you computer up so that you don't have to drag the mapsource topo CD's around with you? I think i read somewhere that you can do it but can't figure it out or find that now
    Close the MapSource program (if it's open)
    Make a new folder in your C:\Garmin folder and name it "Topo"
    CD 1 contains a folder named "West"
    CD 2 contains a folder named "East"
    CD 3 contains a folder named "Alaska" and a folder named "Hawaii"
    Copy those folders into your "C:\Garmin\Topo" folder
    Click your Windows Start button and select "Run"
    Where it says "Open", type in "REGEDIT"
    Click the "OK" button
    Double-Click the folder "HKEY_LOCAL_MACHINE"
    Click on the following plus signs in sequence"
    +SOFTWARE
    +Garmin
    +MapSource
    +Products
    Click on the folder named "6", and then in the right window pane, double-click the "Loc" registry key.
    "D:\East" is displayed
    Change that to read as:
    C:\Garmin\Topo\East
    Click on the folder named "7", and then in the right window pane, double-click the "Loc" registry key.
    "D:\West" is displayed
    C:\Garmin\Topo\West
    Click on the folder named "8", and then in the right window pane, double-click the "Loc" registry key.
    "D:\Hawaii" is displayed
    C:\Garmin\Topo\Hawaii
    Click on the folder named "9", and then in the right window pane, double-click the "Loc" registry key.
    "D:\Alaska" is displayed
    C:\Garmin\Topo\Alaska
    Close the Registry Editor window
    Open MapSource
    Your Topo maps should now open without the CDs!!!
    NEPMCPMBA President
    Woot! Thanks!
    trail rat
    Reputation: slocaus's Avatar
    Wow!
    I just copied the West CD that I use to the computer hard drive, changed to that directory, and ran install from there.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Prez NMBA
    yup thanks a bunch thats exactly what i was looking for
