Results 1 to 20 of 20
    Jul 2014
    stem mounting for garmin. Enve model
    hey guys,
    I just saw this enve mounting system for garmin
    ENVE Computer Mount - Cycling Computers | Competitive Cyclist
    I'd like to buy this for my specialized moutain bike but I'm not sure if this can be mounted.
    Who try this mount for his bike or mtb?
    you think enve stem has a different distance between bolt as other brand?
    did you seen another brand product a mounting system like this one ?
    thanks
    since 4/10/2009
    Reputation: Harold's Avatar
    out front is not a good location for mtb. That is a road bike mount location, as the GPS is "protected" between the hoods of your levers. Note that the product page shows it with road bars. On a mtb, it's going to be exposed. For mtb uses, you want what essentially amounts to a flipped out front mount, a stem mount, or the old standby, right on top of the bars so that the GPS is somewhat protected by your cockpit setup in the event of a crash.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I like my Garmin on the Stem...
    Nice and protected
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Armature speller
    Sep 2004
    Quote Originally Posted by Cleared2land View Post
    Nice and protected
    Protected, yes...
    Reputation: Joe Handlebar's Avatar
    Apr 2016
    One, I wouldn't drop $40 on a computer mount....but that's just me. Second, I wouldn't drop $40 on something I had no idea if it would work. As the description states, it's "for Enve road stems". It's not just the width between the bolts either, it's the contours of the front of the stem clamp, so unless your stem uses the exact same front plate as an Enve road stem, I wouldn't count on it matching up.
    The member formerly known as Redtires....
    Reputation: Arebee's Avatar
    Sep 2012
    Nice and protected
    I agree that this is the most protected placement, but I still damaged my Garmin 800 last weekend with an identical placement. My GPS has survived unscathed in NUMEROUS falls, but there are times when nothing will prevent damage. Putting it out front is asking for trouble.
    You can reverse the Garmin "Out Front" extended mount so that it sits along side or on top of the stem. SRAM makes a similar mount too. Still not an ideal position.
    Magically Delicious
    While nothing is going to protect your GPS like keeping it in a padded pack, I have well over 10,000 miles with this Garmin mounted on the stem. Adding to that, I have had numerous Youtube worthy crashes that have broken many bones, but no damage to the Garmin.
    Sep 2012
    Agreed! That was my legal disclaimer! ;-)
    My Garmin has also survived numerous falls while mounted on the stem. I wish there was some more rigid case offered, like an otterbox phone case. The silicone case keeps the unit free of scratches and minor impacts.
    That said, I sent my unit in to Garmin and for a $99 flat fee, I'll get a refurb next week.
    Dave's not here.
    Reputation: MiWolverine's Avatar
    I use one of the out front mounts (not this version, rather the bar mount style), but I reversed mine it so it sits off to the side of my stem.
    Yo no hablo inglÚs
    Reputation: dirtyjack's Avatar
    I like the cap mount .
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Magically Delicious
    I looked at the cap mounts and really liked them, but thought they might be a little too exposed.
    You've experienced no problems?
    Reputation: RS VR6's Avatar
    I have a cap mount. IME...it works best with minimal or no spacers above the stem. If you're running 10mm worth of spacers + the gravity cap + the Garmin...it places the garmin fairly high above the stem.
    The Garmin on the side of the stem seems to be a fairly safe spot. Unless you're running a super short stem and your knee smacks it.
    Quote Originally Posted by louit32 View Post
    hey guys,
    thanks
    I use this one on my cat eye (which is significantly smaller than the garmin) but is solid.
    Adjustable Garmin Stem Mount - K-EDGE
    Jan 2015
    Hi, i need some help.
    I have enve holder first gen version and I broke plastic insert.
    Where I can find replacement?
    since 4/10/2009
    Quote Originally Posted by VitaliT View Post
    Did you read this discussion at all? Nobody here uses the Enve mount asked about in the OP. We mostly agree said location is a bad idea for mtb riding. Have you contacted Enve?
    Jan 2015
    Not yet, seems its only solution.
    Oct 2017
    Beauty of an ancient thread here
    Quote Originally Posted by Harold View Post
    Nobody here uses that Enve mount? How exactly did you each that conclusion?
    Counterpoint:
    I've been using a front-mounted GPS for many years and have never had a problem.
    since 4/10/2009
    Quote Originally Posted by fillaroida View Post
    Nobody in this thread stated that they had one to provide an answer for the OP. If OP wanted max attention, a new thread would have been appropriate. Or what I would have done would have been a quick Google search for a product page somewhere (I am sure this thread came up in his search, and that's why I asked if he had read it - because nobody said that they had it), and if unable to find it, I'd have reached out directly to Enve.
    It's possible that Enve might use inserts that some other company makes, or are compatible with. So maybe an insert from K-Edge or Rec-Mounts would work. But being that I don't know that answer, reaching out to Enve would come before posting here (for me).
    Counterpoint:
    Yes, I know some people use out front mounts on their mtb's. That's covered under the "mostly" portion of my statement. But said location is a significant minority of mtb riders. I'd go to say that it's preferred for road use, however, because aero. mtb places slightly different demands on things. Most mtb riders I see who use the out front mount flip it backwards on their mtb. Which is a different scenario than in front of the bars.
    Oct 2017
    Ah, that's different then. Because some folks around here (i.e. MTBR) DO use that mount.
    Awesome!
    Jan 2015
    Problem solved.
    Contacted ENVE and they promised to replace whole holder by warranty.
    Case closed. sorry for necroposting
  1. Garmin model recommendation
    By jm1024 in forum GPS, HRM and Bike Computer
    Last Post: 12-21-2015, 10:54 AM
  2. Garmin mounting
    By Rmabus in forum GPS, HRM and Bike Computer
    Last Post: 06-22-2015, 07:23 PM
  3. mounting garmin on stem
    By adumb in forum GPS, HRM and Bike Computer
    Last Post: 01-14-2013, 01:46 PM
  4. Mounting Garmin Etrex GPS ??????
    By Tnadeau07 in forum Beginner's Corner
    Last Post: 04-21-2012, 04:21 AM
  5. Enve Stem Durability?
    By danridesbikes in forum Weight Weenies
    Last Post: 05-28-2011, 08:11 PM
Members who have read this thread: 53
