    Specialized Speedzone Sport?
    So I have a cyclometer with a casing like this one:
    http://www.roadbikereview.com/Channe...uct_142514.jpg
    but the display is formatted a little differently.
    I've been able to figure out how to set up the rollout and scroll through the current time, something called "ATM", distance, and odometer. What i don't know is how to change the display from current speed to average or max speed and what the purpose (and how to change between) of the "1" and "2" that are displayed. Anyone here able to help me out?
    At Work
    Reputation: sxr-racer's Avatar
    I may still have an owners manual, let me look this weekend.
    anyone?
    Reputation: plantdude's Avatar
    I have the speedzone pro version from quite a few years ago. The 1 or 2 is most likely the settings for two different bikes. I have this same feature. If you hold both buttons down together, it will switch from 1 to 2. You have to insert a wheel dia. for both numbers, and if you have two mounts (I do) you can easily switch the computer between two bikes.
    As far as changing the function, one of the buttons on the side should make that happen. If not, it may be an issue with the computer. It is also possible that the model you have doesn't have those features.
