Results 1 to 25 of 25
    Laker and a Trail Blazer
    Reputation: Broncstad's Avatar
    Stava app w/iPhone 4s battery life
    How long does your battery last? If I do a four hour ride, it's toast. For those who use this set up, how's it working? Thanks in advance
    Reputation: mestapho's Avatar
    That sounds about right.
    I added this.
    Works great.
    I keep my phone in my hydration pack though.
    Quote Originally Posted by Broncstad View Post
    Turn off push notifications, wifi and 4g.
    Let's Ride Cowboys
    Reputation: TheCreative's Avatar
    Mar 2012
    I would think having a external battery pack would be almost necessary on a long 4 hour ride. Do you mount your phone to your bike?
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    I charge mine in my car on the way to the trailhead. It helps a little.
    Raised in a Chicken-Coop by Chickens
    Adventure Mapper
    Reputation: forgiven_nick's Avatar
    Nov 2006
    Put it in airplane mode.
    I got 7.5hr on my android based htc device that way, still had almost 30% battery life left.
    My YouTube channel for MTB content:
    http://youtube.com/RideAlongside
    Website:
    RideAlongside
    I don't mount it on my bike.
    If I put it on airplane mode will strava app work?
    Adventure Mapper
    Nov 2006
    Yep. It should. Test it real quick. You will need to connect for the app to upload and show you're performance on the different segments you competed in though.
    Website:
    RideAlongside
    I don't think so. Airplane mode turns off the GPS receiver so Strava won't be able to measure speed, distance or location.
    Ive been turning wifi and cellular data to "off". Help a little. Weird that text messages still come through and I think I got a phone call too.
    Phone and SMS messages don't require data service. They were both around well before we had smartphones. :-)
    How do you turn those off without turning on airplane mode?
    AFAIK, You can't unless you remove the SIM card.
    Big B's Trails
    Reputation: ImaFred's Avatar
    Quote Originally Posted by R+P+K View Post
    Correct^^^
    Also make sure and double tap your home button and close all unneeded apps
    I dig dirt!
    Quote Originally Posted by ImaFred View Post
    Correct^^^
    If you're jailbroken you can turn these off individually in SBsettings.
    Correct^^^
    Not so much.....
    How iOS multitasking really works | Macworld
    Except in a few cases, ..., the apps that appear in the multitasking bar are not currently running. When you press the home button, iOS will tell the app to quit. In almost all cases, it quits, it stops using processor time (and hence battery), and the memory it was using is eventually recovered, if required.
    Let's Ride Cowboys
    Mar 2012
    Not so much.....
    RPK is correct. Closing out those apps doesn't do a thing. It's an app switcher not a multi tasking manager. I only close out apps that are misbehaving.
    If you constantly quite all of your apps this way, you are actually slowing your iPhone down because it has to open your apps from stratch rather than a saved state.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by TheCreative View Post
    that's not 100% true...
    there are many more apps running in the background that you'd think... Music and games are the worst 2 that keep using memory, though some are not "running" per say the memory they use though makes those items start up faster, they actually make everything else run slower on the phone and everything needs to play memory swap games to run/save/execute anything. GPS Apps are heavy use apps and will run faster/cleaner when allowed to use as much memory as possible. the lower the swapping of memory the lower your power consumption...
    before quitting back ground apps... notice the memory use pie chart...
    now after
    I quit 7 background apps, Music, Pandora, 3 Angry birds (yes I like pissed off birds ) Trillion and Safari..
    if you notice the numbers, nothing changes but the "free" jumps from 4 meg to 139 meg, that's an awful lot of swap files for the Iphone's limited memory that have to be moved around for the GPS to use it's high requirements of memory..
    OK, ya when all said and done we're only talking about maybe adding 5 mins of run time with the GPS on the phone.. but it adds up
    if you really want to get the absolute most of of the battery quit all "waiting" apps but nothing is going to help as much as getting an external battery. I have wondered about getting one of those tiny Phone specific type Solar charger things... been wondering how well the little panel mounted to the top of the pack would help?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Oct 2007
    I thought it turned off the GPS too.. but it didn't just now when I tried it.. all the location services are still up and running... hmmm ill have to try airplane mode next ride and see what it does
    notice the location services are on and the little arrow in the upper right is on... hmmmm learn something new everyday...
    (edit)
    ahhh what I did find is with out a cell connection Strava wont work correctly as it can't get map info. Unlike some of the other GPS apps it doesn't allow for pre downloaded maps.
    also just compared Everytrail, MotionX and Strava just now sitting here inside at my computer and both Everytrail and MotionX got a Sat signal in a few seconds, where Strava erred and said there wasn't a signal.. bummer as I kinda liked Strava's interface..
    Aug 2010
    Quote Originally Posted by forgiven_nick View Post
    Yup. "Airplane mode" in other phones shuts off the GSM/Whatever radio and stops the phone from hunting for a tower. That is likely what's killing your battery.
    Jan 2009
    Rather than use the Strava app, I use another app (Oruxmaps, free) which gives offline mapping and much more control over power-sensitive settings like how often a gps point is taken (1sec vs 2,3.. etc). On finishing the ride I email the track to upload@strava.com. Works a treat. This, combined with airplane mode, gives 5+ hrs easy and more utility too.
    EDIT. Oops. Just realized this Q was iphone specific. I have an Android but there must be the same or similar apps for iOS.
    Quote Originally Posted by thomllama View Post
    now after
    Reminds me of the time Windows 7 came out and everyone howled about how much memory it used. One of the lead technical guys came out with something along the lines of "Free memory is unused memory".
    (edit)
    Strava probably relies of A-GPS (assisted GPS) and so won't work in airplane mode. Interesting that you still had location services when in airplane mode. How long did you test it for? I wonder if it would eventually fail when trying to reacquire a position. - e.g. fully quit the app, and restart it.
    Oct 2007
    The GPS signal seems to work fine,.. the issue is it shuts off the cell/data system it seems. Basically it's still working it just can't access a map to draw on the screen of the phone. I didn't try to upload to the site or anything but I'd guess it's all good, it seems Strava is still tracking and when you upload to the website it would draw on their map like normal. Just can't see anything on the phone at the time of riding.
    Like I said Everytrail and GPSkit and a few others allow you to pre-download map info.. so before you go you can get the tiles for the area you are going to ride. I've done this a few times as there are a bunch of areas I ride where the cell system is less than reliable. I have noticed that it saves a bit of battery life by pre downloading the maps as the phone isn't searching/ requesting, or downloading the map tiles as you ride. But still draws the map on the phone without issue when in the no reception areas, as long as you've downloaded the tiles are you are in.
    GPS signal is receive only, where Cell/data is request-send-receive so it kinda makes sense that Airplane mode wont cut the GPS as the phone isn't sending out any info/waves/what ever's that could interfere with the plane... just my guess anyway.
    Hmmm, a quick google would indicate Cyclemeter won't work in airplane mode. I might do a test at lunch time.
